Similar Content
By Duramax7man7
Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
ONLY 419hrs
FEATURES:
Newer Agro Tires on Rear & Solid Front Turf Tires.
Wheel Weights on rear.
Fully Swapped Forward Swept axle and Steering off of 520h.
New Tractor Supply Adjustable Seat.
Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
I ran my 60" Deck on this tractor for over a year with no issues.
Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
Asking >>>>> $1,099 OBO <<<<<<<
(248) 943-8634 Text or Call. God Bless.
By Duramax7man7
Very Solid tractor!
Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
$1175 OBO -POOS
(248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
By Berco
Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
By RJ Hamner
Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
Ideas?
