608KEB
Mower deck spindle removal ?
608KEB
I have what I was told was a 1979 42"Rd deck. I've removed the spindles in newer decks and older decks. I've not encountered  spindles with keys in them before. To remove the shaft from the housing do I hit it through? Or use a press? I'm also having trouble getting the keys out. I got 1 out.
I got it! I tapped on shaft. It came right out.
608KEB
No problems....yet. removed snap rings
608KEB
ID # might as well do a little rehab work since I took it apart. 2 of the 6 bearings are shot.
Lane Ranger
That type spindle on those decks  takes a little longer to work on when redoing one but they last a lot longer also.  Deck housing looks like a very good one too!
gwest_ca
In case you were wondering your build date is 9123
123rd day of 1979
Thursday May 3, 1979
Garry
608KEB
Thanks, I received the deck for free. A gentleman saw my Wheel Horses and asked if I wanted a mower deck for free. He told me it was in good shape and he hadn't used it in over 25 years. Said it came with a 1979 C-141. The belt idler bar is hardly worn. Free and in decent shape is always a great deal!
Edited by 608KEB
Lane Ranger
You can still buy new replacements for that idler bar (last time I checked)  and  you should use new  nylon bushings too (Glen Pettit sells replacements )    The idler  needs to run smooth to have a  good operating mower deck.
608KEB
New bearings #6203.$117.00 total ouch! New idler bar spacers. I've used this rust converter in the past with good results. Works as a primer too. Starting to put the deck back together.
608KEB
I'm having a little trouble getting the key past the collar with the grooves in it? I have instructions. What am I doing wrong?
WHX??
That doesn't sound right for that common of a bearing!
608KEB
That's what I thought. Because a few months ago, I bought bearings  for 42"RD #78350. They were  about $6.00 a piece. I was surprised. These were $17.00 each. I bought them from the same bearing house. I was also wondering if the deck belt would interchange with deck #78350. The belt on 95-42MR02 is original and shot. The belt I have appears to be about 1" longer.
Edited by 608KEB
WHX??
Yah I hate to say it 608 but I think you took it in the shorts & no more business for that bearing house. I know your not supposed to do this here but sue me ...I am not gonna let a fellow member get robbed
http://www.ebay.com/bhp/6302-bearing
These are what I use and I am sure they are not real high quality but I can change bearings in a deck all day and I grease often.
608KEB
It's  my fault.  Last time I bought bearings for my other 42" rd I asked how much they were. This time I did not ask. I assumed the bearings would be simular in price. I'm over it. Lost or spent money in worse ways! Still trying to figure out how to get the 1/2 moon key in. The collar with groves doesn't go in far enough maybe my top bearing needs to go in further. I don't  want to damage anything.
Edited by 608KEB
doc724
You do not need to put the woodruff key back.  Newer decks did not use a key anymore.  Just make sure you can fit a lock nut under the nut which holds the pulley on. Use lots of never seize between the pulley and shaft.
608KEB
4 hours ago, doc724 said:
Top bearing  wasn't tapped in far enough.
Edited by 608KEB
gwest_ca
Garry
608KEB
A few more pictures. I soaked some of the bolts in vinegar. Brushed rust remover gel and vinegar on underside  of the deck.
ohiofarmer
Typically what happens to an old deck and especially one that has sat around is this.  The slide bar rides on top of two little strips of Delrin, causing a little space between the deck top and slide bar in the area between the Delrin strips. Dirt enters the area and water makes the thing rust. The bar pits and if the deck sets around, the slide bar freezes in place and then the mower belts will break..
 What I did was buff the deck free from rust with a  wheel and use rust converter. I also used my secret weapon abrasive wheel on the slide bar and deck http://www.harborfreight.com/catalogsearch/result?q=polycarbide+abrasive+wheel
 and these wheels will impart a near mirror finish to steel in short order. I have told people to try them for paint removal and they thank me every time for mentioning the wheels. Instead of riding on Delrin, I just find a piece of Formica and cut it a couple of inches wide and cut two slots in it to caapture it in between two bolts so it is under the slide bar. I slather grease beneath the Formica so there is no place for more rust to form. Then i use just a little plumbers grease [completely waterproof] between the slide bar and the formica. It then slides very easily  and there is not a space for dirt to get in.
 The next step is a judgement call, but I run the mower without the deck belt guard and i blow off the dirt and dust on a regular basis.
  • Similar Content
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • Brockport Bill
      By Brockport Bill
      48" Mower Deck - Side Discharge model # 78361 -- # 312000163. This mower is listed as being manufactured at the near end of Wheel Horse production for this deck in 2012. This mower is in very good condition used only one season on small yard. Well cared for and stored indoors. The deck has double right side pulley for optional bagger attachment. Any owner who cares for this mower will have a great investment of a classic WH deck to last decades. Cash pick up Poughkeepsie, NY area. No returns. Please send p.m if interested
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
    • Brockport Bill
      By Brockport Bill
      Wheel Horse Mower Deck - Rear Discharge - was used all last season - terrific cut, NO rust holes. Blades, pulleys, good condition. Pulley/belt safety covers included. Belt included, underneath cleaned -- Model # 05-36mr04 -  Cash pick up $415, near Poughkeepsie, NY. No guarantees, no returns. Please send p.m if interested.
