Mloosley78
Custom Wheelhorse hot rod tractor
Mloosley78
So work has begun on the hot rod wheelhouse.
Stripped the raider down to only what is necessary.
Engine being rebuilt and got an old seat to put on her
Start cutting the beer keg open tomorrow to use as front grill
Will be a good day
  • Like 4
neil
This looks interesting , can't wait to see the progress on this little project, wished I had the time to do something similar
good luck with your journey
953 nut
:WRS:  I quit drinking years ago, but I will be watching this build!    :text-bravo:
farmer
Was emptying the keg the incentive for this project, :rolleyes:  and why is this reminding me of Chitty Chitty bang bang.
Looks like fun.  :)
Mloosley78
Ha the beer was drunk ages ago but i think it will look good as a grill
Started changing the front wheels today. One on and one to go
Digger 66
  Ditto ^^^^^^^^^^^      Ditto ^^^^^^^^^^^^^^^^^^                  Ditto ^^^^^^^^                  Ditto ^^^^
19richie66
What did the front wheels come off of?
Mloosley78
There off a moped. Bore holes were exactly the same so just pushed the bearings out of the moped wheel and knocked the bushes out of the wheel horse wheel and swapped them. Had to shorten the moped wheel by about an inch and half overall so it would fit on the spindle but overall result looks great. They will be blasted along with the back wheels ready for paint but they sit taller at the front which gives the tractor a slight rake. Perfect for the look i want. Going to change the tyres also on front so they Kinda  match the back tyres but all in good time. I have an option of putting some floatation wheels and tyres on back but can't make up my mind on them yet
Mloosley78
Mloosley78
1 hour ago, Mloosley78 said:
Any thoughts??
953 nut
Bigger is better, even if you end up having to raise the fender pan up to clear.
  • Similar Content
    • Burnerman
      By Burnerman
      I’m building a lowered 300 series wheelhorse. So far it’s a combination of 3 scrap tractors.
      the frame, trans and tins are from a GT2500 anniversary special given to me by a neighbor with a trashed Briggs. The Kohler M12 is from a junkyard 312 that was roached. The parts tractor I’m using for the build was another older 312. I’ve got the k301 in the garage. The trans was toast. Both axles wallowed out keyways and 1 axle actually broken.
      Anyway! I needed a project and a toy to putt around the neighborhood. I couldn’t find any other posts on how to do the whole thing. I’m trying to keep it cheap using stuff I have on hand and looking as “stock but cooler” as possible. So here we go.
      I’ll update this as I go along.
