8ntruck 6,358 #18276 Posted January 15, 2023 On 1/14/2023 at 8:21 AM, lynnmor said: I needed to replace a bell, so I bought from a vendor on this site. Turned out that he had in stock two of them with the same abuse. In order to cause the wear on the bell, someone adjusted the PTO till the hoop was pushing it instead of replacing the broken pin.. It seems to be a widespread problem with that pin breaking and that there is no mechanical ability. The fix for a bell worn to the groove is replacement, it would be a project to make a cap to replace the missing metal. Yup, the fix for a worn off groove is usually replacement. However, the C195 uses a conical PTO that is unique to the C195. They are rare enough that doing some machining to repair one is worth considering. 1 Share this post Link to post Share on other sites
GAJoe 813 #18277 Posted January 16, 2023 (edited) 9 hours ago, Lee1977 said: The wear on the end of the coneIs usually caused bt a worn or bent spiral pin in the loop or the c-clip came out of the short shaft. Those c-clip grooves do wear out I have replace the short shaft 2 times in the last .46 years on my C-120. I don't see signs of ware on any other part. I plan on replacing the cone with one from Eric. Then I can change the bearing if needed. Edited January 16, 2023 by GAJoe added details. 1 Share this post Link to post Share on other sites
GAJoe 813 #18278 Posted January 16, 2023 I built a tire changer that mounts in the hitch receiver on my truck, changed a tire, and put it on my C-160. I know that Harbor Freight has a nice mini changer for around $30 or so but our dog had to have emergency surgery yesterday to the tune of over $1200. I had the metal already and time to make it. 6 6 Share this post Link to post Share on other sites
Tonytoro416 952 #18279 Posted January 16, 2023 Looks to work well. Hope your dog is ok now. I recently haven’t had real good luck in that department 5 Share this post Link to post Share on other sites
GAJoe 813 #18280 Posted January 16, 2023 (edited) 33 minutes ago, Tonytoro416 said: Looks to work well. Hope your dog is ok now. I recently haven’t had real good luck in that department Thanks He's home on the mend. He slept well last night. He's moving a little slowly but he's done all of his bodily functions today. Edited January 16, 2023 by GAJoe 1 6 Share this post Link to post Share on other sites
WHX?? 46,683 #18281 Posted January 16, 2023 (edited) Pulled this one out in some work space today. It amazed me and started and ran good. Even took some seat time on it. Got it back in the shop and would barely idle. Putting a Novar ignition on it see if that helps. Wanted this gal to be on on show circuit this year but may go down the road if she don't start seeing things my way... Clinton B1290 and all original. Edited January 16, 2023 by WHX?? 6 9 Share this post Link to post Share on other sites
ebinmaine 62,949 #18282 Posted January 16, 2023 49 minutes ago, GAJoe said: built a tire changer Excellent 👍 2 Share this post Link to post Share on other sites
WHGuy413 2,506 #18283 Posted January 16, 2023 Sorry to hear about your pup. I had one of those tire changers from harbor freight and it was horrible. Yours looks like it works much better. 4 Share this post Link to post Share on other sites
kpinnc 10,678 #18284 Posted January 16, 2023 4 hours ago, GAJoe said: I built a tire changer that mounts in the hitch receiver on my truck I have a Harbor Freight changer, and it works great. But I like how you hold those beads back better than mine! Glad to hear pup is doing better! 3 Share this post Link to post Share on other sites
Horse Newbie 6,852 #18285 Posted January 16, 2023 3 hours ago, WHGuy413 said: I had one of those tire changers from harbor freight and it was horrible. 3 Share this post Link to post Share on other sites
ebinmaine 62,949 #18286 Posted January 16, 2023 6 hours ago, WHGuy413 said: tire changers 4 hours ago, kpinnc said: changer 3 hours ago, Horse Newbie said: We have the larger size manual changer for full size tires. It does work just fine and it's a serious workout too. 😂 The smaller ones I break the bead with the bigger changer, then use levers to remove/install the tire. BIG thing to remember is that the changer MUST be very firmly attached to a solid object like the floor or vehicle. A pallet holding it is an exercise in expletives creation. Share this post Link to post Share on other sites
ranger 1,617 #18287 Posted January 16, 2023 (edited) Sorry to hear about your pup, glad he’s doing better now. I had to use my homemade tyre/tire changer that attaches to the car the other day when I got a puncture, (car, not horse). I couldn’t break the bead on one side, (alloy wheel). Didn’t want to damage the wheel by hammering a tyre lever in. Then I had a @peter lena moment, “LUBE IT”. A quick squirt of the infamous “WD 40”, a couple of minutes later and the bead broke as easy as anything! And I have the proper tyre lube/soap for removal/installation, but it’s not much use until the bead is broken! The spray penetrated immediately. Your use of the clamps is a great idea, I have similar ones, the fixed ends are removable , they just unclip and can be reversed and fitted at the other end of the rail so they push outwards, they worked a treat to spread and hold the tyre walls apart for better access inside for the repair. Doug🇬🇧 Edited January 16, 2023 by ranger 4 1 Share this post Link to post Share on other sites
