Joel G
Mower deck options for C-100
Joel G
Hi, I'm brand new to the forum and just brought home (last night) my first Wheelhorse tractor.  It's a '75 C-100 and it's in great shape.  Unfortunately it did not come with a mower deck and so I am looking at my options.  As far as I can tell the 5-1011 is the OEM for a 42" side discharge deck.  I was, however told that both side and rear discharge options were (or are now) available.
That said, I would love to find a used 42" mower deck that fits my tractor, however I am not sure how to properly ID it if I come across one.  Would the model # be 5-1011, and if so would it be stamped on the deck?
I have also heard that new ones can be bought through Toro, however I would rather not spend thousands on an aftermarket mower deck if I can restore an original for less $.
gwest_ca
Welcome to the forum
The 5-1011 was the 42" SD deck sold in 1975 for your tractor. Notice it used blades with a 5/8" x 3/4" double-D center hole which are next to impossible to find now. Later decks used blades with a 3/4" center hole.
Here is a list of the decks in the order they were produced
5-1001 replaces RL-426, 5-1421, 5-1422, 5-1423, 5-1000
5-1001 replaced by 5-1010, 5-1011, 5-1012, 65-42MS01, 65-42MS02, 75-42MS01 (Blades up to this point had a 5/8" x 3/4" double-D center hole)
(The following decks used blades with a 3/4" center hole) 75-42MS02, 85-42MS01, 95-42MS00, 95-42MS01, 05-42MS01, 05-42MS02, 05-42MS03, 05-42MS04, 05-42MS05, 15-42SC01, 15-42SC02, 15-42SC03/78345
& 85551 front hitch
Decks all had an ID plate or decal with the model number and serial number on them but most end up lost or unreadable.
All the 3/4" blade decks look almost identical with subtle design changes for improvement.
Familiarize yourself with what the hardware on top of the decks look like and find out what model tractor used the deck. The C-Series and the 300, 400 and 500-Series tractors all used the same decks.
The front belt idler assembly that connects to the front quick hitch is part of the deck so get that also.
Garry
Joel G
Thank you very much Garry.  If I did decide to order a new deck from Toro, then would then be able to order any of the ones you mentioned with 3/4" blade holes and expect it to work on my tractor?  Is there one model that you would recommend for my tractor?
Are the Tacho-O-Matic assemblies the same for all?
Thanks again Garry.
Joel
BTW, I was told by Toro that the 5-1011 was made for only one year and that Toro no longer makes that model deck, so if I were to get a new one, then it would have to be a different model that I can easily bolt on.
Thanks again,
Joel
gwest_ca
This is the deck that Toro still makes and will fit your tractor. There is another front idler assembly but it is for the 60" deck that is likely no longer made. A new idler assembly will come with the deck.
http://www.newhavenpower.com/Toro_Classic_42_Side_Deck.html
This is what you get
Not many if any other manufactures can boast they have supplied the same mower deck for at least 44 years.
Garry
Joel G
Very Very helpful Garry.  Thank you so much.
I'll need to save my ducats this winter and perhaps get it in the spring (if I cannot find a used one before then).  The deck is more than the tractor...
608KEB
Did you pick that up from Jason? Nice C-100!
Joel G
Yes I did.  Looks clean and runs like a top.
roadapples
Plenty of decks to choose from at the Big Show...
857 horse
The BIG SHOW,,,,,,,,,,,Wow Jay,,,,,,,dont get me started,,,,,,
Joel,,,,that is THE Wheel Horse Show of the year.....Jason will be there,,,,Road Apples lives almost in walking distance,,,,,,
Oh,,,,if the tractor came from Jason,,,,,you got a nice machine....and no unpleasant suprizes,,,,,,
OK,,,,,,,im off,,,,,,,,,and Welcome to RED SQUARE,,,,,,you sourse for Everything Red,,,,,good friends,,,,,,,,and any advise or parts you will need.!!!!!!!!
see everyone in 6 months
                                                        Howard 857 Horse in Va
Joel G
Thanks for all of the help everyone.  I may make the trip to PA for the BIG SHOW..
  • Similar Content
    • Brockport Bill
      By Brockport Bill
      48" Mower Deck - Side Discharge model # 78361 -- # 312000163. This mower is listed as being manufactured at the near end of Wheel Horse production for this deck in 2012. This mower is in very good condition used only one season on small yard. Well cared for and stored indoors. The deck has double right side pulley for optional bagger attachment. Any owner who cares for this mower will have a great investment of a classic WH deck to last decades. Cash pick up Poughkeepsie, NY area. No returns. Please send p.m if interested
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
    • Brockport Bill
      By Brockport Bill
      Wheel Horse Mower Deck - Rear Discharge - was used all last season - terrific cut, NO rust holes. Blades, pulleys, good condition. Pulley/belt safety covers included. Belt included, underneath cleaned -- Model # 05-36mr04 -  Cash pick up $415, near Poughkeepsie, NY. No guarantees, no returns. Please send p.m if interested.
    • Tristen1972
      By Tristen1972
      1995 Toro Wheel Horse 60” mowing deck. The deck is in decent shape but has been used. There are some repairs that have been made by the prior owner (not me). This deck would be really good for a working tractor and not a show piece. Comes with all the tins, mule drive, mule drive belt, new left and right front anti-scalp wheels and the manual for it. The only thing it is missing is the main belt for the deck spindles. I am located 45 mins NE of Indy. If you have any questions, feel free to shoot me a message.
