ebinmaine
To tube, or not to tube... That is the question !
ebinmaine
Given the fact that I have nearly new or new tires and I want to install them and inflate them is there an advantage or disadvantage or pros and cons or ups and downs or goods and bads....
To using tubes.
The reason I want to use them is that it's just plain easier in some situations because of not being able to seat the bead properly with a low-volume compressor.
Ladies and gentlemen, what be your thoughts?
JAinVA
I tend to always install tubes.It seems to make seating new tires easier.I know others here may not agree but since you asked.JMHO
pacer
Shortly after I started getting "horse fever" buying them sitting out in fields, back of barns, etc and discovering the - usually - rusted, pitted rims and quickly decided that a relatively inexpensive tube was THE way to go! Occasionally when I have a difficult tire mount facing me and I am gonna go to the local tire place to get them installed I'll let them go ahead and inflate the tires -- on a reasonably clean rim!
Ike
To using tubes.
I put tubes in the front tires on my Kubota bx1500 because Kubota small wheel and tires just plain leak!  I also keep a 4 way hydraulic plow on the front year round which is pretty heavy.  The tires have yet to need air.
I also bought a small bobcat 310 skid steer that had four flat tires.  The current owner said I needed to replace the wheels because they were bent and would not hold air.  I just took the tires to a tire shop and had tubes put in and used it for 8 years without a problem before I sold it.
Tankman
I like tubes. Easy.
In my opinion, best if using fluid filled tires. :handgestures-thumbupright:
Herder
Well your right seating the bead can be a pian. The smaller the tire and the more plies they are the more difficult they can be. Using tubes means a having to remove them in order to patch a hole. It is more work.
Tire pugs make flat repairs quicker and easier.
pfrederi
New tires an decent rims no tubes why spend another 12-17 dollars.....  However I have  lot of old somewhat cracked tires and less than perfect rims...they get tubes.  A cargo strap around the tires helps with seating bead on new tires  or  a bead cheetah.  Finally got one faster than cargo straps
20 WHs = 80 tires plus a few spares.  3 tractors=12  2 military vehicles= 9 assorted hand trucks, pumps generators etc. wheel barrows etc another 12 All together over 125 tires cannot afford all new ones plus add on some neighbors.  Add some nasty black locust thorns and i do a lot of tire work
Edited by pfrederi
953 nut
I have found that a bit of tire lube and a ratchet strap around the tire will make bead seating rather easy. If the new tires were shipped wrapped up where they are sort of deformed it helps to set them out in the sun with several pieces of wood the width of your rim positioned between the beads. As they warm up they will regain proper shape.
SylvanLakeWH
Tubes...
:twocents-02cents:
roadapples
Exactly...I hate having to remove tires to fix them. I've plugged plenty without even removeing them. I only use tubes if there's no other way. I have a plug kit in both my trucks.....
Tractorhead
I use Tubes, because if i get a stiched tyre, it can be both simple repaired but In case of a rip or a small cut, 1-2 cm,
a tube can be quickly changed, then you won some time to get a new Tyre.
My Rims are also very Old and they last still, but they had a lot of Rust, Ok, i removed the Rust, but i am not sure, the Tyre will keep the Air and i don't like to work with any Sealant. With Tubes i can be sure, the Tyres keeps the Air.
Independent on each cons, at slow speed Tyres, i allways work with Tubes.
WVHillbilly520H
I try to install new tires without tubes but no avail the last 2 pair of front tires on the 520s have slow leaked that I must pump every other week, from now on they will get tubes from new, just my opinion, Jeff.
ebinmaine
23 x 8.5/9.5/10.5 x 12
I've been pricing tubes online and at local stores and finding huge variances in price.
Where do you guys buy yours?
pfrederi
Amazon
Pullstart
Best way to load a tire is fluid, best traction adder in my mind.  I vote tubes.
  • Similar Content
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • PWL216
      By PWL216
      Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
    • heysavoy
      By heysavoy
      I have a 1990 wheel horse classic model # 31-12KE01 and need to replace all 4 tires. The sizes are 15x6 8 NHS on front and 23x9.5 12 NHS Rear. I'm wondering if anyone has any specific tire they have purchased and found to be reliable? I have an acre yard with a few hills but nothing severe. I've looked at Carlisle, Marastar to name a few. Also do most folks keep the same rims and take them all in at one time to a local tire garage to have them mounted or just buy new ones with rims? Is having the correct size shown above all I need in order to make sure its an exact fit for my tractor?
    • UrbanAcre
      By UrbanAcre
      Hi,
      I just bought my first ever tractor - 1989 520H. One of the front tires has a slow leak, and they are both showing signs of age, so am looking at buying new. When I look at some of the options on the Miller site, they have 3 basic types of tires as options in the 16x6.50-8 size ..
      circumferential ribs (either equal sized or central rib larger diameter) ag style chevron 'super lugs' turf tire - quadrilateral overlapping treads
      What are the considerations for considering these different tire types ?
      The current rear tires are turf type, no weights, but with chains.
      I have 1.5 acres, quite hilly, and am using the tractor for some mowing, tilling, and garden plowing.
      Appreciate some perspective, suggestions.
      Regards.
