Sandman330
New to Wheel Horse need parts
Sandman330
Hi, I am new to the Wheel Horse "family" and in need of parts dealer . I have a leaking fuel tank on my 520-H. I have found a couple on ebay but that makes me nervous. Would like to find a goods parts place I can trust. Also does anyone here know where I can find a manual for a 520-H. I have soooo many Questions lol.
Achto
:WRS: Take a look in our manuals section, there will be 520 manuals in there. As far as parts, if on line worries you check locally for a Toro dealer. If new parts are still available they should be able to help you. There are also many parts suppliers listed here under "RedSquare Links."
Edited by Achto
Sandman330
Thank you.
Chris G
Scroll down on the home page and go to the vendors section. Look for A-Z tractor and contact him. He might be able to help ya out. But welcome to the Horse Family!
TDF5G
I compare prices of the two.  One will be a little less on the cost than the other, depending on the item.
N3PUY
I repaired the tank in my 416-8 years ago with Permatex repair for plastic tanks.
It's listed for windshield washer tanks but will work on fuel tanks too.
 Not listed as such for liability reasons.
Cee245
I have a parts 95 416h with a good fuel tank.
I think its the same shell.
You would have to put your fuel level sensor in the 416 tank.
I have a 97 416h with a 520 fuel sensor to my custom gauge set for a 416.
953 nut
:WRS:     This manual may be helpful.
jay bee
520hC-120
Partstree.com is good as well as jacks small engines .com good luck with your 520H I'm sure you'll love it like I do mine :)
:WRS:
JimmyJam
:text-welcomeconfetti: to :rs:You will find tons of info on this site!!!
  • Similar Content
    • Mitchellnh
      By Mitchellnh
      Wheel Horse parts collection. Many new-old stock and used parts for many models. Please make an appointment to view. No trades.
      There's a lot of parts for D-160 and the C series. This is a collection left behind by my Father, so I'm really not sure what part is what here. There's even a D-160 Tractor under a tarp in the backyard with a three point hitch. Hasn't run in a decade. I'll throw that in if you meet my price.
      Willing to sell entire lot for $1850 obo
      Mitchellocastiglione2@gmail.com
    • blu_stang
      By blu_stang
      Hi All, It's time for me to sell the D-250 I've had for the last 8 years.  It’s useable as is, or would be a great project bundle for further restoration.
      I am selling a large package: the running tractor, a refurbished snowblower (48”), parts snowblower, mower deck (60”), tiller (40”), front plow blade (60”), Cat 0 3-Point Hitch with adjustable top link, WH 3-Point tool bar, wheel weights and tire chains.  Also included is an extensive part collection, nearly a second tractor worth.  I will include the original manuals, an original 1976 sales brochure, and repair manuals for the tractor and the engine.  I made electronic copes of all of the above, and stored the paper copies to prevent further wear. This is one of the most complete D-250 tractor/attachment bundles I’ve seen.
      Some highlights from the available parts: Frame rails, extra engine, water pump, extra transaxle, extra gears, including worm gears (stored in oil bath), Front wheel set, carburetor, carb rebuild kit, rebuildable original radiator, extra radiator overflow bottle, rebuilt alternator, new voltage regulator (I was planning to change over to an alternator setup from the generator), new in package Renault engine seals, new PTO seals, ignition maintenance parts.  There are also many panels, frame pieces, cables, levers, tubes (lines) and hardware in the collection.
      The tractor engine runs smooth.  There are around 1050 original hours on it; It’s a 1976 edition.  Everything works, except the dash lights and the rear lights (disconnected b/c of fender).  I just haven't sorted out the wiring, but it is all there.  Headlights are good and working, as are all of the gears and levers.  The four tires are nearly new Carlisle Multi Trac, with nubs still on them.  The rear tires have been filled (ballasted) with Rim Guard for extra traction.  The hydraulic pump, front PTO clutch and brakes operate but could use a tune up.  I’ve used it for mowing and snowblowing on hills, driveway and around my land. I don’t have an original WH seat.  The snowblower was rebuilt a few years back, and assembled with all new hardware and bearings.  The mower deck gearbox was professionally serviced recently, and has a new set of blades with only a half dozen mows.  The rear fender needs a repair, but all pieces are available.  The plow and tiller are due for restoration.  The Points, Condenser and rotor have all been replaced and tuned in.  The battery is good.  I've rebuilt the carb, replaced the fuel pump and changed out the plugs within the last 30 hours.  The replacement radiator is from a Kawasaki engine; it was installed with new hoses. There are also new custom hydraulic hoses and a new hydraulic lift cylinder.
      Here's a video of me mowing, this past summer.
      Transporting this haul in one trip will require a pickup truck and a large trailer.
    • Merl
      By Merl
      Newbie here and I have a 520-H that runs, but needs some TLC and some minor things fixed and/or adjusted. It comes with a like new tiller that I believe has only been used once and has paint still on the tines. I am the 2nd owner and I have personally never used the tiller. I am selling my previous home that I rent and where it has been stored. My current home's yard just isn't big enough to use a rider and I need to find a new home for it. I want to sell them together to simplify and I need them gone in the next 2 weeks. Please reach out with any questions and I'll do my best to answer. I am definitely not as knowledgeable as most of you on this forum, but figured somebody would like to fix it up, part it out and/or needs a tiller. Please email or text.
    • decvt79
      By decvt79
      I recently posted about issues with my transmission and have now identified the issue.   I removed the transmission cover and found that the final pinion bearing had failed.   Bearings and race in bottom of cover.   Now need to find replacement bearing and also a new filter.   Bearing part number from Toro is 93-0446 and is stamped with “Japan Nachi 6203”.  The gasket is Toro # 93-0478.   Any help verifying these part numbers for a TORO 270H model 72106 and also locating replacement parts or equivalents would be greatly appreciated.  My transmission serial number is 049132.  Thank you!
    • mbalsup
      By mbalsup
      Hi all,
      Not a Wheel Horse fan but recently had a WH 656 given to me. It seems complete with the exception of the steering wheel. Might anyone have an appropriate steering wheel for sale or can point me to where I can find one? Thanks
      Mike Alsup
      Dekalb, IL
      mbalsup@gmail.com