peter lena 8,035 #18288 Posted January 16, 2023 @ranger glad that helped you out , my regular reference to lubrication kind , is not an insanity , but my view of a long neglected area / spot . another guy just up the road from me , typically has a long neglected lawn tractor , any time I hear a screaming belt drive trying to engage / work , I know its that guy , beating on his unit again , faded rusty paint , barely operates , just don,t understand how you can do that . use a silicone grease on tire mounting , makes for easy on / off . part of the SUPER / LUBE FAMILY . pete 2 Share this post Link to post Share on other sites
lynnmor 6,762 #18289 Posted January 16, 2023 3 hours ago, ebinmaine said: BIG thing to remember is that the changer MUST be very firmly attached to a solid object like the floor or vehicle. A pallet holding it is an exercise in expletives creation. I use a pallet, but then my expletives are up to date. I just didn't want that wart standing in the way for use once per year, and that would need another set of expletives every time it got in the way. 3 Share this post Link to post Share on other sites
ebinmaine 62,949 #18290 Posted January 16, 2023 15 minutes ago, lynnmor said: I use a pallet, but then my expletives are up to date. I just didn't want that wart standing in the way for use once per year, and that would need another set of expletives every time it got in the way. I had that same thought when I mounted mine to the floor but then I got thinking about all the people in the world that own exercise equipment they never use and I just started stacking stuff on top of it. 😂 1 1 2 Share this post Link to post Share on other sites
ranger 1,617 #18291 Posted January 16, 2023 My changer doesn’t seem to mind whether it’s attached to the car or not. But I do sometimes have to put a foot on one of the legs while I pull on the bar if it’s an awkward one and the unit is freestanding. Share this post Link to post Share on other sites
Ed Kennell 35,593 #18292 Posted January 16, 2023 11 minutes ago, ebinmaine said: exercise equipment they never use My local auctioneer sells a couple pieces every week.. He lists them as clothes dryers. 8 Share this post Link to post Share on other sites
peter lena 8,035 #18293 Posted January 16, 2023 @lynnmor my son bought a floor mounted tire changer years ago , been terrific / easy to use . its solid , leverage advantage makes quick work of any tire / wheel situation . bought it on line , pete 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,445 #18294 Posted January 16, 2023 (edited) Now thats good ingenuity right there.Use what you have to make it work. Edited January 16, 2023 by Wheelhorse#1 1 1 Share this post Link to post Share on other sites
ebinmaine 62,949 #18295 Posted January 16, 2023 11 minutes ago, Wheelhorse#1 said: Now thats good ingenuity right there.Use what you have to make it work. One of my favorite sayings and a great way of life.... Use what ya have!! 2 Share this post Link to post Share on other sites
Ed Kennell 35,593 #18296 Posted January 16, 2023 9 minutes ago, ebinmaine said: Use what ya have!! Yep, and go to tha scrap yard to get what ya don't have. 5 Share this post Link to post Share on other sites
pfrederi 17,125 #18297 Posted January 16, 2023 With 20 WHs 3 big tractors and two mil vehicles (lock ring wheels) I have done a lot of tire work over the last 20 years. Had the small HF Changer longer than that. Big HF changer bolted to piece of plywood, Use a KT17 on one end I stand on the other. Pull it out to an open area to use it drag it back when I am done. Have a serious bead breaker for recalcitrant tires... 2 4 Share this post Link to post Share on other sites
ebinmaine 62,949 #18298 Posted January 16, 2023 1 hour ago, Ed Kennell said: Yep, and go to tha scrap yard to get what ya don't have. It's an excellent notion and I do it when I can. Unfortunately the insurance industry here in Maine is more in control of the salvage yards than the owners are so most of them don't let you in anymore. I do have one place not too awful far away that's my first phone call for batteries. 2 Share this post Link to post Share on other sites
ebinmaine 62,949 #18299 Posted January 16, 2023 56 minutes ago, pfrederi said: recalcitrant That's a word that is not used enough in modern society. 1 2 Share this post Link to post Share on other sites
WHGuy413 2,506 #18300 Posted January 17, 2023 We had a snow storm come sneaking in last night. About 2 inches of snow. Aiden took his 856 and plowed for my dad. Alex handled my driveway but I will let him tell you. Aiden also finally installed his stack I got him for Christmas on his 856. It sounds pretty sweet. 1 8 1 3 Share this post Link to post Share on other sites
