Chuck14025
Starter just clicks
Chuck14025
1994 520 H.   Starter just clicks.
1. Battery 12.6V, load test OK.,    New solenoid. Ground good. Key switch tested ok. Wiring diagram shows a 'kill' relay - I can't find it on the tractor. Checked the 3 relays under the battery box - they work. Neutral switch, PTP and seat switch work mechanically.
2. Not able to find article on this problem when searching. There must be dozens. How do I find them?
3. Can I test the starter without taking it out?
4. Is there a 'kill' relay?
thank you...
Lee1977
When the solenoid clicks you are not getting enought power. You say the battery is good so you are not getting ground. Check and clean all the grounds and make sure the switch is grounded.
Chuck14025
I'll put a charger on the battery to get the volts up. Cleaned the main ground at the frame yesterday. I'll check the switch ground. Thanks.
daveoman1966
Unless replaced at some point, that starter is 26 yrs old and quite likely needing refurbished or, at least, cleaned out and lubed.  Over the years (decades), micro dust accumulates and robs power; brushes get worn, bearings needlube replaced, etc.  If all grounds are good and battery is up, take the starter off and clean it up.
gwest_ca
There is a kill relay.The relays are all identical so the only way to identify them is to compare the wire colors going to each of them. Each relay has normally open and normally closed contacts so can function differently to meet the requirement.
Garry
953 nut
10 hours ago, Chuck14025 said:
1994 520 H.   Starter just clicks. This is probably a bad battery cable or connection.
1. Battery 12.6V, load test OK.,    New solenoid. Ground good. Key switch tested ok. Wiring diagram shows a 'kill' relay - I can't find it on the tractor. Checked the 3 relays under the battery box - they work. Neutral switch, PTP and seat switch work mechanically. The kill relay has nothing to do with the starter, it will only come into play when the key is turned off or the PTO is on and you get out of the seat.
3. Can I test the starter without taking it out? Take an automotive jumper cable set, put the black on battery "-"  and the starter bolt at the engine, Put the red cable on the starter post and the battery "+". This will bypass all wires on the tractor and if the starter won't turn over it is bad.
thank you...
Chuck14025
Thank you all for the excellent responses and finally I've learned what the 'kill' relay is all about.
Tested all 3 relays - they all behave the same.
NEW INFORMATION
1. Cleaned all wiring, etc. turned key engine, STARTED right up.
2. Shut it down, tried to RESTART - not even a click. TOTALLY DEAD.
3. 12.7 volts on the battery.
4. Connections tight. Solenoid works. Starter works.
5. HOT wire from battery + to starter solenoid where the Light Blue wire attaches - STARTS RIGHT UP.
QUESTION IS: Why isn't the Light Blue wire to the solenoid being energized? What are the possible scenarios?
1. Intermittent operation of the key switch?
2. An opening on the coil side of the electric circuit?
3. Other possibilities.
Thanks for the help.  Coffee and donuts are ready.
Chuck14025
Sorry for the mistyping.  QUESTION IS: Why isn't the Light Blue wire to the solenoid NOT being energized? What are the possible scenarios?
gwest_ca
There is a diagram here for just the starter circuit making it easier to follow
Garry
Chuck14025
Thanks gwest. Now I have 3 different copies of the 'demystification' guide with 3 different wiring diagrams but yours at least shows the brown wire from the start switch going to the coil side. Perhaps something on that side that should be closing the circuit isn't.
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
