  • ×   Pasted as rich text.   Paste as plain text instead
      Only 75 emoji are allowed.
    ×   Your link has been automatically embedded.   Display as a link instead
    ×   Your previous content has been restored.   Clear editor
    ×   You cannot paste images directly. Upload or insert images from URL.
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Similar Content
    • By qudrcps
      I recently started experiencing "bucking" on my 1997 520-H with the Eaton 1100 series transaxle.  This occurred after 500 hours of heavy use with the 60" mowing deck, with all transaxle oil changes performed per specs.  In reviewing causes of "bucking", I came across this for a similar complaint in a Simplicity 4711 that used the same transaxle.  ( simpletractors.com/forums/topic/7441-simplicity-4211-hydro-bucking-problem/ ).  One thought was that this was due to missing or loose bolts securing the transaxle to the frame.
      This turned out to be precisely the reason for the "bucking" in mine.  One securing bolt replaced, all other securing bolts tightened (along with the engine bolts), and the Forward-Reverse lever/linkage adjusted and tightened, and the tractor is back to "usual".
      It's just something to consider before the nightmare of a transaxle overhaul...
    • By mustangken
      My 520H blow out a valve seat.  Any suggestions on a new motor or should I have the seat repaired?
    • By r1jakecfd
      Hi Guys,
      I know my voltage regulator is bad on my Onan P220 and was wondering if anyone has an opinion on a replacement, OEM or aftermarket?
      Also, I checked my stator leads for AC Voltage and got about 25 volts at 3600 rpm on each. Is this OK? I know it says in the 40’s.
      Thanks guys
    • By r1jakecfd
      Hi Guys,
      Does anyone know where you can get the correct size, 90 deg crimp fittings for the hydraulic line going from under the hydro trans to the lift valve on the 520-H? I found a Gates fitting with the correct thread size but it was too long on the thread end. It came down too far under the transmission to allow the hose to come over the frame.
      Hopefully I described this well enough?
      Many thanks,
      John
    • By BaySide1
      Hey Guys,
      Doing some Maintenance on my 2 Stage snowblower ID # 0644SC01    60442  Ser# 9317
      Problem # 1
      Last winter Noticed that the Drive Pully on the Blower was wabbling
      This spring when I took the belt off I noticed that the Keyway on the spindle and pulley was worn.
      The Key ways actually rounded
      The set screw in the pully to spindle was missing.
      So, what is the easy/cheap fix that will solve this issue
      Thinking of mig welding the pulley to the spindle.
      How Stupid is that idea?
      Problem #2
      The scraper Blade is well worn. Should I try to find a new piece or weld something to it?
      What would you guys do?
      Thanks In Advance for taking the time to Respond,
      Best Regards,
      Kevin B
