Delhiski
What am I doing wrong?
Delhiski
Having problems. Rod for PTO will not drop down far enough. So I needed to take top bracket off to get rid out and remove belt?   Next item, is there a truck to remove belt?  I can not get it out of pulley area as it is twisted and to tight to pull through. What is the trick?  I reserved forcing through as I am not sure it will go back on?  See pics.  I appreciate any help I can get. First time pulling off the deck.
Pat_In_Denver
The belt doesn't come out of the mule drive unless you remove the cover from it by taking off the large nut.  At the PTO, you should only have to swing the bar towards the back of the tractor to remove the belt.  The only time that bar needs to be dropped down is when you attach a tiller.
  • Like 4
Pat_In_Denver
If you do need to remove the arm, the trick is to pull the top out away from the engine so it doesn't hit the rim of the PTO.  It's a bit of a pain, but after mounting a tiller a couple of times it becomes a piece of cake.  Just make sure the hair pin on the bottom is replaced towards the engine side so it can't interfere with the belt.
Ed Kennell
When I remove a deck, I always leave the belt in the mule drive  and store it with the deck.
  • Like 7
Tankman
:text-yeahthat:
KC9KAS
@Delhiski :text-welcomeconfetti: to :rs:
Delhiski
There is a spacer sleeve on the PTO rod, I moved that above the metal plate and that gave me enough clearance to lower the rod.  I will have to look at the schematic to see proper way.
Thanks for the belt help, I will just leave on and zip tie in place.  If and when I need to remove I will take off the belt cover.  Thx
I moved that spacer above?
WHX??
Your welcome from all of us ...
:WRS:
  • Similar Content
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • Brockport Bill
      By Brockport Bill
      48" Mower Deck - Side Discharge model # 78361 -- # 312000163. This mower is listed as being manufactured at the near end of Wheel Horse production for this deck in 2012. This mower is in very good condition used only one season on small yard. Well cared for and stored indoors. The deck has double right side pulley for optional bagger attachment. Any owner who cares for this mower will have a great investment of a classic WH deck to last decades. Cash pick up Poughkeepsie, NY area. No returns. Please send p.m if interested
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
    • Brockport Bill
      By Brockport Bill
      Wheel Horse Mower Deck - Rear Discharge - was used all last season - terrific cut, NO rust holes. Blades, pulleys, good condition. Pulley/belt safety covers included. Belt included, underneath cleaned -- Model # 05-36mr04 -  Cash pick up $415, near Poughkeepsie, NY. No guarantees, no returns. Please send p.m if interested.
