Spokane Dave
1961 Wheel Horse Suburban Followed me home to get freshened up
Spokane Dave
So I am curious if anyone has any suggestions for getting the Embossed wheel Horse letters on the front of the hood white.
Obviously freehand painting is the answer, but I am NOT a good freehand painter.
I tried first off  to paint the letters white / mask off to then paint red, and remove masking to uncover white letters, but that failed miserably.
Just curious if anyone has any tricks . . . . .
JPWH
A wide paint marker works best for me.
Spokane Dave
Hmmm
Good idea wonder if the crafty wife has one of those...
Edited by Spokane Dave
wallfish
If you could freehand cut the tape that perfect, there's no reason you couldn't freehand paint it. :ychain:  :hide:
  • Haha 1
Spokane Dave
 :kbutt:Good point, but that was one of the issues:ranting:  .... was going good cutting with exacto blades :violence-blades:, but went bad fast, so I decided to bag it :deadhorse:
  • Sad 1
Sarge
A flat piece of rubber and some of that acrylic artist's paint in a tube and a plastic scraper . Put a dab of paint on a clean , thick piece of rubber - then smear it out with the plastic scraper . Those body filler applicators work good to smear the paint - takes a bit of practice to get the layer of paint just right on the rubber but it works great to do raised letters . I did a plastic dash that way , works sort of like a stamping pad but hard enough to only touch the top surface . Get the paint too thick and it will look uneven - you can always let it dry for a bit and apply a fresh coat . Round surfaces are the hardest but it's still easier to use a pad than to paint it by hand . I've done this with spray paint as well , just a few light passes onto the rubber but you have to be quick to transfer it to the letter/raised portions . Just make sure that rubber is clean and find something to practice on - that acrylic stuff will spread a lot if you try to rub it off and make certain it's compatible with whatever other paint you're using as a base .
Sarge
Chris G
I usually use the paint marker as well. cause i dont have the steadiest hands.
wallfish
I was just mess'n with ya Dave, couldn't help it. I actually tried that method too and didn't make it past the  W
WHX??
I am too so I got the best idea here Dave ....get one of your :wh: bro's who's good at it  to do it for you!
  • Like 4
Spokane Dave
Sarge
Now thats a way that I did not consider :think:
Okay so two for paint sticks :text-+1::text-+1:
:teasing-poke: no worries the old skins still plenty thick and I have a great sense of humor :teasing-neener:
Been rackng my brain but unfortunately my 3 old painter buddies worthy of doing it are all dead :confusion-confused:
ACman
Thumbs up for all the above but the last remark...that sucks :( .
Spokane Dave
Yea that's a profession that almost guarantees early cancer in life, but these were all old school painters who may or may not have used respirators etc as is standard these days ..... still sucks none the less, as they all died in their 40's
  • Sad 1
Spokane Dave
I did pick up a new  wear bar for the plow blade today, so all that is left is fitting / cutting it then paint it and the lift linkage I forgot the other day and I can get it all out together.
I do do need to go get some plugs for the dash holes as well - in hindsight I should have tigged them shut but early on thought I might utilize them
Spokane Dave
Curious if anyone knows the actual volume / amount of gear lube that goes in the rear end - I know the fill process just curious if the actual volume is known ?
Racinbob
I go by the lubrication chart Wheel Horse way back. They also stated that "Some lubricant recommendations have been updated and will not agree with the owners manual". Basically that's 1 1/2 quarts in the 3&4 speeds and 2 quarts in 6&8 speeds. I haven't pulled an overflow plug in decades. :)
Edited by Racinbob
WHX??
Thanks Bob handy file to have. :handgestures-thumbupright:
Spokane Dave
Thanks Bob that's what I needed :handgestures-thumbupright:
JERSEYHAWG /  Glenn
That is turning out really sweet. Nice job on her.
Glenn
Spokane Dave
:happy-wavemulticolor:     :greetings-clappingyellow:       :happy-wavemulticolor:
I found some midnight oil time so I stoked up the fire in the garage the other night, and the old girl is purt-neer completed - :think: Still need a couple hole plugs for the dash, and still need to get a safer pulley for the motor output.
:bow-blue: Proudly displayed the high quality decals from Vinylguy (Thanks Terry) where they belonged, and I decided to Use the cheap :roll: Fleabay decals for the plow face and cut the other up for the back.
:think: The crappy old little plow came out better then I expected after :tools-hammerdrill: putting a wear bar on it (never had one before) - :text-bump: I threw in a pic of the lift linkage/ mechanism I made and forgot before.
:scratchead:I decided to paint the wear bar on the plow white to accent the wheels - Waddayathink ? :twocents-mytwocents:
:confusion-confused:  So I have a question for all of you . . . . . . . I know people name there horse's - Do you guy's name your wheel horse's? :confusion-shrug::confusion-shrug::confusion-shrug:
While admiring / marveling in my restoration results this evening. . . . . . :techie-eureka: I was thinking this old Girls name should be "PURDY" The Wheel Horse :dance:
Well enough yammering :hilarious: . . . . Here are some more pic's for your viewing enjoyment  :hilarious:
  • Like 8
SylvanLakeWH
:bow-blue:
WHX??
Didn't know if I was gonna like the frame stretch but looks good now. :handgestures-thumbupright:  Not a big fan of the wheelbarrow fronts tho they might skid too much?? What's your thoughts on the rears being backwards? Better in snow?
Spokane Dave
Thanks . . . . .There was a bit of a snaffu in supply when I went to get the front tires, so I settled with the WB fronts - I to was thinking they may slide steer, so was thinking of whipping out some mini chains for the front.
As for the rears . . . just a 50% chance of mistake (it was Eye crossing late when they installed) and had not noticed  . . . is there really any difference / benefit to turning them backwards ??
RandyLittrell
Suburban looks good! I like that you took what you had and slicked it up while leaving the old modifications. All restored tractors just look alike!
Randy
ol550
My dad always ran the tires backward on the combine, where you couldn't go you could back out of.
Spokane Dave
Well I thought I would let you all know "purdy" the old wheel Horse went to her new owners today who anxiously and happily handed me 25 Crisp 100 dollar bills for her.
:banana-rock::banana-blonde::banana-dance::banana-tux::banana-wrench::banana-guitar:
Now I am on the hunt for my next victim :violence-blades:
