JoeM
WH Plow Brush Add On
JoeM
A friend of mine gave me this brush that he had mounted on the front of his 48 inch WH Plow. Says he used it because his driveway is gravel and it solved the problem of digging it up when plowing snow. He since paved the drive and passed it on to me. I installed my plow today and brush today, just need some snow to try it out. I'll post the results later.
WHPlowBrush3.jpg.937a36b467c4a5173727f5a9e0fd28ea.jpgWHPlowBrush2.jpg.a257077ae54eb5ca69b241f86abe6b9d.jpgWHPlowBrush1.jpg.7d10ac5a275b34a89b405fbb4eae99ab.jpg
  • Like 5
ebinmaine
Interesting idea.
I'm curious to see how you like it.
wallfish
:text-yeahthat:
Chris G
2 hours ago, ebinmaine said:
Interesting idea.
What he said
AMC RULES
:text-yeahthat:  :text-+1:
 :wwp:
squonk
You'll have an excuse to bring the tractor into the house too! :)
  • Haha 3
MalMac
If that works, it’s a million dollar idea.
The Tuul Crib
Same here!
JoeM
I finally got to use the plow with the brush, worked good. Although we only had 3-4 inches of snow it did push the snow and not much of the gravel driveway.
I didn't have my film crew so I took a pic, I may try to get a video or more pics next storm.
  • Excellent 2
  • Similar Content
    • loudtractor
      By loudtractor
      96-42BA01 plow. Brand new in box. I assembled to make sure all parts were included. Did have to add a trip spring, spring rod, and index rod. Someone "borrowed" them as it sat in the warehouse for 50 years. Box is a bit rough, but I could reinforce it for transport. I will disassemble it, need workbench space.
      Made for (per manual):
      1974 A800,
      1975 A80
      1976-7 A90 A100
      I believe vertical shaft tractors. Maybe others?
      Thanks for looking
      Matt
    • 87buickt
      By 87buickt
      Listing for a friend, late 70s I believe D200 deck and plow. Been sitting for a while, make reasonable offer, friend also has tons of literature he may part with, if Interested let me know
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
    • Nuzmuz
      By Nuzmuz
      Just wanted to show a modification I did to my 1990 310-8. I recently picked up a 36” tiller for my horse and I tried it out on my new garden area. After hitting a rock, it knocked one of the axle brackets open dropping the right side of the tiller. On a manual I viewed, it had clevis pins to hold the lever in, but my bracket did not have them. I drilled a 1/4” hole through on each lever and mounted a 1/4” clevis pin and hairpin cotter to reinforce the lever. I read on another post to just tighten the bolts on the levers, but I think this will work a little better. Hope this helps someone!
