Salbreth1
Curbside 418-C puller build
953 nut
10 hours ago, Horse Newbie said:
Is the transaxle/ rear end the same for a hydro and an 8-speed ?
All of the action on an eight speed takes place in the transmission. With a Hydro the direction and speed control all takes place in the hydro unit, it then transfers power to some reduction gears inside the axle housing. The differentials are the same.
  • Thanks 1
Lee1977
If you are making a  2" receiver hitch for them the frame for the hydro has to be wider. I cut the metal for my hydro the same width I used for the 312- 8 and it wouldn't fit.
I have another one half made for an 8 speed.
  • Like 3
ebinmaine
Excellent point.
I did the same thing.
Also found that out while swapping homemade plow brackets.
I've since saved a case from a bad hydro transmission to use as a welding jig.
  • Like 4
  • Similar Content
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • Bill D
      By Bill D
      I have to change some o-rings on my GT-1800.  What size o-rings do I need for the ORB-5 and ORB-6 fittings.  Also, does anyone make a ORB-5 to JIC-6 fitting?  Looking for both straight and 45 degree fittings.  Thanks.
    • Tfarver
      By Tfarver
      This is my commando I just picked up awhile ago. Looks like it was-tried to be a puller. Got it with no motor but have a strong 14 to install. Does anyone know how to preserve the sheet metal but keep the “rust look”. Will be using this unit for small farm chores. I really like the look currently with the rust and wear, kinda tells a story I suppose but I don’t want to leave the Tin “unprotected”. I’ve heard of guys lightly rubbing down the metal with used motor oil?  Any thoughts, comments, concerns are highly appreciated!
    • TonyI
      By TonyI
      I have a 418-c  worked great plowing over the winter.. but now is having no power pulling a load fwd.
      replaced the fluid.. the old fluid didn't look bad. feels a littls better., but still significant loss of power and high pitched whine coming out of the hydro.  the lift works fine
      is there a repair manual our there for the hydro?  Is there a way to reverse flush the system?   I hear sometimes the hoses crack internally and clog things up.
