The Tuul Crib
Torington B-1416 needle bearing
The Tuul Crib
Started to put my sunsrtand together and
ran into an ef up with the needle bearing .
l have looked for a wheelhorse number
for the b-1416 and want to make sure l
get the correct one. Any help on the part number would help. Thanx!
pfrederi
Is that a bearing in the hydro gear motor???
The Tuul Crib
Yes there are four of them .
pfrederi
Do not think you will find WH numbers.  Hydro gears were repair by replacement.  I was curious as to why you took yours apart. Were you able to fix anything??  Pumps you can do something to but not sure what you can do to a gear motor.  Aldon took one apart once to change the output gear to work with a GT14
The Tuul Crib
Took it apart to resurface the slippers
the swash plate and surfaces in need
of repair.  I guess the word would be
complete.
gt14rider
Torington b- 1416 is still available,  I replaced 2 on out put shaft, (buggerd up 1 taking shaft out. ) snap rings are available at( LJ power ).
The Tuul Crib
Does lJ fluid power have these needle bearings? I did the same thing on my bearing that's why I have to get another one. And I also realized there is an O-ring inside the part with the four bolt holes.
gt14rider
I purchased bearings from bearing distributors troy ny. But I'm sure any good bearing supply Co should be able to get them. Check out the vendors on here. Check out my post ( gt14 90-2062 ) it has o ring #s , different tid bits I've learned so far ,
The Tuul Crib
I have already received the gasket set and seals plus O-rings from LJ fluid power. Just went to eBay and found two needle bearings in case I mess another one up.
i'll check it out! Thanx!
The Tuul Crib
Do you remember what you torqued
these ten bolts to. I can't seem to find a chart anywhere for the specs?
gt14rider
I use bolt torque chart for bolts with out torque spec
The Tuul Crib
Great thanks for that. Now my next problem is I torqued the bolts down on that piece and I cannot turn the gear after l torque them.Cannot figure out why this is happening. When I loosen them back up I can turn it fine.
gt14rider
Did you set the bearing deep enough as to not bind on snap ring or gear, or the 4 bolts on gear side collar, turn that collar, see if that binds.
The Tuul Crib
Yes I took it back apart again and check those clearances and there's plenty of room. That gear turns really hard and I don't believe that it should turn that hard once it's all together. I check the torque specs on the bolts the eight bigger ones or the 3/8 ones are torqued at 23 and the two smaller the 5/16 are torqued at 8 foot pounds
Stormin
I wonder if a needle in a bearing has been dislodged?
The Tuul Crib
All the needle bearings look in tact.
gt14rider
Any progress :confusion-scratchheadblue:
gt14rider
How about some pics
