formariz
Early RJ tank support
formariz
Can someone provide me with some good photos of the early RJ tank support?
Unfortunately  it seems that all existing photos have disappeared due to Photobucket's greed.
rj35hunter
I can provide you pictures and dimensions if needed when I get home tonight.....
formariz
Thank you . Dimensions will also be greatly appreciated.
rj35hunter
Flat stock going up from frame to stand is 10" long 3/4" wide 1/4" thick. Piece going front to back is 10" long 1" wide and 1/4" thick. 2 pieces going side to creating the bottom for the tank are 6" long 3/4" wide and 1/4" thick. Let me know if you need any different pics etc
Clay
formariz
Perfect. Thank you very much.
Does tank in that system just rests on supports, or is it also strapped to same?
What year tractor was this frame in?
Edited by formariz
rj35hunter
Your welcome. The tank sits on the bottom pieces and a strap Ins around the tank....this is my 1955 RJ25 which doesn't have the tank. I used this one so it will show the pieces better. This framing for the tanks should only be in 1955 models.
