Spini
416-8, Stock Tires are 6.50 on 8" Wheels, Can I Go Wider ?
Spini
I'm thinking about going with 7.50 tires on the front with the 8" stock rims.  I mow in a wet area and am thinking if I increase the surface area, I'll be less likely to sink.  I already went wider in the rear, which seems to work well.  I'm also running lower pressures all around.
My main concern is if the slightly wider tires will clear the mower deck when I make tight turns.  As it is, the 6.50 clears only by about an inch.
I'd like to go with the 7.50 Carlisle Turf Masters, the mounted width is 7".  Currently I am running the stock tires, which are Turf Savers, and according to Carlisle, the mounted width is 6.6".
I guess if that's the case, it may not make much difference in surface area, and I would be risking rubbing the tires on the deck.  I have a 42" deck.
If anyone is using (or knows for sure if) 7.50 Turf Masters on an 8" wheel with a 42" deck on a 416-8, please let me know how well it works.  Obviously
I can't risk "tire rub".
I also welcome any other suggestions for mowing wet ground.  Thanks in advance.
RandyLittrell
You should be able to go to the 7.50's with no trouble. They will "pooch" out more than stock, but I don't think it will look bad at all. Post some pics when you do it!
:WRS:
Randy
shallowwatersailor
I can't answer if there will be interference with your deck, but the 5xi-series have 16x7.50-8 tires on 5-3/8" wide rims. I never noticed if they "pooched" any more than other tires. Kenda K500 Super Turf tend to run taller.
953 nut
:WRS:
If you have an inch or more of clearance with the present tires you will be fine.
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      Need a pair or rear rims for 518xi, 520Lxi, 522xi, 523dxi, GT18, GT20, GT22, GTD23D, tractors.  Can take new old stock, nice used, or used that need refurbishing.  Anything will be fine.  Needs to be within 2 hrs of Erie, PA, or shipping available.
      Thank you,
      Mike.
    • Rob R
      By Rob R
      Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216.  He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • morePEdal
      By morePEdal
      416-8 with Onan P216 Engine
      The good:
      *576 hours
      *Nice, clean deck (42”)
      *Nice Plow
      *Wheel Weights
      *Chains
      *2nd owner. 1st owner sold the house in 2020 and said he was getting too old so he included it with the house.
      *Original receipts and paperwork and manuals.
      *Receipt showing tune-up and changing from the deck to the plow in November 2021
      The bad:
      *The last time it was used was the winter of ‘21/‘22. It is currently set up with the plow.
      *Had trouble starting, when it started, it died after 4-5 seconds. He had a portable charger and it helped. We got it running, but when I turned it down to idle, it died.
      *I didn’t get a chance to test drive it because of this.
      *One front tire goes flat fast, one rear tire has a slow leak.
      *He is going to buy a battery before I look at it again on Friday so I can test drive it.
      What do you think is the issue? Is it the battery or fuel system?
      Do you have a way to verify what year this is with the ID number and serial number? Also, the ID number of the deck. I’ll upload pictures of the stickers.
      *He says his driveway has an incline so snow and ice would pool around his door opening so he got tired of his wheels spinning. He decided to pay for plow service. (Home is big and nice with a lot of land.) He also decided to get a zero-turn mower so that’s why this 416-8 wasn’t used since after winter ‘21/‘22.
      He’s asking $500.
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
