RedWheelz
Snow Blower compatibility question
RedWheelz
I got a C-121 and was wondering if a model 06-37SK01 snow blower will fit it?
Thanks for any help!!
Ed Kennell
file:///C:/Users/umpa/AppData/Local/Microsoft/Windows/INetCache/IE/L25QUUTB/WH Interchange 1955-2000.pdf
Open this file and scroll down till you find your C-121.  Page 22
You can also find your blowers manual in the manuals/blowers section and compare it to blowers that are known to be compatable  with your C-121.
Edited by Ed Kennell
JAinVA
Ed,
   I couldn't open the file you posted.It might just be me but just in case I thought I'd tell you.I looked in the manual section and I don't think that blower would go on a c series without modification.
Walt
 06-37SK01  Snow Thrower is for a vertical shaft engine powered tractor.
JAinVA
Thanks Walt I thought that's what it looked like it fits.
Ed Kennell
Thanks Walt and Jim.   That file would not open for me either.     Above is the file from the manuals/misc  section I was trying to copy/paste to show the blowers that will work.
gwest_ca
The attachment list is good but leaves out many models. It includes the original unit, the unit that replaced the original and the unit available when the list was made. It leaves out the models between the last two.
There is a list of models here that go back to the first 37" snowthrower for the C-Series tractors that started in 1973 with the introduction of the front quick hitch. Everything from 1973 on will fit.
Garry
Walt
Garry is correct it will fit, but the drive may not work without some modifications. I have modified a vertical shaft snow thrower to use on tractor with a horizontal shaft motor. It was a bit of work and a couple of hundred dollars in parts to complete. I enjoyed the project and it did nice the 2 times I used it this winter. This being said I will more than likely not use it again. The reasons being are my feet got cold setting on my butt clearing snow, and dressed exactly the same way I stay toasty walking behind either of my smaller snow blowers. Also I only own 1 tractor and want my blade on it in winter. I also have limited storage space in the winter since I store my car in the winter.  Lastly I have no desire to own a second tractor just to be able to run the snow thrower.  Guess I'm neither a collector or a hoarder simply the owner of a worker.
Maynard
I just bought a wheel horse raider 12 wanting to put a snowblower on it will a snowblower from a newer model fit? Or do I have to get the older  style if I can find it? Looking at model #79263
gwest_ca
The 79263 fits tractors with a vertical engine crankshaft so the pto is below the engine. Requires extensive modifications to change to a side pto as Walt did to fit a long frame tractor like the Raider or C-Series or 300-500 series models.
The post I made in 2017 no longer has the list of compatible models. It is now here. Click on the picture
You can add a front quick hitch to your tractor so 1973 and later front mounted attachments will work including mower decks.
Garry
  • Similar Content
    • Jayzauto
      By Jayzauto
      Toro - WheelHorse SnowBlower fits “XT” Models.  Model 79483 Serial 240000164. In great shape, has high chute, wide kit installed and has belt.  Skids show little to no wear, so I’m guessing not used much.  SnowBlower only.  No mule drive or lifting hardware.
      $250/BRO
    • PWL216
      By PWL216
      Selling a two stage snow thrower in very good condition. Works great. Comes with small box of new in-package parts. Can deliver to Zagray.
    • Joe Warren
      By Joe Warren
      New Old Stock Wheel Horse 37” Snow Thrower
      Wheel Horse part # 06-37SX01   1979-86
      Used on tractor models:
      B-81, B-82, B-85, B-111, B-112, B-115, B-116, B-165, B-186
      LT-832, LT-1100, LT-1136, LT-1137, LT-1600, LT-1637. LT-1642,
      SB-371, YT-12-A,
      208-3, 211-3, 211-5, 211-A, 216-5,
      New Old Stock, fresh out of its original shipping carton, $399
       Local pick up in Easton MA (I may be able to deliver to southern New England and Tristate area)
      Please private message me if you have any questions.
      Thank you,
      Joe
    • BobandJamie Raay
      By BobandJamie Raay
      400 Series WheelHorse Garden Tractor w 42" deck in good condition. Has a frame issue under the seat (needs welding) but runs well. 17-horse Kohler engine on tractor.
      Extra rear discharge mulching deck (42"), extra set of blades for mulching deck and side discharge deck,  snow thrower (42" with 20" chute) and trac vac with 5.5 horse Honda engine in good, working condition as well. All 4 hubcaps are included (rear not in tractor picture but see additional pic). Original paperwork, including owner's manual on all. Includes chains for snow traction and weight attachments for each wheel. All have been used at the same property since purchase and have been stored indoors throughout. Thanks for looking!
    • mmmmmdonuts
      By mmmmmdonuts
      Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
