ohiofarmer
I like to hang shelves--a lot of them. If you hang them from the ceiling, they need to be firmly attached. The blocks that the shelves are attached to have 16d spikes driven through and a 16d has a shear strength of 1.5 tons The shelves themselves are cleated to the rear wall covering nailed into the studs. The front rail is two layers of 3/4 plywood laminated with staggered joints. the plywood has a rabbeted lip so the shelf fits flush at the front and you have a handy place to screw the shelf to the support rail. because of that , they assemble super fast  You can see that there are no under supports on the floor and that makes it easy to keep clean I keep them about 24 inches off the floor for the super heavy stuff. For a four shelf unit 16 inches wide, it takesexactly1,5 sheets of plywood including the shelf supports. The units you see are 64 feet long and they were gang cut with a worm drive saw while in a plywood pile [cutting four shelves with one stroke] . I did it in about eight hours total start to final assembly.
 Make sure that you use deck screws and not drywall screws for assembly of the front support rails to the vertical front stile [vertical] supports The drywall screws will not hold the weight that you are likely to place on these shelves.I picked the Roughneck by Rubbermaid for my storage tub. They have a lifetime warranty and fit  three nice and tight between the supports
 I knew this single stage [nearly new condition] was hiding in this section of the barn, but because of bad housekeeping it was not accessible. I am re-organizing the barn now and cannot believe how much better it all works once the shelves are neatened up...
ztnoo
Could you give us some longer distance shots of the wall or whole assembly?
It will help visual the total concept a little better.
I generally like your ideas and method of execution.
What's the height to "the square" of the garage/shed/pole barn???
Shynon
Here's my Harbor freight high lift motorcycle stand with a few mods. I could not lift tractor high enough to put on my table so  I added 6" . It removes with 2 bolts and slides right out, steel plate on top also comes off with 4 bolts, Shown lifting my 1054 off my table. I have also cut open the bottom of the table and installed some 4"pvc pipe to hold misc. steel stock, also cut a rectangle  for other steel.  More to come as I am reorganizing my garage again after seeing some of the great ideas here.
  • Like 5
DennisThornton
This got my attention!  Never thought about using that to lift a GT!  Initially I think I would have extended the post instead but never-the-less I'm intrigued.  Seems to have issues with mid mount attachments but I wonder if that could be addressed...  Maybe used to only lift but then some special TALL jack stands
Hey!  Thanks for sharing!
953 nut
I think the balance point on most :wh: would be behind the mid mount.
Very good idea, I have a similar roll around; your royalty check will be in the mail.  :ychain:
DennisThornton
OK.  I know you're good for it but I'd rather trade for further ideas.
ohiofarmer
I have that Harbor freight high position  jack as well, and once considered how cool it would be to copy the geometry on the thing and make a big version of it using this larger 8 ton jack they sell as an upgrade to their engine crane.  http://www.harborfreight.com/8-ton-long-ram-air-hydraulic-jack-94562.html
 Once i rebuilt the Southworth 42" lift height lift table, that idea died pretty quickly
  I have read reviews of people lifting loads close to the 1500 pound "capacity" of that lift, but I am not comfortable attempting it. Of course, an unbalanced load lifted up high and applying twist from horsing with a big wrench could lead to some Red Green style disasters.
I do like your mods, Dennis. Using that add on or others you could make an engine stand of adjustable height, welding table, or any number of things
Edited by ohiofarmer
Shynon
After seeing yours I and seen the possibilities, I had to have one. I think this will work nicely in my shop
Shynon
Well after throwing my back out picking up a sickle mower, used a 25% off coupon and picked up this nice little lift table. Now just need to remember to use it.
  • Like 6
ztnoo
What is the rated lifting capacity of the HF lift?
Shynon
It is 500lbs. they also have one that is 1000lbs capacity
AMC RULES
How do you get it under the sicke?
PeacemakerJack
Following @Professor1990‘S thread on his shop build made me think of this thread that @prondzy started a couple of winters ago.  I’ve been continuing to work in my garage trying to get the details taken care of to both store tractors, implements, and parts as well as having a functional heated space for winter projects. Being the “plow dog” that I am, I decided that I needed to find a good way to store my plows.  There are definitely tighter (more compact) ways of storing plows but I wanted something functional where I didn’t have to unpack a shelf to get out a plow.
So, I bought some extra shelving from the local box store, used 2x4’s across the shelving brackets, installed a long 2x4 underneath and then drilled holes at the appropriate spacing.
I am able to then select a plow, pull the pin and slide it out to go to work.  I’m trying to create more space in my garage for the next big event which is the installation of a furnace to heat the space.  Once the heat runs are all installed, then I can start to cover up the walls and ceilings with the appropriate coverings.  It is so awesome to be able to organize shop spaces for sure...
  • Like 5
ClassicTractorProfessor
@PeacemakerJack yes a well organized shop is a must have for our hobby, sure makes a guy feel good when he opens the door and sees it all coming together...thanks for digging this old thread out I had forgotten about it and probably some good ideas I had forgotten about as well hidden in it
The Tuul Crib
Ok, here's the Tool Crib!
