Ralph S
All in
Ralph S
Well I decided to make a weight bracket to hang more weights on the rear of the little puller after Saturday's pull.
  • Like 4
Ralph S
I installed a front bracket too so that I can juggle weights where they are needed
Spareparts
We cannot have anything on the rear that will interfear with chain hook up, so what I did was where you welded the tubing
to the pan mount was drill a 1" hole thru there and hung about 40 lbs. of barbell weights there. No interferance and that really helped
Daron1965
Looks good Ralph.  Looks like the pulling bug bit you. :greetings-clappingyellow:
I would really like to start a pulling league in our area.
Ralph S
I relocated the battery and fuel tank too. LOL the things we do to stay occupied
Ralph S
I'll bee at 1500 lbs. Weight class now. I changed up the weights in the front to the same style like the rear so I can balance it out to keep the front low while it's pulling
Daron1965
Looks good.   :happy-bouncygreen:
Ralph S
How can we go about doing this ? Do you think there are enough people around who would go for it ?
Daron1965
I already know of numerous people in the area that are interested. I have been in talks with a local volunteer fire department that already do truck pulls 2 times a month to add a garden tractor division. We have contacted national quarter scale about regulations and class divisions. I'm trying.
Daron1965
Ralph,  how is the build going?
Ralph S
I've got the rear weights on. I'm ready for big knob and Portersville.
Ralph S
Daron1965
How much weight is on the back? Looks like it is easy to adjust.
Ralph S
38 pieces at 6 lbs.each. all I need is a 1/2" wrench to adjust the weight
Ralph S
This will put me at 1500 pound stock
Ralph S
I just picked this 520hc up yesterday and had it running and driving today
Daron1965
What are your plans for it?
Ralph S
I found a hitch and a bottom plow for it and plan to use it for plowing and disking. Who knows ? maybe make a litttle side cash with it plowing gardens.
Ralph S
My next project is a 518-H. It has something wrong with the transmission but I'm working on it now. LOL ! My work is never done but I have fun doing it. If it proves to be too expensive to fix, I may take the Onan engine out of it and put it in a 310-8 chassis and make another puller with the spare parts.
Ralph S
I'll have to get your number off ya. I seemed to have lost it with the transfering of a new phone. Mine is 724-650-2016 if you want to talk in real time.
Ralph S
the 310-8 is in the 1500 lbs, class
Ralph S
Big Knob starts on the second Saturday of April. I'm pretty sure the fun starts at 1pm.
Ralph S
Right around 230 lbs
Ralph S
Do you have pictures of the weight hanging there ?
Spareparts
No. I do not at this time, but what I done was drill thru the seat upright's about half way between the diff to the seat pan and
used 1" round bar thru the uprights. The bar was long enough to hang the weights, 3 on each side between the upright's and the tires,
The solid bar weight right at 5lbs. and I could squeeze 2 more weights on there but it would be tight I hope  I explained it well enough and I will take some pictures
and try to post some up when I figure out to do it. Right now the tractors are in hibernation but it will soon be time to wake them up.
Our pull season starts June 1st and we have 20 pulls scheduled for this summer, gonna be busy.
