Xearl
Plow trouble
Xearl
While plowing today the spring popped off . I screwed it back on twice and the last time I had to go searching for it . I'm thinking of welding or brazing ,any thoughts ?  I think the ends are cast or steel .
cleat
Never had that problem.
You can't weld spring steel to cast.
You would not want to, the heat would take out the temper.
I don't see how anything could turn and unscrew, is the spring cracked or worn, cast ands worn ?
Maybe take a picture next time it happens.
Sarge
That is truly odd - the way they are made it should not be able to unscrew itself...?
Pics, yes..please.
Sarge
Xearl
PICTURES LATER . I DON'T THINK THEY UNSCREWED I THINK THEY PULLED OUT.
Sarge
Just fyi - all caps is yelling on forums and other places - no offense. If they are simply pulling off , something is wrong.
Sarge
  • Haha 1
Kenneth R Cluley
I have had this issue before, It seems to me the "threads" on the casting get worn and allow the coils of spring to pull off. I took round file to casting to deepen the thread and improved the problem but i'm thinking casting will probably need to be replaced to solve problem.
Ed Kennell
The World's Strongest Bond In the Shop
Sarge
I could see them getting worn if the blade was being tripped constantly - otherwise they shouldn't be a problem. Those castings could be built up and re-profiled by a welder...
Sarge
oldlineman
How about a hose clamp arounf the spring to hold it onto the casting
Xearl
I cleaned out the groves with my Dremel  and squeezed the top of the spring .  I had the idea of clamps so it's nice to see that someone else thought that clamps might work .
Tankman
Had this problem once. A 10 minute fix. Was a piece of cake.
End of spring, squeezed tight with a large water pump plier (Channel Lock pliers). Closed the spring just enough the screw the cast end tightly.
Needed to use two drift pins one on both ends to achieve the proper parallel alignment.
Screwed the cast piece back into the spring. As noted, don't weld; unrepairable troubles. :handgestures-thumbupright:
Xearl
Sarge
I'd have to say those ends are about worn out - how long has it been doing this ? Spring steel is harder than the castings - how does the inside of the springs look ?
The clamp should help as well as tightening up the diameter of the springs on the last 3-4 coils - work your way around slowly and don't create any sharper bends than needed.
Sarge
Xearl
Post sent from my phone sometimes have caps but let me assure you I am not yelling . I can't imagine finding anything to yell about on this site . I thank everyone for their input which has helped me out on more than one occasion .
Sarge
Not sure why so many phones want to do that on forums, but it's odd how some do it by default.
I must say, seen some odd wear on certain parts - but that casting makes me wonder how it got worn down like that. Is the blade in decent shape as well as the frame, or all bent/tweaked ?
Sarge
cleat
Plow looks in good shape from what I can see in the pics but did it spend a lot of time outside ?
Have you plowed a lot of salty roads ?
Just wondering if the cast has corroded away.
Xearl
Cleat & Sarge , I bought the plow in 2001 and used it every year on my shale driveway which is about 250 ft . plus up by my mail box up by the road . I replaced the scraper about three times ,welded some small cracks where the blade mounts to the frame and straightened the blade itself two or three times . When I do these repairs I repaint .  I am not easy on the blade and leave it on the tractor year round since I bought the 523DXI . I have spread 10 wheeler loads of stone dust and top soil .  Salt is not involved in its use .
Edited by Xearl
add content .
Sarge
The casting is somehow just worn out. I use my blades a lot, like grading out full semi trailer loads of rock and have never had one of those go that smooth. In fact, I rarely ever trip a blade for that matter. It could be just a soft casting and once it starts popping off like that it's accelerated to this point - I'd start hunting for a good pair of complete springs and ends to get away from the problem completely. Grading rock is really hard on these blades, they really aren't designed for it and neither is the tractor nor it's frame - you really risk breaking other things when moving rock but we all do it anyway. Just odd that this one wore out that bad and it's an unusual issue to see around here.
Sarge
  • Similar Content
    • Xearl
      By Xearl
      44" Snow blower .  I want to straighten this guard but I don't know if the belt is supposed wind up in front or back of it . In the second picture the guard or guide is just on the other side of the pulley .
    • Xearl
      By Xearl
      what is toro 98-3096 part used for on a bagger . I saw it on ebay .  ED
    • Xearl
      By Xearl
      Well we got the snow  and halfway down the driveway the augers stopped turning . Well once before the belt came off , not this time .  I can turn the auger but the impeller shaft doesn't move . Looking at the parts diagram there are keyways on both gears and I'm hoping one of them sheared off .  Has anyone worked on one of these  ? I could use some advice on the best way to go about this .  I just spent two days with the 518 XI with a plow clearing enough to get out and have enough room for delivery trucks to turn around .
    • Xearl
      By Xearl
      I have a 523dxi with a 2 stage snowblower and I popped the belt off the engine pulley. I don't know how to release enough tension together it back on without taking it apart. Can someone please help me.
    • Xearl
      By Xearl
      I bought this John Deere weight bracket from   doc724  and mounted some weights from and old exercise machine . It's 120lbs. This is on my 523DXI .
