Flat Thunder Channel
520-H Ignition Trigger - Replacement
Hello everyone!  I am going to replace the ignition trigger on my grandfather's 520.  Any tips, tricks or important things I should know before starting?  I already have the parts.  I just need to tear into it.
I didn't know Cummins owned Onan.
WHX??
Yeah for a few years now... they wanted a piece of Onan's genny action I think.
Change out is pretty straight forward. Quite a few threads on doing it here. Some may suggest taking a look at the governor as long as the flywheel is off.
here's a manual if you don't have one.
492-4006 Onan P216 P218 P220 P224 SM.pdf
lynnmor
Onan started using a gasket like material under the trigger, if it doesn't have it, I would add it.  Some think it is to reduce heat transfer.
You may need an impact wrench to remove the flywheel bolt if the tractor was exposed to water too many times.  I only had one that was frozen like that, the threads fought all the way out.  Clean the bolt and crank threads and make sure the bolt threads in easily with your fingers, I had to run a tap in on the frozen one.
Watch how the flywheel key is installed.  Clean the crank and flywheel thoroughly using 600 grit paper or crocus cloth, torque to 55 lb. ft.
Thanks for all the information!  I wasn't overly worried, but sometimes getting others perspective is helpful / time saving.  I downloaded the manual for future reference too. 😁
I fixed it!  Check out the repair video if you are interested in replacing a ignition module (crank trigger) on a 20 HP Onan.  The video illustrates the symptoms it experiences in real life.  Hopefully it will help others diagnose problems on their 520 Wheelhorse.  Dad and I struggled to identify this problem.  We never made it a priority and the problems it experienced were similar to a fuel delivery issue.  I am happy to say she is back in action!!!  Go team Wheelhorse! :)   520 HP WheelHorse; Engine Repair
  • Like 4
tom2p
Nice job !
( commented in other thread )
Pappy 4430
Can you give me those part numbers please ? Can't read the trigger number.
Thank you very much
Edited by Pappy 4430
Thank you very much
166-0785 & 166-0767
Pappy 4430
7 minutes ago, Flat Thunder Channel said:
166-0785 & 166-0767
Thank you very much sir !
I have same problem with my 520-8
You are welcome!  Happy wheel horsing! 👍
  • Thanks 1
Shippey
I know this post is old but wanted to pile on and say this video was outstanding.  I used it to fix my 520H.  I'd like to add a couple of notes and hope Flat Thunder doesn't mind.  First, when I went to order the parts I saw a note suggesting to order the rotor first as this was most often the problem.  The rotor was about $35 and the igniter about $140 so I thought I'd take the suggestion.  Turns out they were right.  Just changing the rotor solved the problem.  FYI since it was a little laborious to take apart and I thought it would be more so to put it together, I ordered the igniter anyway.  As it turns out, there was a 2 week delay to ship it so I put it together with the rotor only and cancelled the igniter after the problem was solved.
Second, the fly wheel cover comes off, and more importantly, goes back on if you take the regulator off,  It's the piece FT struggled with a little getting the fly wheel cover off.  It's only a short 3/8" head bolt and if you can keep from bending the sheet metal taking the cover off, it's a lot easier putting it back on.
Thanks Flat Thunder.
lynnmor
Was your rotor black or a light gray like the one shown in the first post?  Usually the newer light gray ones had fewer problems.
No problem!  I glad it helped out on the repair process.  Thanks for watching 👍😁
Shippey
The old rotor and the new rotor were both light gray.  But there's an update.
Shippey
I need to update my post above.  Specifically, "when I went to order the parts I saw a note suggesting to order the rotor first as this was most often the problem.  The rotor was about $35 and the igniter about $140 so I thought I'd take the suggestion.  Turns out they were right.  Just changing the rotor solved the problem".  Turns out it didn't solve the problem.  I replaced the rotor only in early Oct 21, when it was still warmish, and the 520H ran as it should.  So I parked it and waited for the snow.  When I went to use it in the cold of Jan 22 the shutdown problem returned.  In fact it was worse since it would only run for about 5 minutes when previously it would run for almost 10 before it shut down.  I ordered the ignition control from Jack's Small Engines which cost $163 with shipping.  Worst part was it took a month to get it.  I put the ignition control in and have run it for about an hour in 15 degree weather and so far so good.  It's parked again and waiting for snow.
Handy Don
Thanks for adding the extra post.
Supporters are able to go back and edit their earlier posts for up to, I think, 30 days. After that, depending on importance, you can ask an Admin to make the change. Non-supporters can only edit their previous posts for, again I think, 48 hours.
  I wouldn't change one without the other simply because it's such a time intensive process.  Glad you got it fixed up!
  This was one of the most difficult faults that I had to diagnose on grandfather's tractor.  Cheers,
RonnieB2nd
What's the problem? Trouble starting?
Shippey
Started fine but would only run 4-10 minutes and shut down like I turned the key off.  Had to wait 45 minutes to restart.
lynnmor
Temporarily, run a jumper wire from the battery + to the coil + and see if the problem continues.  Of course only use the jumper while actually testing.
  • Similar Content
    • Truckedup1
      By Truckedup1
      I have a very recently restored 1989 wheel horse 520-HC tractor with 60” deck. Family owned for over 10 years but now it’s time for another project. Please contact me with any questions I have the original 60” deck but it was rough so I sourced the current deck off this site, it really is in excellent condition for not being restored.
    • jleitschaft
      By jleitschaft
      Hello All,
            New to the group and looking for advice. My father was a devoted wheel horse enthusiast for many years. He only cut grass with a wheel horse tractor (rear discharge deck) pulling a Parker lawn sweeper. We have a lot of property and it took him a while but he was retired and loved being on the wheel horse. When he got sick, I had to take over all the lawn maintenance. All of our family lives close on the same road. At the time, I was responsible for maintaining 7 properties plus my fulltime job. Using the wheel horse was not an option for me so I bought a commercial zero turn mower.  Unfortunately, in 2017 my father passed away. I have all his tractors and it has been hard for me to think about what to do with them. He had 6 wheel horse tractors total. 3 tractors we used for cutting grass and 3 tractors are show pieces that have never cut a blade of grass. I have a few guys that have been asking me for years to sell them but I am not sure if I’m ready. I am turning to the group because I am lost at what I even have. Its my belief that the tractors are rare and the conditions are mint. If anyone would be willing to express their opinion and provide feedback I would be grateful.
      Wheel horse 420 LSE (shows 7.5 hr)
      Wheel horse 520 hydro (shows 92 hr)
      Wheel horse classic GT (shows 26 hr)
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • SPINJIM
      By SPINJIM
      1992, Wheel Horse 520-H.   Onan overhauled: New rings, cylinders honed, valves lapped, new carb., new seals and filters, new fuel lines and primer bulb for easy starts.  Seat is like new.  Front tires are new.  All tires hold air.  Some repainting, but didn't need much; was stored indoors.  New decals.  Other new parts.
      Has swept front axle and Variable Ratio Steering.  Belt cover ventilated to cool back cylinder.  Rear wheel weights are 55 lbs. each.
