Bach-Ed
Is this Kohler block any good
Bach-Ed
Last year this K241 threw a rod.  And as it went it damaged the bore.  I later heard that some lower damage can be tolerated when rebuilding.  So is this still a usable block or is it only fit to be a boat anchor?
JAinVA
If that damage is below the  piston skirt bottom at bottom dead center and there are no radiating cracks from the damage you should be good to go.The piston doesn't travel all the way to the bottom of the bore anyway.If you won't have to put a lot of money into I say go for it,JMHO,JAinVA
Edited by JAinVA
953 nut
If it is not in need of being bared I would think it is going to be OK. You may want to have it magnafluxed to be sure there are no cracks.
JAinVA
As Richard says you could get the block magnafluxed.That is the best way to make sure that the damage hasn't let unnoticed cracks cause a problem.If that service isn't available to you, try a dye penetrant test.While not as good magaflux it can detect cracks.Again if little money is at stake and you know the risks button her up and see what happens.These old Kohlers are some of the toughest air cooled engines ever built.JMHO,JAinVA
Edited by JAinVA
oldredrider
I've successfully rebuilt blocks in much worse shape than yours. Sleeving the cylinder is another option if necessary.
Howie
Knock the sharp edge off of that hone it or bore it and use it. My K301 is similar to that and has been in service since 1985. It could be
sleeved as mentioned above.
WH nut
Run her
  • Similar Content
    • Rick3478
      By Rick3478
      For Sale NOS M12S Short Block, still in the original box.  I bought it pre-emptively when Kohler was phasing out the Magnums.  Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap.  Neither of those things happened, the darn things just keep running.
      Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake.  Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
      And it's heavy, so it's not practical for me to ship.  Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
      Asking $800 or might consider trade for a good center mount grader blade.
    • mcfarmall
      By mcfarmall
      Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams.  A starter,  some new gaskets, and miscellaneous parts.  New drive belt and all the belt idler assemblies.  Engine runs but smokes.  Great restoration candidate or a spare engine for you pullers out there.  Call, text or email for a private showing.   No offers considered unless made in person.  Buyer responsible for transportation.  Many more pictures to send to interested persons.
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • johnnymag3
      By johnnymag3
      416-8  clean machine, one owner, M16 Kohler...............no smoke, knocks, etc. Only 771 Hours.
      42" Rear Discharge deck   NO RUST    blades used 1 season
      48" plow very nice condition,
      Wheel Horse weights, on tractor already
      AG Tires on rear,used one season, front tires great condition. Rears are filled with beet juice, done at a Dealer professionally,  ....non toxic, non corrosive.  Traction Galore !!!
      Machine is fully serviced, ready to work. NEEDS nothing....Look below for pictures
      JOHN   845 797 5716 cell
