Dan693
Thinking about trying a foot pedal throttle on my WH,
Has anyone ever tried it and how did it work out?
Thanks!
rmaynard
Not sure why you would want to. Unlike cars, most engines on tractors are designed to run at full throttle when operating. However, you might want to search in "pullers". Many pullers use a foot throttle.
WHX??
If in I remember right @VinsRJ put one on a tractor just for the halibut. I could maybe see it on a tractor I would use just for fun or pulling tubs around the yard.
Here's a dandy put they can be easily made.
https://mwsc.co/products/gas-pedal
wallfish
For normal tractor use and chores, doesn't make much sense but I did one for a 35 mph hot rod tractor. Worked great too!
oliver2-44
On al large tractor with a loader a foot pedal tractor is really nice to give it that extra umph as you dig into a pile of material as you fill the bucket.
  • Like 4
Ed Kennell
I have a foot throttle on the Crazy Horse.  It works fine for hot rodding, but I wouldn't want it on a working tractor.    I do have foot motion control on all my hydros and  would never go back to hand control especially for blowing and plowing snow in close quarters.
        FOOT THROTTLE PEDAL
                                                MOTION CONTROL PEDAL
  • Like 5
ebinmaine
sounds fishy to me....
Is there a particular reason behind this here thought?
  • Haha 1
953 nut
Unless you are driving on a perfectly smooth surface you would find the throttle would be bouncing around too much. On a loader tractor the throttle over-ride like @oliver2-44 mentioned would be good to have.
SPINJIM
How about a foot control for the motion control lever of an automatic, NOT on the throttle control ?   I have a 1076 with the old stirrup style footrests.  I'd like to be able to steer,  operate the hydro lift for the plow, and control the speed of the tractor without requiring three hands.   Anyone have success with one ?
    Jim
wallfish
Scroll back up to @Ed Kennell 's post #6.
Kurt-NEPA
I have one of Matt's foot pedals on my 95 520H.  I really like it.  Especially when blowing snow.  Much more control with less effort.  For mowing, I like it that I can quickly slow down when needed.  Using that 520H lever on the dash was always a bit awkward.
BTW, I have 2 5xi's, both had foot pedal from the factory.  I like them.
Ed Kennell
I am not familiar with the motion control on the 1076 Jim, but I have added this pedal to all the hydros on my Cs, 3, 4, and 500s.
It is an easy addition to any hydro that has the console mounted lever that can be connected directly to a pedal with a rod, and it works great especially for plowing and blowing snow.
Sarge
To make a foot control on the older style Sundstrand transmission you have to add an arm to the mechanism where the direction control arm is attached to the boxed frame - that's how the original foot control kits were designed. This allows the clutch/brake pedal to still work and independently control the hydro to stop the tractor - but if your foot is pushing on the hydro direction control via the foot pedal mod the two will fight each other and it won't stop. @gwest_ca can probably find the installation sheets for the early version foot controls...? It's tough to describe how these things are engineered, but with the instructions it gives a clearer picture of how they did it.
Sarge
Dan693
A ton of input on my post which is great. Been really busy but I got it done and it works perfectly. I dont mow with it....just plow snow.
Have some test and tune to do when it gets above zero but will try to post some info and pics when I can.
  • Like 5
Jerry77
Is that a homemade rig Ed?...could you provide more pics and info on it?...looks real handy and cheaper by a lot than the bought ones....:)
Ed Kennell
@Jerry77    PM sent.
Cub fan
Dan693, this may not be the place to ask you but you had a post sometime back about sometimes it is better to just do a clean up on an old unit instead of a complete restoration due to time and skill. I want to do that to my unit not sure where to start and what products to use, I read a lot of your article and respect what you have written and done. If you can give me some advice I would be thankful.   Jim the Cub fan and your neighbor in Carmel.
littleredrider
I have a lawn ranger that has foot gas pedal. I don't remember how it hooked up or what was used. In a storage shed at my mother's and never go there much anymore lol. But this was a crazy horse back in the day, it had a 5 horse Briggs alcohol engine on it and guess would flat out fly.....
VinsRJ
I put a foot throttle on my 857 project, I will have afoot throttle on all my non-RJ projects going forward, love it!
AMC RULES
So, a Senior with a foot pedal...
 :think:  that'll be different Vin.
VinsRJ
SR is going to shift on the fly...
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range.
      Thanks,
      John
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Little Red Horse
      By Little Red Horse
      I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
      It has AG tires and a mid-mount blade from wheel horse.
      It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection,  not sure. Although there's not too much that goes wrong with them.
      The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
      I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
      Please contact me by text or email.
      Thanks for looking!
    • ohiofarmer
      By ohiofarmer
      i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
        I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
      You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
      i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
       Tell me what you are seeing out there and what you think.
           Edit:  Jay and I ran up to buy Bob Ellison's tractor in MI.  Bob was very nice to deal with and included his "last seat"   I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
    • Donavon
      By Donavon
      Just curious what is the heaviest for a future project.
