M i k e
1054A Wheel Alignment Problem
M i k e
Boys, having problems with the front wheel alignment on my 1054a.  Seems as tho the tie rod is about 1/2" or so too short causing the front tires to pigeon toe.  Tore everything apart can find nothing wrong or bent.  According to WH parts diagrams, the 953 and 1054 tie rods are the same part number.  Perhaps one of you good fellas could give me the measurements of your tie rods so I can verify mines the correct length?  Maybe something else Im missing here?
Thanks,
Mike
roadapples
It will steer easier with some toe in...
RandyLittrell
How about some pics? That may help us out here.
Randy
M i k e
Its toe out, not in.
gwest_ca
If the flat bars on the spindle that the tie rods bolt to are twisted at all it changes the toe in big time.
One day I was not paying attention to what was happening in front of me and got one tire up against a stump. The flat bar twisted easier than I expected. A large adjustable wrench closed up on the flat bar was all it took to correct it.
Garry
RandyLittrell
That all depends on fast you are going into the corners!! :laughing-rofl:
Randy
  • Haha 1
pfrederi
Make up some adjustable ones then you can hace any degree of toe in ...(or out) that you want and make up for any bent parts
  • Excellent 4
19richie66
The 1054 has one tie bar that runs across from the spindles. The tie bar “mounts” are the same as the gt14 and are cast iron. If the wheels are toed out, then the tie bar is too short. I’m assuming you have the rod ends screwed out as far as they will go? Someone make a new crossbar for it? Snap a picture please. I’ll measure mine when I get back home.
Edited by 19richie66
Pullstart
Randy
You must be a circle track guy...  :handgestures-thumbupright:
  • Haha 2
pacer
I recently bought a 414-8 and the toe-out was horrible - causing unbelievably hard steering. I had previously made the rods up as Paul suggests and ordered some ends off the bay, so while waiting I was digging thru some old worn rods and quickly noticed a half inch difference in them! I had taken them off the 414 so I checked them against the worn rods and found the 414 ones were the shorter version. Loosely mounting the worn longer versions appeared to correct the toe-out about right! So apparently some one had just got some new? rods of the shorter versions thinking they were all the same length.
Since they were all worn badly, I went ahead and made up the adjustable ones - -- what a difference in steering!!
Pullstart
This all reminds me that when I put Putt Putt together, the donor was a ‘64 chassis compared to my original ‘62.  It had two tie rods on it for one side, so I had to cut and turn one.  I ended up with slight toe out that I need to correct by lengthening the cut and re-welded one.  Thanks for the reminder!
roadapples
Pigeon toe confused me....
953 nut
Measured a couple of mine, both were 17 1/2" center to center.
M i k e
Garry
Ok but the 1054 only has 1 tie rod that connects the left spindle to the right one.  There are no adjustment nuts to it at all.  As I said in my OP, nothing appears to be bent at all.
Mike
953 nut
Mike
Even if there is a bent part on your steering arms DO NOT BEND THEM BACK! They are cast iron and will not respond well. You may have to determine what length you need and ask Lowell if he will make one to your specification.
https://www.wheelhorsepartsandmore.com/steering.html#!/Toro-Wheel-Horse-953-1054-Tie-Rod-2711/p/86105616/category=23548038
M i k e
My tie rod has absolutely no adjustment nuts for it.  Its basically a round stock with 2 ends welded on that bolt directly to the spindle arms.  If WH made them with adjustments then that means i've been swindled by a schmuck on ebay who advertised it as for the 1054.  He even gave the correct part number, 2711 if memory serves.  This explains much.  The real trick thing is that its pretty much verbatim of the one that was on the tractor when i bought it, however that one was obviously repaired and welded in the middle making me think that was the problem.  Thats why I never questioned anything when I saw it.  Oh well, live and learn.
Thanks,
Mike
19richie66
Okay. Here is the gt14 tie bar I took off my tractor. Should be the same or very close. Don’t quote me. From end to end, this one is 18-1/4”. From center of stud post to center of stud post is 17-1/2”. If I didn’t need this one for my wifes 1054 frankenhorse I would send it to you. Hope you get it figured out.
953 nut
I have six 953s and none of mine are adjustable either. The ones Lowell makes are threaded and ends are screwed tightly into place. It  is likely that one of your spindles is bent and that has caused the alignment issue. I don't think I would attempt to determine which one it is and try straightening it for fear of damaging it further. Another possibility would be to drive out the roll pin that attaches the steering arm to the spindle and after aligning it drill a new hole, but I doubt that you will be able to drill all the way through and come out the other side at the right point.
Having Lowell make one to fit your needs seems to offer the greatest likelihood of success.
19richie66
The 1054 crate project I have had a non adjustable tie bar but I figured it was homemade the way it looked. Anyone have a picture?
953 nut
I can get you a picture tomorrow.
M i k e
Just ordered one from his website a few mins ago.
Thanks,
Mike
  • Excellent 2
19richie66
There you go!
M i k e
This is the one I have.  If it's not a legit wh part, someone did a good job as it looks the poop.
  • Sad 2
19richie66
Nope, definitely not factory. Can’t go wrong for the price of Lowel’s tie bar.
Shynon
Here's mine of my 1054, not po welded washers around the ball joints. 18 1/4" end to end.
  • Similar Content
    • Pullstart
      By Pullstart
      5 big wheels, in various forms or stages.  One with melted wiring, one runner, one in need of an engine, one full project and one in the middle of nap time.  @953 nut thanks again for turning on my big wheel switch!
    • Pullstart
      By Pullstart
      So, this kind of was destined to show up, I guess.  My wife found it a while back and was trying to buy it for me for our anniversary, but I was already in the middle of helping @Bow_Extreme get a deal on it!  Well, come to find out, he called looking to possible unload it.  SOLD SOLD SOLD!  The color is odd, but it adds character.  I think it’ll stay.  I’m thinking this might show up to Uncle Jim’s Plow day, snowblower engine and all to work the field!
    • 12 hp Kohler
      By 12 hp Kohler
      Got a 953 and 414-8 from Big Red Fred the other day. Got a great deal on both of them. Both run great and I am very pleased with them. Got the 414 for my grandpa and the 953 was just to good of a deal to pass up, so now I got another tractor in my collection
    • Pullstart
      By Pullstart
      This 953 that we have dubbed “Hot Wheels has quickly become a go to tractor for myself... and my kids especially!  The increased visibility, the feeling of a big tractor, the hydraulics, who knows what really makes it so different from the rest.  Now that the Magnum 12 roars to life so easy, it’s that more attractive to jump on and take a stroll or do some chores!
      Here are some pictures from this morning, checking my food plot after some sprinkler time and a few days of good soaker rain showers.  I’ll try to keep this thread active as photo ops present themselves.