  • Excellent 3
PeacemakerJack
:text-yeahthat:Is a nice looking shop.  Tell us what some of your favorite features of your shop are...I’m liking that track light.  Awesome wood shop there too...
953 nut
I have the good fortune of having two shops, one for woodworking and one for :wh: plus a small barn for storage.
The woodworking shop was our guest house prior to building our new house.
The barn has room for seven on the main floor and lots of parts in the haymow.
And the :wh: shop can hold a bunch of stallions.
1888454024_953restoration002.JPG.5c88ae5e0fef180176c16a0346b51f4f.JPG886997609_applecountry2017001.JPG.2520f057ed9aeba95fa78559c59154d3.JPG
  • Excellent 5
The Tuul Crib
I guess my favorite things of my shop is being air conditioned in the summer and heated in the winter!
formariz
I use my two car garage part of house for my woodworking shop. A little disorganized now from the small flood we had. It occasionally doubles as a winery and distillery also. Tractor shop is in another shed which is a one car garage size.
  • Like 5
  • Excellent 2
19richie66
Im with you @Shynon. I just got this about a month ago. Going to set it up with ramps on both sides to drive a tractor over it. Lifts about 6’ high and I believe it is rated about 1500lbs.
  • Excellent 6
WHX??
:text-coolphotos: fellas.. blast cab looks like it doesn't get used Richard I best come and mafia it.
You got way to many plows  Josh especially when @Coulter Caleb don't plow no more.... I best mafia his too!. :lol:
'Cept them kerosene and smudge pot heaters are gassing me out ....Be over this weekend Jack with a furnace get ready I want it fairly cleaned up for work.  Yer wife is on your case about gettin heat out there she's helping...then again heard she's the bread winner ..best send her to work! :ychain:
Speaking of shop cleanup a mouse told me Dan @Achto was cleaning out his garage...could this be true?? I'm gonna have a heart attack.....I'm thinkin he cleans up his act he won't know how to act and we won't see anymore choice :wh: roll out from it anymore....:D
Edited by WHX21
  • Haha 3
Shynon
:ROTF::ROTF::ROTF:
  • Haha 3
Achto
This is a daunting task Jim, I hauled 3 heaping pick up truck loads out & I don't think that I have any more room now than I did before. Maybe I need a bigger truck, or have @pullstart show me how to load mine?:lol: Gonna keep digging though, I need room to work on this winter's resto project.
  • Haha 1
PeacemakerJack
Dan—that’s a good idea.  I could use Kevin’s packing skills to load and haul all this junk to the dump!  I can’t wait to watch your next build Dan if it is the one that I’m thinking of...
Richard—I always like seeing that shop. One of the things I noticed in your shop was the dual ceiling fans.  I’m planning on installing one of those for sure.
Jim—I/we will be ready for you.  Looking forward to getting this phase of the project done.  Sounds like I might have to put pad locks on my plows before Saturday...:D
Richie—I like that lift!  That is a real back saver and will have no problem getting your project at just the right height to make it easy accomplish the task at hand.
  • Like 4
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Besides working in my workshop I sometimes have, or want, to make improvements to it and I figured in this topic I would take you along for the ride.
      First off today was installing a new door and doorframe. The old one was rotted and starting to fall to pieces, literally.
      My dad made a sweet doorframe out of stainless steel and I repurposed a hardwood door that came out of our home when we renovated the place. Still needs paint but should be good for a few decades I'd say.
      Old door with flaky paint and rotten underside.
      New stainless steel doorframe and repurposed hardwood door.
      Next up was lighting. Few years ago I got some freebie fluorescent lamps but they were old and dying one by one. Having to replace the tubes and/or starters regurarly got kinda lame.
      Since Black Friday is now also a thing around here I snatched a good deal one some LED units which can be daisy chained up to 20 units.
      I ordered six of these lamps for about $80,-
      As a test I installed one.. can you spot it?
      What can I say? Bright as day!
      Greetings from the Netherlands, Mark
    • mmmmmdonuts
      By mmmmmdonuts
      I have approximately an 10x12 lean to shed attached to my house on the side of my side loading garage. I currently have a double door that is 6' wide by 6x10" high. The problem I am having is the door starting to fall apart. It is also framed very heavily with 2x6s. So I am currently looking to either do another double door or a garage door. Part of the reason the door is getting damaged in the first place is because water pools at the bottom of the door in the winter and freezes and I have to basically heat and or chisel the ice away. It is where I store my snowblower.
      My wife ruled out a sliding barn door and a roll up door mainly for appearance purposes.
      I was starting to lean to a 8w x7h regular garage door but see a few cons.
      1) It would block the light when up.
      2) I would lose quite of bit overhead storage and about 2 feet of wall space.
      3) There would be much more work reframing parts of the wall to fit the door.
      Pros.
      1) I could fit my wheel horse plow and snowblower side by side.
      2) Shouldn't freeze to the concrete as easily with a rubber seal.
      3) Don't have to shovel out the doors to get the snowblower out.
      I was wondering what thoughts you guys had on and if I am missing something.
      Thanks.
