D_Mac 8,214 #1 Posted November 1, 2018 (edited) Chance to buy this single stage snow blower attachment but not sure if it would fit my 308-8 or not. The owner dosnt know the model number but says it is close to a 6-211 or st4201 but he can not be sure. He said it was mounted on a 1971 Raider 12. That and these photos is all I have to go by. Lets say it would fit my 1986 308-8. Does the Magnum 8 pack enough ponies to make it all worth it? Upstate NY we get our fair share of snow. I already have a beast of a snow blower that gets the job done. I can buy the attachment for 100 bucks. Value any of your thoughts on the matter. Thanks Edited November 1, 2018 by D_Mac bad photos 1 Share this post Link to post Share on other sites
pfrederi 17,129 #2 Posted November 1, 2018 (edited) You may need to modify the mounting frame or get a different one. Hard to tell from you picture but is there a welded in rod near the end of the mounting bracket (Circled in BLue) or just two holes that would accommodate a long bolt. For your tachmatic you need the shorter bracket with the welded in rod. The second two pictures show the difference you need #3 I think you have #2 Edited November 1, 2018 by pfrederi 2 1 Share this post Link to post Share on other sites
pfrederi 17,129 #3 Posted November 1, 2018 8hp will get the job done but it will be slower than a bigger hp unit. However sitting down on a tractor is easier than horsing a big walk behind around... 3 Share this post Link to post Share on other sites
D_Mac 8,214 #4 Posted November 1, 2018 Great photos explaining what I need. Thank You. I asked the seller for more pictures. Those are the chains for the tires that are covering the mount in the sellers photos. Like I said I have a 10 hp Husqvarna that I use. I would rather have a blade for the 308-8 but I have not stumbled across one yet. I would imagine I would need the same type of mount for a blade as I would for the snow blower. Share this post Link to post Share on other sites
midpack 804 #5 Posted November 1, 2018 5 minutes ago, D_Mac said: I would imagine I would need the same type of mount for a blade as I would for the snow blower. no, you need a rear axle bracket to use a plow, 1 Share this post Link to post Share on other sites
pfrederi 17,129 #6 Posted November 1, 2018 $100 for a working blower and chains is good deal. The bracket you could modify yourself or pick up one used for small $$ Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,488 #7 Posted November 1, 2018 Here is a list of the models. They are 37" wide without the wing extensions which make it 42". Should work well without the wings in deep dry snow. Snowthrower DNA All have 2 idler sprockets for the drive chain. 1966-67 model ST-376 1968 model 6-1211 1969 6-6211 plus 6-9111 1970-72 model 6-6212 plus 6-9112 All without front quick hitch so not a direct fit for 1973 and later tractors. ------------------------------------------------------------------------------------------------------------ Front quick hitch introduced 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank handle) 1976 model 6-6215 - This one - 1976 model 66-42ST01 - and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - This one 1978 model 86-42ST01 - and this one 1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) Garry Share this post Link to post Share on other sites
Ed Kennell 35,629 #8 Posted November 1, 2018 5 hours ago, pfrederi said: $100 for a working blower and chains is good deal. The bracket you could modify yourself or pick up one used for small $$ Yep, that is a bargain, and you may be able to trade the blower for a plow. BTW, it is possible to mount a blower with that frame mount adapter kit on a tractor with a front attach-a- matic. You do have to trim about 1/4" off the front of the two ears to clear the bracket support bar. Personally, I prefer the frame mount. I feel the geometry is better with the longer pivot point requiring less force to lift the blower and allows a higher lift than the shorter attach-a-matic mount. 1 Share this post Link to post Share on other sites
D_Mac 8,214 #9 Posted November 4, 2018 Well as it turned out it was the wrong mount. PFREDERI was right on with his photos. I passed on the set up even though it is a good deal. Thanks to everyone for the help. Share this post Link to post Share on other sites
