ebinmaine
Plowing snow. How about your tips, tricks and advice?
ebinmaine
I know this subject has been covered multiple times over the years. We have a lot of new members and many of us like to refresh ourselves too.
Please feel free to post links to old posts as well.
So what can you share with everyone about plowin' the White stuff??
Common things like what tires and weights.
Why you prefer a certain tractor. (Please Be kind to others as we have different needs and opinions).
What orange/amber lights are required by your local officials while in the road?
How much space do you save for future snow piles?
Is there anything you found that was unplanned for that the rest of us should know?
Whatever you can / care to share.....
squonk
Plan on fixing 1 breaking / falling off the first time out.
  • Like 5
lynnmor
I don't know of any laws requiring certain lights, but there is the law requiring a triangle slow moving vehicle sign.  We have no dedicated police force in my area, so pretty much anything goes.  I can tell you that motorists will give you no room and it is extremely dangerous with the current crop of idiots.
When making snow piles, move them back at least three times as much as you think you might need, and don't block melt water or you will have a pond.
  • Like 6
  • Thanks 2
Ed Kennell
I plow 4-5 driveways and mailboxes, so I am on the road quite a lot.    And like Lynn said, drivers act like idiots when driving in the snow.
I have  a SMV sign and a blinking pole light in addition to the tractors head and tail lights.
One thing I always do when working near the road is to always face into the traffic lane so I can see them coming.
100_0011.JPG.b992baec4df81265f05bc368219337c4.JPG100_0018.JPG.5a5ff7fb183ba25f4508d046f589d2e5.JPG
  • Like 9
pfrederi
Plow wide...really really wide.
Use a hydro  reverse is much faster...
10 pinion Differentials, steel chains (if you do not have a paved driveway) and as stated weight weight weight.
  • Like 5
ebinmaine
@AMC RULES
I'm loving that grader Craig but that might not be super practical even in my fairly large driveway.
  • Haha 3
pfrederi
I forgot to add a 5 angle position blade helps with keeping the front of the tractor from being pushed sideways...
ebinmaine
Perhaps I'll drill 2 extra holes in the plow frame.
pfrederi
There isn't a lot of metal left if you drill the extra hole in a 3 position frame
ebinmaine
Ahh ok...
pfrederi
9 minutes ago, ebinmaine said:
Ahh ok...
Actually I just went out and measured a 3 and 5 hole frame.  You can do it.  I thought i read somewhere once that you couldn't but I guess the old memory is bad.
  • Like 4
Racinbob
Ya made me go out and look at my blade. Yup, there's room. I think I'll do that next spring. :)
  • Like 4
AMC RULES
Typically, you just replace your sector Eric.
From this...
to this.
See here though...
should be room to just add another hole to your current three hole sector.
  • Thanks 2
Tankman
49 minutes ago, AMC RULES said:
Should be room to just add another hole to your current three hole sector.
Looked at my blades long ago and it appears two additional holes would be OK.
Just never got around to drilling.
Plow often if a lot of snow is forecast. Push the wet white cold junque well out of the way make room for all snow, and then some.
Maybe just move to Key West?  :eusa-think:
Ed Kennell
Whaaat……..and miss all this seat time?       No way.
  • Haha 6
SPINJIM
Anyone have opinions on the TILT of the blade top-to-bottom?   Most WH blades I have seen have the tilt adjustment in the second hole from the top.   But the big trucks that the highway dept uses, don't push the snow.   They lift the snow from the road, and throw it to the side.   I adjusted my 48" blade at max tilt, and found it did a better job on that sloppy snow that we just had.   Along with wheel weights and chains and some momentum, it seemed to lift and throw instead of push.
Also, tri-rib tires or chains on the front help to keep the plowing straight.
Jim
Edited by SPINJIM
  • Like 4
Chris G
I plow a couple driveways and some other areas at my house and I have used a alot of different machines. Last year was 1960 suburban 400 and the year before was a 3 wheeled Copar Panzer T102 with foot operated plow and this year my B140and the list goes on.  The biggest thing Id say is making sure ya got adequate weight and traction. I always have used ags, but keep chains ready just in case. Also find the right gear and throttle range that works for you. And most of all never rush, enjoy the seat time. Plowing snow is probably my favorite thing to do with these old machines.
peter lena
I agree with the idiots on the road, I put a couple of LED BATTERY /BIKE LIGHTS  on my horse ,helped with being seen. they have about 5 different phases, I like the constant back and forth light flash, I am currently working on a rear view mirror. stay safe out there, pete
SylvanLakeWH
Can just use the blade to remove hurricane debris a few times a year...:ychain:
On topic - I run turf tires, no weights, no chains with a 42" blade. Typical Michigan slop to snow on three driveways each year. No problems. All are about 175' long and flat so no grade issues. Key thing - Push it back so there is room for more...:twocents-02cents:
Cetan08
I have a gravel driveway and pretty steep in places. No way I can plow up hill but need lots of weight and chains for traction getting back up. I can only imagine that it would be hard on a Hydro.
Elkskin's mower junkyard
I run mainly sears in snow. This year I got 1 Sears ready to go and 2 wheel horses. I like sears for the 3 point hitch. I hook grader up and grade snow if its only 3 to 4 inches. Otherwise use dozer blade. I haven't used the 552 yet for plowing snow but debating on modifying it to accommodate the adjuster like 753 has. 753 used to have to use carb cleaner to get it to pop off in cold I put new fuel pump on this year on the 1958 k160 bolens engine that's on the 753. So far so good. But I haven't got to use any this year with snow lol. I go over my machines several times a year but still get breakdowns in winter lol. I usually pile snow very high in piles.and away where you can put more.
Edited by craftsmanmowerfreak
ebinmaine
Awful flat down there.
Not much for mountain hiking.
Nice and toasty though....
@ebinmaine hehe I decided to do it to 552 lol
  • Similar Content
    • Ifixoldjunk
      By Ifixoldjunk
      So I finally got around to finishing my custom bagger mount weight bracket conversion. It seems to hold weight really well.
      all that really went into it was a few pieces of steel tubing and a hunk of bar steel. The long bolts I used came with the weight off amazon. A Briggs and Stratton 50 pounder. I’d like to eventually find a nice cast weight, but for now this works great!
    • whamm511
      By whamm511
      Can anyone tell me if 23 10.50 12 Wheel Weights will work on 23 9.50 12 wheels?
    • Jack Oldham
      By Jack Oldham
      Hi All,
         I have a question regarding doing an electric mod on my Wheelhorse A800 Ranger. What I wish to do is install some front headlights, rear brake lights, and indicators on all four corners i would also like to install a horn a some point but that can come later. I'm unsure on the best way of wiring this, what gauge wire to use, do I need a fuse if so what ampage and where also what size amp hour battery is best to use if I'm running these additions so i don't drain the battery. I understand more how I'm going to wire the indicators than how I'm going to get the break light to work but really require advice on both.
      Thanks for you time in reading this.
      Jack Oldham
    • Horse's ass
      By Horse's ass
      After 65inches of snow in a few days, my horse keeps getting stuck with the blower.  I’m wondering if the 12in wheel weights sold by craftsman or other manufacturers are compatible with my standard rear wheels on my c161.  Will the holes line up?  Thanks and Happy New Year!
    • Petes Horse
      By Petes Horse
      I've been looking for a while. The bolt holes just line up and the wire is a little tight between the fender and light. No drilling though.
      They were at Rural King. I think about three bucks each. Optronics MC42RS RED  Marker/Clearance.
