The wife said I need a hobby... C160 Auto
By
Emmy's Dad, in Wheel Horse Tractors
Similar Content
By BrianStasC-101
Hello all. I am looking for suggestions on adapting the pto from my C series tractor to a harbor freight predator 420 13hp engine. I know the predator motors are a controversial topic however it is the route I have chosen for this particular machine. The intent was to mostly use it for plowing so no PTO required but it would be handy to have. Looking to hear from someone that has successfully done the swap that may offer any advice before I attempt to transfer it over. Just looking for any general pointers that will help me along the way to make it go as smoothly as possible.
By HumbleHans
Operator manual 810343R1
Wiring
34 pages 17.5MB
Wiring Colored
1 page 228KB
1984 C-105 8-Speed model 11-10K802
1984 C-125 8-Speed model 11-12K802
1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
1984 C-165 8-Speed model 11-16K801
1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
1984 C-195 Twin Automatic model 01-19KE02
By PMeadows
Thinking about selling my 1974 C-160 and hoping to get a feel for interest. It has working hydraulics, front plow, single row rear plow, 42" belly mower deck, 55lb wheel weights. Runs fantastic, no smoke. Lights work, amp meter works, has plug in cigarette lighter (doesn't work). Left rear wheel cylinder has slow leak.
By t_furl43
1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well, it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4 -
By RJ Hamner
Will the plow I am using on my C121 and C160 work on a 876?
or is the plow frame different?
Thanks
Bob
