firemanironman
can you identify this wire?
firemanironman
I picked up a wheel horse and I am having trouble finding the connection for this wire. I have no spark and  have searched for the placement of this wire within the distance of its length...any ideas?...can't seem to paste the picture....
Edited by firemanironman
ADDED MEDIA
firemanironman
One wire comes from the harness and the other into the relay? connection on the left side of the tractor. Thanks!
firemanironman
953 nut
:WRS:
That appears ti be the "Seat Switch Relay". If you can tell us what year 312-8 you have we can give you a detailed wiring diagram of each system.
gwest_ca
Two wires into 1 terminal or 2?
Garry
firemanironman
Thank you for your responses. The seat switch relay seems to be working because it will not turn over unless I am sitting, I am not sure if that fact rules out the switch relay?  I am also not sure of the year, I will look for markings...is there a probable spot on the frame or engine to look? One of the  2 wires come from what looks to be the main harness picture added and the other comes from the terminal  on the right side...picture added..
Tractorhead
I guess it can be a Neutral Switch connector, or a „Clutch pressed“ switch.
without exactly knowing of your tractor‘s details, i would look for a Switch mount near Clutch Pedal or link
or maybe PTO.
gwest_ca
The tractor ID decal was likely under the left side of the seat on the rear fender pan.
Post all the numbers off the engine data decal including the serial number. May be able to identify with those.
Garry
Darb1964
I'm not a big wiring expert, but from the photo did you check under the fuse that is missing?
gwest_ca
Being the wires are black which are usually grounds it may be for the original solenoid that required one of the small terminals to be grounded.
Garry
  • Similar Content
    • Hardy6
      By Hardy6
      Hi I recently got an old charger 12 that had been sitting in a friends backyard for at least 20 years. The engine spins over and the starter works but it has no spark, I’ve been looking online for some solutions but I can’t seem to find any other charger 12s with my ignition setup. It seems to have a sort CDI box but I’m not sure. Does anybody know how this works or any tips on how to test for where the problem is ?
    • BrianKoch
      By BrianKoch
      Hello gentleman,
      Problem: will not crank on its own, will crank with jump box—but still not fire
      Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
      I have my test light out and am probing around.
      There is no power at ignition/magneto wire or the ignition/starter wire
      There is power everywhere else
    • Jeff-C175
      By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 1.4MB Color
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • grasscuts
      By grasscuts
      Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod  length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