    • CasualObserver
      By CasualObserver
      I've been dreaming of a new shop space to work on tractors and generally store things at my house. We already had a three car garage on the house and could only fit one vehicle in it due to the large space that kids toys, bikes, zero turn mower, shelving and a workbench already occupied. Well.. that stuff and a few or so little garden tractors... but they don't take up that much space, right?   Anyway...  we'd been talking about building my dream shop for several years. We live on a large in-town parcel, so there's plenty of room, but as with most things, it comes down to when it can fit in the budget. I drew it up several times on the building designer at Menards dreaming of when we could go forward. Well, in the early 2017 we decided to go ahead with it, and I came up with my final layout plan.
      We proceeded under the option of build the shell, and finish what we can later. We went over and over the list of things to do now and later. Things I wanted that had to be done now for sure were the rough in for the in-floor heat and the attic trusses. I had a contractor friend who would GC and frame it for me if I bought all the materials and he could do it on his own schedule. Yep, done. I figure I could have built it myself, but it would have taken most of the summer of every night and weekend, as well as the headaches of arranging the subs for the stuff I couldn't do, but if he could do it, and he has all the contacts/subs already... I'm money and time ahead to work some extra overtime and avoid the headaches.
      The previous owners of our place had a gravel RV parking next to the house. The old poorly done timber walls were deteriorating and leaning with age.It was convenient for parking the trailer, and nice when the kids were little that we could park off the driveway so they could play, but every year inevitably it was always a weedy mess by mid-summer.
      Step one, remove ugly timber wall.  Lucky for me my neighbor had an chainsaw with a garbage blade on it. He came over and we were able to cut the wall into 12 ft sections that we loaded on the trailer for the dump.
      Next, met with our contractor friend to stake and mark it out. Since part of the goal was to reduce the amount of gravel, the equivalence of one car parking space was being removed and returned to grass on the left edge.
      Then just before the excavator was to start work, the kids and I did a little groundbreaking for the big project.
      Some gravel removed and sand base laid down and compacted.
      Concrete guys laid the forms for me on a Friday night so I could lay the insulation and pex for the in-floor heat.
       Like any kids, the call of the sand pile was irresistible.
      Next day I had help to lay the insulation boards and pex. Might seem silly to see two people carrying these boards that weigh all of 2 lbs each... but notice all the pavers? I'd been hoping for good weather to do the insulation and pex..... what I got was great temperature, bright, sunny......and 25 mph sustained winds with 40-50 mph gusts. So.... two guys to carry each flippin' board and weight it down. Ugh.... made the process much longer.
      Got the pex down, which went very smoothly. Three zones, stapled to the foam board.
      Monday morning I get a call.... inspector won't pass it because there's no pressure test on the pex. Ugh. Nothing about that in our building code, but what am I going to do? Project can't go on without his initials. So... I build a pressure manifold, tie all three zones into one long line and charge it up.  Tues morning, concrete guys are onsite... inspector shows up and says ok.
      By the time I get home from work, I have a new slab.
      Lumber pack shows up the day before the family and I are leaving for a week at the cabin. When I pulled out of driveway, construction was underway. We got a few progress pics through the weeks from various friends.
      And I returned a week later to this.  Totally the best way to build a shop!  I was out of his way, he was out of mine... worked out perfectly.
      I installed the overhead doors, had the electrician come and trench the electric over. Got the gas line roughed in for the boiler as well while the trench was open.
      After that, the excavator came back with the final top dress for final grading.
      We bit the bullet and decided to go with sod right away. Even got the kids to help for a little while. Couple of neighbors (one of whom happens to be a professional landscaper) came over the chip in too, and three pallets later....
      Now we're at slow progress time. I bought all the construction materials on a Menards 11% rebate, so once I got the rebate check I started to finish the interior. Got the vapor barrier up, and ceiling rocked with 12 foot 5/8" type x. 105 lbs each. Ugh. Thank God for drywall lifts, right!?
      More rebate checks allowed for the insulation and rock for the walls.
      Then we came to a complete standstill..... got enough stuff moved out of the house garage to get both the car and truck in for the winter, but with no heat and no ceiling insulation the shop was just a big storage box for winter.
      Spring this year rolled around and prioritizing shop work made it to the list. I realized it's going to be much easier to get the interior done before I move in. So... started back at it. I got the floors masked off and got tape and mud done... then the girls helped me paint.
      Did the floor with Rock Solid polycuramine kits from Menards... grey with flakes and a textured topcoat to make it less slippery if wet. This is a long and multi-stage process. First it required renting a diamond grinder and grinding off the curing sealer. Then powerwashing three times to remove all dust and debris.  The base coat went on, cured for a few days, and topcoated three days later. Then I let that cure for a week before moving in. It's supposed to be cured in 24 hours, but why rush it if not necessary?
      Finally ready to move in.
      Got some used kitchen cabinet take outs and installed them for the workshop area.
      Really looking forward to getting stuff organized and cleaned up now.  It's totally a dream come true. Still have to buy and install the boiler and get the ceiling insulated... but those are things that can be worked around. Up until this point it's been much easier to have minimal stuff in the way.
      If you made it all the way to the bottom, thanks for taking the time to read it.  Get more done, have more fun!!
