mmmmmdonuts
FEL ladder frame question
mmmmmdonuts
With a front end loader for these tractors how important is a ladder type subframe? Does the cross piece in the front have to connect where the towers are? Can the frame where the towers are just mount to the frame and go back to the transmission or is that cross piece critical where the towers mount? Could it be set further back with the same effect or would it not be the same? I know it is important to go back to the transmission so if you hit something you don't snap the frame, but how critical are the cross members?
953 nut
If the front and rear portions of the sub-frame are not connected you will twist the tractor's frame. You will find that the sub-frame is heavier than the tractor frame and without it the forces exerted by the loader would all be transferred to one point at the center of the tractor.
mmmmmdonuts
Okay so both ends need to be connected at the very front and very rear correct? Not offset correct? Would 2x2x1/4 tube be sufficient or am I better off with 2x4x3/16 tube?
cschannuth
I agree. My subframe dwarfs the tractor frame. I have mine connected to the tractor in 6 separate locations - 2 in the front, 2 in the center, and 2 at the rear axle.
Shynon
Here's the one I made for my 520 it's a copy of a Wheel Horse loader frame. Mounts to the mid mount and rear axle, has connection points to front of tractot for the tower stabilizers.
  • Excellent 3
squonk
My PK loader is all 3/16'"  Use it if you can.
mmmmmdonuts
Okay this is giving me some good ideas. Does it hurt the ladder frame at all if you go vertical and then connect like in Shynon photos? Or is it better right between the rails?
WNYPCRepair
Mine is very similar to Shynon's for my 520xi. I am connected to the mid tach-o-matic, and U-Bolted to the rear axle. I have moved a minimum of 50 yeards this summer alone, and it has held up great. Unfortunately, I don't remember how thick the subframe is. If I remember tomorrow, I'll see if I can measure it, but I believe it is 3/16" 2x2 tubing
Edited by WNYPCRepair
WNYPCRepair
6 minutes ago, WNYPCRepair said:
Mine is very similar to Shynon's for my 520xi. I am bolted to the front, connected to the mid tach-o-matic, and U-Bolted to the rear axle. I have moved a minimum of 50 yeards this summer alone, and it has held up great. Unfortunately, I don't remember how thick the subframe is. If I remember tomorrow, I'll see if I can measure it, but I believe it is 3/16" 2x2 tubing
Nope, 1/4". My build isn't the prettiest, since it was also my first time using a MIG welder, but it seems to be nice and strong.
http://www.wheelhorseforum.com/topic/61940-522xi-front-end-loader-build/?tab=comments#comment-577778
WNYPCRepair
Actually, reading further, I think they are only 1/8", but I haven't had any issues at all.
  • Similar Content
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • PWL216
      By PWL216
      About a year ago I bought a C-121 auto with the intention of using it as my go-to mower. Shortly thereafter I got a great deal on a low hour 314-8.  It ran perfect and had several attachments - it became my new go-to mower.  So, I decided to repurpose the 121 to be a front end loader. After purchasing the build plans from P.F Engineering (which are excellent), I realized I couldn’t build it for less than $2k in material. I decided to look for a used one and found a Thompson TC10 local to me, mounted on an “end of life” 1077, for $1,000.  The loader swap itself was pretty straight forward. The only modifications needed were drilling a couple of mounting holes in the tractor frame, grinding away a little of the loader top frame so the hood opened/closed and welding in a new hydraulic pump mount. I have a few things to button up still and the bucket itself needs attention but it’s fully functional. I also bought a pair of clamp-on pallet forks.
      I also did a “refresh” of the 121. The total project cost is shown below. Roughly $2,300, with just the FEL itself being around $1,300.
      Tractor
      C-121 Auto $500
      Solid engine mounts $50
      Front End Loader
      Johnson 10TC $1,000
      Hydraulic fluid $35
      Spare hydraulic hose $40
      Ignition
      Battery $35
      Battery cables $20
      Points & Condenser $20
      Fuel
      Carb & Gasket $65
      Electric fuel pump $60 (later removed)
      Air filter $10
      Fuel filter $15
      Fuel line $10
      Spark plug $5
      Decals and Paint
      Decals $115
      Paint $30
      Lights
      Headlight Lens $45
      LED Headlights $25
      Rear lights $25
      Misc $200
    • PWL216
      By PWL216
      Howdy. I recently purchased a non-running 1277 with a Johnson 10 Loader from a fellow RS member. I bought it for the loader - to put on my C121, then I figured I’d just get rid of the 1277. Now I’m wondering if I should try and get it running and leave the loader on it. The motor turns by hand. I’ve tinkered with motors but never much more than the basics. The battery that’s in it is labeled 2017, so it probably was in use then.  What’s the easiest option, swap the loader or try and get it running? What would you do? Thanks!
    • Workin_Horses
      By Workin_Horses
      Kwikway loader that is currently on my 520H (Tractor not for Sale) with custom quick attach for switching between bucket and custom made pallet forks. The sub-frame allows it to fit some other models as well.
      I designed and built the pallet forks and quick attach setup several years ago.  Just remove 1 pin on each side to switch implements.
      Forks are adjustable and removable.  2" box receiver built into fork rack
      Also included is a custom rear axle suitcase weight bracket that holds up to 6 of the 43lb weights
      You can bring a tractor and we can install it on your tractor here or bring a trailer and I can load onto a trailer for you.
      Pictured TRACTOR and WEIGHTS NOT for Sale.
    • mmmmmdonuts
      By mmmmmdonuts
      This is more a general question but has anyone used a quick attach system for a GT FEL? I was thinking of adding one to my loader to use start switching between my bucket and forks ( hopefully a blade soon). If you did how did you do it? Did you use the SSQA system? My biggest concern is adding a bunch of extra weight to a GT loader but I really hate swapping between the two. Pictures would be fantastic.
