John Deere STX38 Lawn Tractor Repair Series. No Crank, No Start
By
MS GENERAL REPAIR, in other brands
Similar Content
By Rick3478
For Sale NOS M12S Short Block, still in the original box. I bought it pre-emptively when Kohler was phasing out the Magnums. Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap. Neither of those things happened, the darn things just keep running.
Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake. Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
And it's heavy, so it's not practical for me to ship. Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
Asking $800 or might consider trade for a good center mount grader blade.
By mcfarmall
Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams. A starter, some new gaskets, and miscellaneous parts. New drive belt and all the belt idler assemblies. Engine runs but smokes. Great restoration candidate or a spare engine for you pullers out there. Call, text or email for a private showing. No offers considered unless made in person. Buyer responsible for transportation. Many more pictures to send to interested persons.
By Joe Warren
I have a Kohler 301K engine with a Carter carburetor. The engine has always performed very well, but recently has been stalling out after running only a short time. I initially thought it was being starved for fuel. I cleaned and rebuilt the carburetor, replaced fuel filter, and replaced the fuel tank which had some corrosion. I even replaced the Carter carburetor with a new Walbro but I am still having the same issue. I am now suspecting the problem is electrical. What is the likely culprit? Coil? Condenser? Spark plug? Points?
Other?
Appreciate your input,
Joe
By BrianKoch
Hello gentleman,
Problem: will not crank on its own, will crank with jump box—but still not fire
Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
I have my test light out and am probing around.
There is no power at ignition/magneto wire or the ignition/starter wire
There is power everywhere else
