JaysHorse
Delivery!!!
CountryRock
Carlisle?
WVHillbilly520H
TSC Hi-Run?
JaysHorse
Deestone. 23x10.50-12. Couldn’t beat the price. $100 for pair shipped to my door. 6 ply
Edited by JaysHorse
  • Excellent 3
Darb1964
Nice
Bean701
Welp, I feel silly.  Got my Deestones tonight too from Amazon, but I got 8.5s and it cost me $128 shipped for the pair.  Leaning them up against the 312 and I don’t think I’m going to be happy with the look, too skinny.  Wish I had done 10.5 now...
Mikey the Monkey
Can't wait to see them mounted...great deal!
JaysHorse
Got them on eBay from a place called simple tire. Learned my lesson last time when I got the 9.5’s.
Pollack Pete
I love getting new tires.You gonna clean up and paint your rims before mounting the new tires?
81blackhood
I put the Deestone 10.5 wide on my tractor.   Very nice tire for the money but their sizing runs on the smaller side.   I was hoping for a wider tire.7627B4EA-29CF-4A5F-A092-1721E1F3C44B.jpeg.207b999db4a63a0c980969768b5037b8.jpeg
  • Like 4
AMC RULES
:rolleyes: Any wider, and the possibility of no chain clearance would be an issue.
JaysHorse
I agree 💯. I had a pair of the 9.5 and not 10.5 and they seem very similar.
JaysHorse
Ready to do some earth mulching!!
JaysHorse
@81blackhood not sure what your running but I only put 20psi in mine
The Tuul Crib
:text-yeahthat:
Digger 66
Nothing beats New Tire Day !
Pullstart
Here is my buddy’s 312 with a pair of my Deestone 8.5’s on 502 Wheels.  These are loaded with antifreeze and virtually zero air pressure, so they might be a bit on the low side.... but they have excellent grip!  To compare, my 10.5’s aren’t loaded, and on the 502 the 8.5’s came off of, I have much less field traction.  I really should load my 10.5’s some day...
Edited by pullstart
Add a picture...
81blackhood
 Unfortunately It’s going to be a little bit before I have a running tractor.  Need to rebuild the motor.   I have 18 psi in them nowB873EBF0-CCBF-4AB5-B625-3CE8A422248C.jpeg.e7c01ff38ae4e39e0d7931a86f96ba8e.jpeg
  • Sad 1
JaysHorse
Cleaned them up but no paint yet. Thinking winter project.
JaysHorse
How do you load them?
ClassicTractorProfessor
I use one of these with an old rv water pump to do mine
Pullstart
I fill a portable air tank with the fluid, then charge it with air and let the air pressure and gravity push it through.
Mikey the Monkey
I had tire shop fill my 26/12/12's with beet juice . Cost was $50 each. Took 10 minutes a tire. Well worth it in my opinion.
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      Need a pair or rear rims for 518xi, 520Lxi, 522xi, 523dxi, GT18, GT20, GT22, GTD23D, tractors.  Can take new old stock, nice used, or used that need refurbishing.  Anything will be fine.  Needs to be within 2 hrs of Erie, PA, or shipping available.
      Thank you,
      Mike.
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • PWL216
      By PWL216
      Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
    • heysavoy
      By heysavoy
      I have a 1990 wheel horse classic model # 31-12KE01 and need to replace all 4 tires. The sizes are 15x6 8 NHS on front and 23x9.5 12 NHS Rear. I'm wondering if anyone has any specific tire they have purchased and found to be reliable? I have an acre yard with a few hills but nothing severe. I've looked at Carlisle, Marastar to name a few. Also do most folks keep the same rims and take them all in at one time to a local tire garage to have them mounted or just buy new ones with rims? Is having the correct size shown above all I need in order to make sure its an exact fit for my tractor?
