mhlmeader
Suburban 400 restoration
mhlmeader
I wired up a 240v outlet for the air compressor today, and put together the sandblaster.....she blows!!! Prolly get some ppe, and blasting medium tomarrow and give her a try.
  • Like 4
ebinmaine
Looks like you have some really interesting stuff in that there play space..........
mhlmeader
Yeah, I've acquired some stuff, :)
953 nut
You will be best off avoiding silica sand. For your own safety use some "Black Beauty" or "Black Diamond" blasting abrasive. Tractor Supply sells it.
mhlmeader
Yeah, I been doing alot of reading up on it, and the Black Diamond is what I'm gonna get, the fine grit seems to be most recommended to avoid clogging, thanks for the recommendation.
  • Heart 1
mhlmeader
Well yesterday was my first attempt ever at sand blasting, didn't go as well as I hoped.  But today I had better success I think.  It's not perfect, but it something to work from.
  • Like 4
  • Excellent 3
rjg854
From the picture looks like you did good
Jennifer
On 5/20/2019 at 9:01 PM, oldredrider said:
"Purtyfied"...like this:
Could you please post a few more pictures of the engine on the sweet looking Horse!  Thanks!
mhlmeader
Get a useful tool, and the friends and family crawl outta the woodwork....blasted this door stop for my Dad. Today:)
  • Haha 1
ebinmaine
Niiiice
Also a boot scraper??
mhlmeader
2 minutes ago, ebinmaine said:
Niiiice
Huh!!!  Never made the connection.  Sounds good
  • Haha 2
mhlmeader
Parts is parts...making a lil more progress sandblasting...and making a mess
  • Like 5
mhlmeader
https://youtu.be/u_TmWX6zJKk
No blasting today cause of rain and laziness,  but I did see if the engine would run, it PURRS!!
Edited by mhlmeader
Added video
ebinmaine
Niiiice....
Mikey the Monkey
Great thread. Great progress. How did that blaster work with that air compressor?  Pros and cons?
mhlmeader
Thanks,  so far I would say I'm pleased with the blaster it has been working pretty well, once I kinda got it dialed in.  The pros and cons......it seems to work it's best at around 100psi or more, problem is the air compressor is only a 30 gal tank, so it really cant keep up for very long.  I can blast pretty good for about 3 minutes, then I close the valves on the blaster and let it build up more pressure, doesn't seem like a long time, but for the little parts and generall smallness of the tractor, it's really not too bad.  By then I need 5o wipe off the goggles anyway, just to see better.  A 60 gallon tank, would prolly be much better.  I'm using the finest grit material too, so glogging hasn't been an issue.
  Cons!!...its messy!!.. I set up just outside my roll up door about 5 feet.  I,ll probably start closing the door abit to help that.  Still get alot of material back in the barn, no biggie, but just messy.  I wear goggles,  faceshield,  respirator, welding jacket and heavey leather gloves.  Moister in the blast materials can be an issue, but this has a water trap, and somewhere I read to use a 25' hose from the compressor to the blaster tank, and that's suppose to help aswell.
 Overall, I'm pleased, and can see myself using it for other small projects.
AMC RULES
:rolleyes: Can we see a pict of your work site, next time you're blasting parts...
so we can get an idea of what "messy" really means?   :thanks:
Mikey the Monkey
Thanks for the info. How long would you estimate it took to blast the parts in the picture with hood, frame and fenders? Looks like they turned out great.
mhlmeader
Hmmmm,  I'd say if I had it dialed in better when I was starting on those parts, all them could be done in about an hour, give or take.....I've only had about 4-5 blasting sessions,  and the first couple were the learning curve, a bigger capacity air compressor would definitely make things quicker, but I dont rush at it....after about an hour of blasting, I'm ready to get cleaned up anyway considering having worked a construction job all day to begin with.  I have the parts setting on a cart on plywood,  wheel it out the barn a few feet or so, load up, dress up, and have at it for awhile.
  • Thanks 2
Mikey the Monkey
Great info, thanks a lot:greetings-clappingyellow:
mhlmeader
More sand blasting today. With the exception of the rear rims and a few smaller tractor parts, I think I'm about done blasting for awhile. Kept the roll up door closed this time, less debris in the barn.
mhlmeader
Put the frontsie on the backsie and put two coats of etching primer on, figured I'd better stop before I messed up too badly, reevaluate some life choices and such....
  • Like 8
  • Haha 1
mhlmeader
From what it was, to what it is.....pretty excited to see some new paint on it!!!
  • Like 4
mhlmeader
Pullstart
Are you coming to the big show?  That’s what Putt Putt looked like about this time last year :handgestures-thumbupright:
  • Similar Content
    • RJ Hamner
      By RJ Hamner
      Had just cleaned out the fuel system and thought I'd run it around the block but with the clutch depressed and slack in the belt the transmission pulley still is turning too fast to allow it to go into gear.
      Here is the picture of the setup. Am I missing a part or have I miss installed something?
    • Tyler9014
      By Tyler9014
      I just picked up this 1960 Suburban 400 off of Craigslist. My trucks starter decided to take the day off and I got stranded a hour away from home in Green Bay Wisconsin in the shadow of Lambeau field with my daughter but we got some help from family and got home with our prize. Now I have the transmission torn down and need a spider gear and a shift lever collar. Does any one know if the axle has too much wear to re-use? Any help would be very appreciated. The break lever gear on the shaft seems to have a little more wear on a couple spots than I would have liked to see but I think it is ok overall. (can't seem to get a good picture)
