Willhaven
WH 211-5SB Air / Gas Filter
Willhaven
Trying to find the part numbers for my 1989 211-5SB air filter and gas filter. I was able to find the old part number for the mower blade (111144) which I cross-referenced with the Toro replacement but can't find filter info.
Thanks!
gwest_ca
Here is an illustrated parts list . There are 2 pages showing 4 different assemblies. I will guess you can pick the correct one.
If you can't determine the required part let us know.
Garry
This should be the same 2 pages
https://www.partstree.com/parts/briggs-and-stratton/engines-250000-xxxx-xx-to-29z999-xxxx-xx/253707-0406-01-briggs-stratton-vertical-engine/air-cleaner-grps_1/
https://www.partstree.com/parts/briggs-and-stratton/engines-250000-xxxx-xx-to-29z999-xxxx-xx/253707-0406-01-briggs-stratton-vertical-engine/air-cleaner-grps_2/
gwest_ca
Once you determine the original part number you can search for after-market replacements but you likely knew that.
And thanks for posting the model information. That makes it so much easier for us to provide assistance.
Garry
Willhaven
Got the air filter - thanks!
  • Similar Content
    • wheeledhorseman
      By wheeledhorseman
      Operator manual #810296R1
      4 pages 848.00KB
      2 pages 171.30KB
      Fits
      1983 B-Series and LT-Series See Product Service bulletin
      1984 B-Series and LT-Series
      1985-1986 200-Series
      For vertical shaft 200 series models 1985 onwards but was also used with 1979-80 B series models (supplied with different lift rod) Fits for example B-165 or 216-5.
      Dozer 1983 42in model 06-42BB02 Complete
      1983 serial numbers that have shown up for the 06-42BB02
      19345
      20452 - Build date 1983 3259 September 16 Friday
      20551 - Build date 1983 3259 September 16 Friday [259] Guess
      Dozer 1984 42in model 06-42BB02 Complete
      1984 serial numbers that have shown up for the 06-42BB02
      23294 - Build date 1984 4193 July 12 Thursday
      Dozer 1985 42in model 06-42BB02 Complete
      Dozer 1986 42in model 06-42BB02 Complete
      Link to service bulletin
      http://www.wheelhorseforum.com/files/file/469-wh61-90-315-snow-equipment-1982pdf/
    • Willhaven
      By Willhaven
      Does anyone know if you can make a 211-5 Single Blade (30”) a mulched or side discharge? I only have the bagging system but would like to mulch (if possible) with my new Oregon Gator Blade.
    • Willhaven
      By Willhaven
      Has anyone tried adding/installing deck wheels to a WH 211-5SB? If so, is there a specific make/model that would work best on this tractor? My lawn doesn't have the most level of surfaces, so adding wheels will save me from multiple scalpings (I think).
    • Willhaven
      By Willhaven
      My second post here, and apologies for a potentially amateur question. I've had my WH for a couple of weeks now and am looking for a manual, video, and/or someone's help here on how to remove the deck. I need to confirm the size of the blade (and replace it!)
      Thanks!
    • Mg181
      By Mg181
      Just spruced up a craigslist special and it has 30 in deck 3530sl02, new blade and lifters bought also (120$!!) And it cuts very low. Even with side handle in highest position it's too close for hot summer lawn. Any way underneath machine to adjust deck height?
