Blackhood Bill
C-175
Blackhood Bill
Ok folks here we go again. Looking at a C-175 non running, needs battery, needs starter, what would anybody else offer someone for it. Asking $250, this would be a restoration project. Just looking for what everyone else would offer/pay.
520hC-120
I would definitely pay 250 for that. Any pics?
Blackhood Bill
Pics of horse with asking price of $250 here is also the verbage from the for sale ad
Wheel horse tractor for sale. Good parts machine doesn't start needs battery and posible starter. Many good parts has new 23x10.50x12 tire on rear, new air filter, has rear vacuum (some parts missing), KT17 Kohler engine, pistons move up and down, good seat no tears etc., etc.
Achto
21 minutes ago, Whnewone said:
KT17 Kohler engine
Do you know if this is a generation 1 or 2 ? If it is a gen 1, I would look for a different engine. Some may disagree but I don't think that a gen 1 is worth much more than scrap price. The
Gen 2's had an oil pump and were much better engines.
953 nut
If this is the model you want it sounds like a good project starting point. If you are only buying it because the price is low you may be disappointed.
Blackhood Bill
Don't know what generation it is. I'd rather have the hydro since this is just a gear. It's low priced and this would be my first project so I thought what the heck why not.
Pollack Pete
Buy it.You don't see them for sale very often.I've paid a lot more for a lot less.I've got 2 or 3 of them.Keep them full of oil.Try to keep off slanting hills for any length of time,and I'm sure if it's a series 1,it will be fine.Thought one on mine needed a starter when I got it.Rodents had gotten under the tins in the starter area and had everything jammed up.Disassembled , cleaned and lubed the starter and it's still OK.Good luck.Maybe offer 2 hundred??
Edited by Pollack Pete
midpack
That's a series 1 kt17
bo dawg
That is a Series 1 engine.
I love mine.
midpack
No muffler, rear PTO belt guard and belt is missing. Check for the Pullies and bracket to drive the leaf sucker... should be behind the right rear wheel
AMC RULES
Love mine, thing is a beast. :eusa-clap:
  • Similar Content
    • Jayzauto
      By Jayzauto
      I have a WheelHorse C-175-8 with Rototiller attachment. Machine is in great mechanical shape, just needs paint.  Engine has been replaced with an identical Kohler KT-17 Series 1.  New Carb has been installed.  Battery, solenoid and cables have been replaced, starts great.  Installed new Tires and Tie Rods.  Installed radial bearings in spindles, so it steers beautifully.  Fuel line has been changed, as well as headlights.  Bew mule drive and belt fot tiller and functions as designed.  I'm sure there is other items that have been done.  Very reliable machine. $800/BRO
      Selling all my WheelHorse items and moving South.  Have other tractors ad parts if interested.
    • Bill Winn
      By Bill Winn
      For sale. 1981 WH C-175 Kohler twin series 1
      1. Tractor has brand new ag tires all the way around, brand new seat, new points and condenser, new rear blade quick attach bracket, lights have been rewired with LEDs, it has a brand new lift cable and bracket,seat pan is from a 410... it's surface rusted but at least it isn't busted up like the oem plastic one, starts and runs but smokes a bit on startup if it's been sitting for months but she runs smooth and strong.
      2. Tiller is like new. It had been used only about once when I bought it and now it has been used 4 times more. Tines still have much of the factory paint on them.
      3. 42" mower deck works perfectly, 4. snow blade was/ is rough but I repaired it so it is quite functional,
      4. Brand new rear grader blade,
      5. Wheel Horse brand plow,
      6. Wheel Horse brand disc- I added a piece of motorgrader blade for a drag. I also welded a post to the top to hold weights,
      7. Wheel Horse brand cultivator,
      8. Home built furrower. (Makes good rows)
      The original Wheel Horse plow/disc/cultivator originally came as a modular kit and in order to use it the draw bar and clevis hitch had to be swapped back and forth. (big pain) I fabricated draw bars and hitches onto each piece so this is no longer necessary.
      I think this is a fair asking price at $2200 for all.
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • Foxer14
      By Foxer14
      My grandfather is selling his C-175 and I want to buy it from him to restore it. He thinks he can get about $3000, but I think that is too high. It does come with a mower deck that is probably to rusty to use and a tiller. He says the tractor has lots of accessories on it. It will need some work as it hasn't ran in probably 15-20 years. I was thinking about $1000 but I am not sure. What do you think?
    • Josh Opitz
      By Josh Opitz
      I have redone most electrical components and fuel of this kohler K341. new spark plug, coil, starter, battery, rectifier, Carb, rewired, but i have not done points. it starts up great idols fine. when I turn the throttle up it rises up to a certain RPM then starts to seize and puff black smoke and the throttle on the the carburetor jumps. Someone had told me it is backfiring and said i need to adjust the my air to fuel ratio. started messing with the governing arm and spring and thought it was helping but hasn't fixed it. any suggestions?
