DennisThornton
Rust Removal
DennisThornton
I've killed a LOT of rust in my time from semi tankers to tiny tools with big sandblasters, electricity, abrasives and chemicals.  One of my fondest is Evaporust but I just saw a video that really impressed me:
http://drxcleaner.com/videos/
Anyone seen or perhaps used it?
And if you haven't tried Evaporust perhaps you should.
  • Like 5
Sarge
Interesting. I wonder how it affects paint adhesion on the long term ?
Sarge
roadapples
I'm impressed....
953 nut
I have found that Evaporust will remove light surface rust, but had a few old wrenches that soaked in it for ab week with no noticeable improvement.
wallfish
Cider vinegar works pretty good too but it's not instant results.
JERSEYHAWG /  Glenn
Never saw anything as good as that, thanks Dennis.
Glenn
DennisThornton
Sarge
They have a metal prep "sealer" as well.  I'd think it would then be primer ready.
Vinegar does work! And real good!  And cheaply! But for me only if it's soaked for days.
It's worked on every thing I've tried but seems to get consumed, used up, rather quickly.
953 nut
Dennis, anything that is between metal and primer WILL fail,     in my opinion.
Chris G
I'm impressed.
DennisThornton
I used metal prep prior to priming.  All auto manufacturers do.  Mostly phosphoric acid. Etches, removes any flash rust and inhibits rust until it is primed.
Edited by DennisThornton
Sarge
While it's not always feasible, I do prefer blasting parts to give a proper surface finish for "bite". There are times I can see pores that are not fully cleaned - I just go to a more aggressive grit but get repaid by having to use a heavier builder/primer on the base. Epoxy primers are the way to go , but pricey stuff but it does better seal up the metal and stops migration of rust pores. Now, if a guy did the blasting first, then used something of this nature to remove the rust - and used epoxy primers - I'd suspect that would be ideal . Big difference when you are dealing with old, porous metal versus new steel - you have to take the extra steps to seal up and fill any damage from time and corrosion to the metal . Otherwise, you'll regret it later as it will come back.
Sarge
Tankman
Impressed. May try some, weather permitting. It's 12 degrees out today. Brrrrrrrrrrrrrrrr.  :handgestures-thumbupright:
pacer
I just ordered a gallon --- vids were impressive!
I too like to use 'sand' blasting for the reasons like Sarge mentioned, but what causes me the most time/aggravation is the small parts - nuts, bolts clips, etc. When I really need to re-use these items I go ahead and use the cabinet, but its time consuming (and hard on gloves!) - so I'm hoping this DRZ will help with this part of the restoring.
Sarge
If you're blasting hardware, get a screen tool for holding/blasting small parts - I've made a few of my own out of perforated metal and it really helps to save the gloves. I've been using the Scat brand replacement gloves - they last quite awhile but it all depends on what media you're using.
http://www.tptools.com/The-Original-Skat-Blast-Bolt-Basket,252.html?b=d*8033
http://www.skatblast.com/cabinet-gloves.html
Sarge
classicdmax
I’ve used white vinegar/salt mixture with good results
pacer
Yeah, I had also made a couple - but I was recently poking around wally world and spotted a fine mesh office paper holder - like in/out papers - about 12x18ish and that is really the best so far.
DennisThornton
Of course you will share your results here! It sure looks like it out performs Evaporust.
Vinegar alone works well.  Perhaps it's the most overlooked under appreciated rust remover.  But I've only used it for soaking, like Evaporust.  This other stuff we at seems to work well by just spraying.  That's new to me!
Sarge
That stuff is pretty different - I may pick up some just to de-rust larger pieces of steel when fabricating/welding stuff, would work great for that. I do like that it doesn't attack paints - but wonder if it may remove the gloss if left on too long. There are various methods used by folks to remove surface rusting on painted areas like old cars - some even use household chemicals with some interesting results. For preserving patina - might be interesting if you don't want to paint an original machine, just give it a clear coat or whatever.
Thanks for the heads up - I'm always interested in new products to solve common issues.
Sarge
  • Similar Content
    • Tfarver
      By Tfarver
      This is my commando I just picked up awhile ago. Looks like it was-tried to be a puller. Got it with no motor but have a strong 14 to install. Does anyone know how to preserve the sheet metal but keep the “rust look”. Will be using this unit for small farm chores. I really like the look currently with the rust and wear, kinda tells a story I suppose but I don’t want to leave the Tin “unprotected”. I’ve heard of guys lightly rubbing down the metal with used motor oil?  Any thoughts, comments, concerns are highly appreciated!
    • Ifixoldjunk
      By Ifixoldjunk
      so the whole corner of my 42 rear discharge was completely rotten away. I’ve welded sheet metal before, but I don’t really know what gauge steel is need for a solid repair. I have 16 gauge on hand. Would something thicker be needed?
    • JHorseman
      By JHorseman
      Hey all,
      i recently picked up a Raider 8 and and Charger 12 to add to my small but growing collection. Both need restored including paint and I have never had much painting experience when it comes to auto paint. Can someone give me some helpful tips on prep , like if i need to strip it to bare metal or not and what colors to use? As well as how to mix the paint with hardener and clear coat.
      Thank you in advance!
    • elliot ness
      By elliot ness
      Picked up an old rusted D blade, every moving part was stuck, but after 2 days of heat and PB blast, well here it is. nite mirror over. and of course Nugget our garage cat .
    • DennisThornton
      By DennisThornton
      http://strongarmbrand.com/
      I've used, liked and recommended "Fluid Film" and TC-11 but never tried StrongArm.  Kind of pricey but if it works like this:
      Here's Before and After with 35 year old
        and Restored by a USA fluid User in Daytona
      Anybody used it?  Or anything similar that you like?
      Thank!
