Hacksawhero123
C160 independent hydraulic hitch progress
Digger 66
THAT IS DANG COOL !
KC9KAS
Very neat idea and fabrication work!
oliver2-44
I like it! I also plan to do something like that ones of these days! Hopefully sooner than later!
Sarge
Make sure that cylinder can't bottom out and put too much force against the cast iron housing or the hitch pin area - they can break if stressed enough since cast iron basically won't flex .
Looks exactly like what I wanted to do other than maybe splitting the lift arm in the dash on the older models and making another arm on the right side to work like the left , giving the older models a second lift option for the cable going to the rear .
Interested to see how this works -
Sarge
Hacksawhero123
Sarge, I was cautious about that. The cylinder runs out of travel before the hitch runs out of swing. We shall find out how well it works in a few days after I get the hoses made and the additional spool valve installed. Thanks!
Mark.
R. L. Addison
I put a rear  hyd. cylinder on a  C141 in '90 or 91 and I use standard equipment with it, tiller, clevis hitch, rear blade, etc. with no problem. One problem I can foresee with your set-up is unless you have a "float" position in your valve, the rear wheels may come off the ground rather than engaging the ground (I bought a loader valve for an ARK loader).
I'll try to put a picture of my frame-work but, don't hold your breath.
Can't tell much from picture, but I think you have a good start but may want to move your cylinder towards the front of the tractor some.
As I mentioned earlier for floating, a "D" series valve would work or chain links, or maybe it will be O.K. for your application.
Hacksawhero123
Yeah, A float position would be nice. Do you happen to know if one was made that will stack with the factory Omco valves?  I'll run it the way that it is and we will know then if it needs a float. I just finished rebuilding and installing my 3 valve stack. Thanks for the input Mr Addison. I learn something new every time I log on here.
Mark
cleat
You may also be able to give it float mechanically by adding a slot, chain etc to the linkage instead of it being solidly attached.
The 3 point on my diesel tractor only has float with no down pressure.
Sarge
The D series valves do not have a float position to my knowledge unless maybe the D-250 model does . The "float" action comes from the design of the D's rockshaft with the center lift link riding loose on the shaft . It is pushed up/down by a pin in two welded arms next to it or you have the option to pin it solidly between those two arms . It's helpful but limits the lift height of the blade and it reacts fairly slowly due to the geometry of those arms . I run the 56" blade with the center lift link solidly pinned and use the spring loaded lift link to the blade - it works pretty well and allows some light down pressure that is adjustable via the threaded rod through the spring .
Blade_Dozer_56in_1974_6-1141.pdf
_Tractor 1975 D-160-180-200 OM #803977.pdf
Details of how it's done on the D are in those two manuals .
You could incorporate something similar into your rear hitch parts .
Sarge
R. L. Addison
Maybe I better do some checking. I have a "D" series valve with what I took for a float detent. I've been trying to find out who made the omco valves to see if I could get a detent block for the other side. Second thought, the "D" I had at one time had float
on the three point for the plow & tiller, and I think the c195's did also for the same reason if my memory serves me right. (I have been wrong in the past many times in the past though, if not, I would be much better off). Gotta check!
Ron
Hacksawhero123
Ok. I've got it all together now. Of course it's rained for two days so I can't test the plow. The rear cylinder has plenty of power on the lift stroke. With me standing (200lbs) on the plow it lifts easily. On down stroke it does not have enough power to lift the machine. Although without the plow, I can put a jack under the hitch and it will lift the machine. This is working as I had hoped. I intentionally used a small cylinder as to not have enough power to start finding weak links in the rest of the framework. I wasn't trying to build a tow truck. Thanks for your input fellas. When it dries up here, I'll get some video of it tearing up the yard.
  • Like 8
Sarge
Yup , we need video..
There are spool valves out there with a side detent for float as well as knob controlled versions - just have to find a hydraulics shop willing to do some digging .
Sarge
R. L. Addison
I can't load the picture of my "D" series valve, here again I would have to email pictures to someone who could post them.
The float detent is very visible.
Sarge
I gotta look into this - mine only has the handle for the center lift right now - don't have the rear cylinder and the 3pt for it yet but hunting one...
Sarge
can whlvr
so can I ask a question,to put other control on you simply bolt in another section,i ask because I have a spare valve and cylinder and hoses from another c 160,and I have a c160 hydro,id like to add a cylinder for something like that
R. L. Addison
Be sure the o ring between the valve stack has life to seal, add longer bolts and hook up hoses. There are places where a float detent is very necessary, but I don't know how you want to use it.
  • Similar Content
    • ebinmaine
      By ebinmaine
      A HUGE thank you to Tony @Docwheelhorse for settin' me up here.
      The generosity of some of our members never ceases to amaze me.
      This here is another 1974 C160, but with the rare Tecumseh HH/OH160 OHV engine. Made one year only.
      It's rough. Very much in need of a full disassembly and restoration.
      When it came here it was missing one tie rod and the other was broken off one end.
      Today I popped used tie rods on and Trina used her 867 to drag it from the drive to the shed.
      The engine wouldn't move.
      Tin was near chock full of skeletal mouseseses and their house.
      Cleaned that out and the engine spins freely now.
      So progress has been made.
      It'll be a good long while before we get to this one but I just couldn't turn it down considering the rarity.
    • Brian33
      By Brian33
      Hello,
      I am hoping someone can help my. I recently acquired a c160 for the engine for another tractor. So I did a motor swap and wanted to see what the hydro was like. I put a plow on it C-160 (which now has a 12hp engine on it). I did a quick test run and everything was good. I drained the fluid and change the filter (Napa 1410 filter and sae 30 transmission fluid as it stated to only use this fluid on the tractor.) everything was working great after the fluid change. I plowed two driveways and the sidewalks near my house... all the sudden the tractor would not go forwards or in reverse. I tried to pick the plow up and nothing... I checked my drive belt it was turning like it should. I started to push the tractor and the rear was engaged so it would not move. Of course I was 400’ from my driveway and the plow was down which made it fun. I put the tractor in forward and started to push it and the thing took off. So I hopped on and took it to the front of the garage. I put it in revers and it cut out again so I pushed it in the garage. Today I went out to check the tow valve. I took it out and cleaned the threads up put it back in and it did not change anything. According to the dipstick I have the proper amount of fluid in it. I did have a drip that I fixed on the cylinder still nothing... does anyone out there have any tips to help me out? I’ve never had a transmission like this only manual transmissions. The model of this transmission is the sundstrand 90-1140.
      Any help would be greatly appreciated.
      Brian
    • ebinmaine
      By ebinmaine
      I don't have pictures yet but I can get some later. I know that will be helpful but I forgot to take them last night.
      So here's what I know.
      When I bought my c-160 last year it came with a plow. It was delivered to my house and the plow was not mounted on it. I never saw this particular plow on that particular tractor.
      The plow I have is 42 inches wide and has a full frame as most of them do.
      The angle lever has the Z shape to it, NOT a straight stick of metal, and also bends slightly back towards the operator.
      When I am pulling the angle lever towards me to change the angle of the plow it contacts the brake lever.
      Any thoughts?
    • ebinmaine
      By ebinmaine
      I have at least 7 hubs on different tractors that I would like to add a second set screw to.
      I have an older but good quality floor model drill press.
      I have the tap set.
      I don't recall ever using the tap set to do anything other than clean out threads. Not make my own thread set.
      Can anybody give any particular advice?
    • ebinmaine
