BaySide1
520H Vacuum Gauge readings
BaySide1
New to the 520h. What should I be seeing for a vacuum reading on the gauge.
Standing Reading at idle?
What causes it to rise and or fall?
Is this engine vacuum or  a hydraulic vacuum?
Thanks
gwest_ca
It is engine vacuum but the operator's manuals seem to differ in their description and appear to contradict each other unless they are calibrated opposite to each other.
#5 is 1988 and #4 is 1993-96. Hopefully an owner can tell us which is correct.
Engine vacuum is taken from a port after the throttle plate. Higher is better.
Sometimes a vacuum gauge gets it's signal from the air cleaner ahead on the throttle plate to indicate the condition of the air filter. Lower is better.
Garry
Pollack Pete
Vacuum will be highest at idle.Vacuum will fall of as engine rpm increases.I could never understand why ,except fot tune-up reasons,anybody ever installed a vacuum gauge on an engine..Just another gauge to look at,I guess. .Good for adjusting a carburetor though.
WVHillbilly520H
They both are correct, #5 standard vacuum gauge when you open the throttle the vacuum drops as rpms rise then on the newer models #4 it's obviously calibrated different to show amount of hp being used ,as for me normal WOT while mowing normally reading steady at 75% +/- but heavy tall grass and deep snow blowing near 100% when the governor opens up and at idle needle fluctuates around 25% +/-, just my experiences with my 520s and tuning carbs with a standard vacuum gauge also the stand alone vacuum gauge can give you an idea on ring/valve seal/condition throughout the rpm range, Jeff.
squonk
For years I used a vacuum gauge to diagnose engine troubles and do tune ups. Low vac-retarded timing, rapid swing-sticky valve, drifting back and forth- lean mixture. ect. I still have a couple kicking around. I wish there was a port to install one on a K301. :)
AlexH
Mines stuck between 100 and like 85 what does that mean?
lynnmor
First, make sure that you have a good hose with clamps connected to the intake manifold and the gauge.  If that doesn't fix it, then a new gauge is in order.  100% means that there is little vacuum and the engine is working as hard as it can, of course with the engine stopped it also is reading 100% because it is working as hard as it can.
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
