Joel
My dad gave me his c105 with a plow attachment. I have taken the mule gear off to replace the belt, check bearings, and replace fasteners. Although now I cant seem to get the darn thing back on. I know I should've taken pictures b4 tearing into it. I guess I got too excited. If someone could send a pic of how theirs is mounted thatd be great!
ebinmaine
:text-welcomeconfetti:
I can't help you get your tractor fixed back up but somebody will be along shortly...
SylvanLakeWH
Here are a few from my C 105.
If you need other angles let me know.
IMG_0361.JPG.19f9cf2fec5d4544699a455a24b822cd.JPGIMG_0362.JPG.57f056fb070806e817ca8c15e30b8927.JPGIMG_0368.JPG.d744a92703910d71e3e6333ad8cf8799.JPG630017403_IMG_05462.JPG.089bc9ab39232b2b8b4d1c01ce339021.JPG
Edited by SylvanLakeWH
Achto
:WRS:
Joel
Joel
I actually need to figure out how this part mounts on. I hold it up to the front and nothing seems to line up. Could I get a picture behind it possibly? Maybe there is something I'm missing. Or do I put the hood on before this?
Joel
Thank you very much!
  • Similar Content
    • 87 312-8
      By 87 312-8
      looking for mule drive bearings for a 36 inch rear discharge deck 1986/87 312-8, thank you
    • Cstauffer24
      By Cstauffer24
      So first and foremost , I'd like to take the time and thank anybody and everybody that is able to help me with my issue! I have minimal electrical experience and I'm having issues finding any prints  or diagrams for this 108 - 5 Wheel Horse. I recently just bought it and brought it home to try to get everything working properly. The gentleman I purchased it off of was jumping the battery off of the solenoid to get it start. Which it started up but it didn't move forward or reverse,(because one of the belts were off.) I brought it home to my shed cleaned up everything as best as I could make sure the belts were on properly and they weren't loose or dry-rotted. And I went and bought a new ignition switch. I assume maybe that the switch was bad but further in depth I feel that the original switch was fine. So my next step was I move forward to the solenoid I marked where the wires were on the old solenoid replaced it and it did the exact same thing. It would blow the little small 15amp fuse link right to the right of the solenoid that has a black with orange striped wire that goes from the ignition switch to this fuse link. And from the fuse link it goes to the left side of the solenoid.
      I've come to conclusions that the coil itself may have had a short in it because when I unplugged the coil the fuse does not blow. And I am putting a 15 amp fuse in and as soon as I turn the ignition on it blows the fuse. Any help possible would be greatly appreciated!
    • Rock farmer
      By Rock farmer
      Are the bearings replaceble  by themselves?
      or do I need to replace the pulley?
       The inner vee pulley has a destroyed bearing.
      can I use a puller to remove the outer idler pulley?
      or will I destroy that one trying to get it off?
      they seem to be pressed on.
      are replacements available?
      thanks!
      joe
      I'm talking about a 1990 312-8 with a 42” deck.
    • Denis L Goulet
      By Denis L Goulet
      hi I have a 520h,with 44 inch snow blower, the blower belt slips or squeals under heavy loads, does  belt need replacing or its an adjustment, also what is belt # replacement. Thanks.
    • Danny856
      By Danny856
      Hey guys, I'm sure the answer is somewhere on this site but for the life of me I can't find it. I have an '89 Wheel Horse 310-8 (210K806) and my mowing deck is 0542MR04. I need the belt that connects the two. The one that goes from the engine/mule drive (?) down to the deck. It kept poppin off. I thought I finally had it set right but then it came off again and I ran over it. Can anyone help? Thanks in advance. Dan.
