Miker-1
Tecumseh HH120
Miker-1
On ‎12‎/‎19‎/‎2016 at 8:36 PM, tbarnhart said:
You're right, .020 is correct specs for the exhaust. The compression release will not open the valve very far. Probably only a few thousandths. Most likely the operating pin on the cam is worn. If the lift is less than the valve clearance, it won't open and the compression stalls the starter. That's why putting a feeler gauge in the gap makes it work again. You could try lowering the clearance to .015 and see how that works, but its not simply an adjustment. You're looking at one of the methods I described above. I have a 16hp ohv Tecumseh that has some of the same issues at times. Mine calls for .010 ex valve clearance, but I keep it a tiny bit closer to help the compression release work properly.
Would you know length of tappet and  exhaust valve. I measure .025 on length of pin on camshaft and measure about .004 lift on ACR stroke. I hope I didn't shoot in foot again! I seem to do that often
tbarnhart
No, I don't know the length of the original parts, but your measurements would seem to make sense. 0.025 of lift on the decompression mechanism with a 0.020 valve clearance would leave approximately 0.005 of valve lift for decompression. That is probably enough to get a small compression reduction, but may not be as much as originally intended. I would see if I could get that valve clearance down to about 0.015. You may have to build up the end of the stem with weld or lightly grind the valve/seat to lower the valve in the block.
woodchuckfarmer
Id recut the valve seat or have the valve lightly reground before welding up the stem.    Wayne
tbarnhart
That's certainly the best way, especially if the valve sealing surfaces are a bit worn anyway. If it's all really good, or the valve is already thin, I've built them up with a hard weld deposit and never had any problems. I'm not looking at it, so I'm just trying to put all the options out there. Want to keep a good Tecumseh going.
my new toy
On ‎12‎/‎18‎/‎2016 at 11:35 AM, Miker-1 said:
If I'am filing valve wouldn't that give me less clearance. putting in feeler gauge increase's lift right. It makes  the ACR open more to reduce compression? Pulled head not much carbon.
I have a hh120 with the original engine it is a Tecumseh 12hp. I think they couldn't get Koehler engins for about 2 yrs. so they switched to Tecumseh Engines
  • Similar Content
    • KC9KAS
      By KC9KAS
      Need assistance! 1977 Wheel Horse C-120 hydro. I sold it to a young fellow last fall. His dad said he put a new battery in it but it still failed to turn over to start. I checked the only safety switch (with an ohm meter) and it is working correctly. I checked all the wires (ohm meter) and they tested ok. I did come to the conclusion the 20 amp AMP gauge was bad. I installed an old one that I had and it turned over and started right up. I already had the voltage regulator wires disconnected and read 36 VAC from the stator. When I attached the wires to the (fairly new) voltage regulator it would immediately cause the engine to sputter and die. The voltage regulator is grounded directly to the negative post on the battery. Once the wires were removed from the voltage regulator it would fire right back up! I am at my wits end trying to figure this one out! Would a bad voltage regulator cause the engine to quit running? I may have to remove a voltage regulator from another known good machine and try it. Anyone have any suggestions?
    • JasonMc
      By JasonMc
      Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
      Jason
    • WHX??
      By WHX??
      Sadly Dan @Achto informed me the the other day of a 857 and a C-120 that was deposited at his local county dump. Dump rules are  such that once it hits the ground it stays due to junkyard dogs going to fisticuffs over scrap steel. Understandable  Despite some hastily made plans of bribery,  chicanery and/or hook or crook to rescue them we failed miserably. We may get drummed out of the Mafia for that one.
      I'll let Dan fill you in on the details if he has the stomach.  I would like to believe that that our beloved  ones would be smelted down to produce more tractors but then I wake up from that dream. Sorry no bone yard pics not that we would want to see them.
      Dan asked me if he had a problem over grieving over these lost gems. You decide... So in memoriam I feel it is quite nescessary to post pics of our lost loved ones. Since I don't have a C-120 here's what I have of a 857.  Please post your pics of either models. True story, I wouldn't hose you guys and not just fishin  for
    • 608KEB
      By 608KEB
      One seat spring is about 1/4" lower than the other one. Has anyone had this problem. If so, what'd you do to fix it?
    • Tuneup
      By Tuneup
      Homer is a typical Southern man. When a tool breaks, he moves it to his backyard to be repaired another time. Turns out I'm the repair guy and have been attempting to barter for an old C-120 and a Commando 7 buried in the yard. He surprised me with the C-125 black hood a while ago after numerous mower, chain saw, weed wacker and whatever repairs. The horses are all out of a shop in Joplin now gone after the big blow... Soooo, 1 repaired old Sears LT and another that I took apart just so he could see after running without oil that the cam was in 4 pieces and the rod in 5 and he said I could have the 120. We pulled it out of the dirt with 4 flats, destroying several ant mounds in the process. Truly, not bad condition thanks to Homer's attention to the use of tarps. He tells me the 301 was bored .030 over and his mind is sharp for a 92 year old so I'm inclined to believe him. May be able to save that Commando in the near future if I repair that old Bolens GT14 first - and so on. So, my collection is now at a lowly 2. I don't think I'll restore this - will just make her a reliable runner and make the wife happy The deck can use a little metal but seems salvageable. Another C saved!
