LengerichKA88
A couple K181 questions.
LengerichKA88
@clueless, I ordered the gasket today, and it’s not even gunna ship until next year!! I couldn’t believe it! So, it’ll be a year before I get to it 😂
I’ve got a couple leads on a full set of engine tins, so that’ll be sorted soon too hopefully. Then we can get em on and doing their job.
moe1965
Before installing your head gasket run a tap down all the holes to get all the **** and crud out of them and might give you a false reading on your torque
oldredrider
Adding, after chasing the threads, blow out the holes with compressed air. Use Never Seize on the head bolt threads.
LengerichKA88
Thanks gents, I will keep all of that in mind 👍🏻
Tuneup
You've come to the right place. If you're 'handy', there is enough information and expertise to get it done on these tractors on this list. I've repaired and rebuilt an 8-speed tranny with this list's help. Great gang. Had your same problem on a 12HP. No top tin. eBay was my friend for that one. Who knows how many hours were spent running it hot! That got me into the engine which is a more familiar area and a nice $120 rebuild. Life is good with Wheel Horsies. Enjoy it - and double check the beer tabs in the fridge.
LengerichKA88
Head gasket came in yesterday, so hopefully some time in the coming week I’ll be able to tackle it. I’ve got the top engine Tin coming in the mail from some mountain man in Maine 😂:ychain:, the front piece that I was “missing” was hiding in the tool box.
Ive got a long list of things to get to, so I hope it doesn’t get shuffled too far down the list.
If anyone would like to lend a hand with rotors, pads, and drums on a HHR, then dive into working in the Horse that’d be great!😂
LengerichKA88
Well, a little behind schedule, but I finally got the head off. This is what I found:
It appears I may have more on my hands than just a head gasket, so before slapping the new one on and calling it a day, I figured I’d post and ask: Where should I look next?
Edited by LengerichKA88
LengerichKA88
Also, if I remember correctly @ebinmaine mentioned that this engine looked like it was built for something else originally, since it has a mix of studs and bolts.
Has anyone ever ever run into an engine like this, and if so: Did you delete the studs for bolts?
I would like to throw all new bolts on it, but I know I can’t just got to the bins at TSC and grab any ole one. What are your recommendations?
LengerichKA88
Some additional pictures
stevasaurus
I think I had 3 or 4 studs in both of my K-181-S.  You need a few to be able to torque the head and then to nut down the tins for the air cooled part.  I would not worry about the studs...just torque the nuts on the studs.
ebinmaine
How was it running?
Good power?
Smooth?
Using oil?
I've seen worse looking engines clean up and run well.
LengerichKA88
2 hours ago, ebinmaine said:
How was it running?
Good power?
Smooth?
Using oil?
 This is the first time I’ve ever done this, so at first I thought this was indicative of a bigger problem.
As far as the studs/bolts go, I’m going to have to punch some holes in the tin I got from @ebinmaine, but that shouldn’t be a problem. I was hoping to do away with the studs for uniformity sake, but I’ll leave em Be.
Other than percolating the oil out of the top, it’s presented no other issues. Doesn’t run rough, usually fires right up on the first turn. I think I’ll get her cleaned up, new gasket, oil change, and call it good.
Ive been using WD40 foaming degreaser and a hard plastic scrapper. Soak, scrap, repeat.  It’s cleaned up quite a bit.
oliver2-44
Remember to sand the old aluminum head flat as described in an earlier post by Stevasaurus.  Since it looks like that gasket was leaking a while I suggest you check the top of the engine.  After you sand the head flat, reinstall it without the gasket and lightly snug all the head bolts and nuts up.  Take a set of feeler gages and see if you can get any between the head and top of the block.  I'll let the pros chime in as to whats too much gap for this type check.  I suspect 0.003 (with out a head gasket) is definitely good, maybe even a little more.  Looking at your picture the top of the engine surface where the head gasket sets looks to still have some carbon on it.. This surface should be clean metal.  You might try some carburetor cleaner to see if it will help dissolve that carbon ( almost any brand will work except the environmentally friendly junk from Home Depot))
If you happen to have the carburetor pulled off, now would be a great time to check and adjust the valve clearance.  Good folks on hear can walk you through it.  If not, it can be done latter without pulling the head.
LengerichKA88
@oliver2-44, I plan on sanding the head down, I just need to find/go get a suitable piece of glass.
The carbs not off, but it can be. We might just go ahead and knock that out too
LengerichKA88
I also just realized: I forgot to mention that the original gasket was still in place in the 1st photo of the original post, here’s how she sits now. Still some gasket material, but I’m going low and slow with this, as space is limited and I’m in no rush to work it.
  • Similar Content
    • Rick3478
      By Rick3478
      For Sale NOS M12S Short Block, still in the original box.  I bought it pre-emptively when Kohler was phasing out the Magnums.  Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap.  Neither of those things happened, the darn things just keep running.
      Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake.  Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
      And it's heavy, so it's not practical for me to ship.  Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
      Asking $800 or might consider trade for a good center mount grader blade.
    • mcfarmall
      By mcfarmall
      Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams.  A starter,  some new gaskets, and miscellaneous parts.  New drive belt and all the belt idler assemblies.  Engine runs but smokes.  Great restoration candidate or a spare engine for you pullers out there.  Call, text or email for a private showing.   No offers considered unless made in person.  Buyer responsible for transportation.  Many more pictures to send to interested persons.
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • johnnymag3
      By johnnymag3
      416-8  clean machine, one owner, M16 Kohler...............no smoke, knocks, etc. Only 771 Hours.
      42" Rear Discharge deck   NO RUST    blades used 1 season
      48" plow very nice condition,
      Wheel Horse weights, on tractor already
      AG Tires on rear,used one season, front tires great condition. Rears are filled with beet juice, done at a Dealer professionally,  ....non toxic, non corrosive.  Traction Galore !!!
      Machine is fully serviced, ready to work. NEEDS nothing....Look below for pictures
      JOHN   845 797 5716 cell
