Similar Content
By Rick3478
For Sale NOS M12S Short Block, still in the original box. I bought it pre-emptively when Kohler was phasing out the Magnums. Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap. Neither of those things happened, the darn things just keep running.
Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake. Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
And it's heavy, so it's not practical for me to ship. Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
Asking $800 or might consider trade for a good center mount grader blade.
By mcfarmall
Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams. A starter, some new gaskets, and miscellaneous parts. New drive belt and all the belt idler assemblies. Engine runs but smokes. Great restoration candidate or a spare engine for you pullers out there. Call, text or email for a private showing. No offers considered unless made in person. Buyer responsible for transportation. Many more pictures to send to interested persons.
By BMW1
I would like to replace the spark plug wires on a k482 engine.
I believe the original wires are 7mm solid copper core.
Can 8mm spiral core wire be used instead or should I use a solid copper core wire?
The reason I ask is because the crimper I ordered a while back only has an 8mm die for spark plugs and a 7mm die is not available for the crimper.
It doesn't seem like 8mm solid copper core wire is available?
Also had trouble finding the boots and connectors for the coil end - anyone have some suggestions?
Thank You.
By Jennifer
Husband wants some advice… lol. So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running! The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice??? It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky.. checked the gap and pull again… same thing over and over! Thanks in advance!
