kougar31
312-8 starter won't engage
kougar31
I'm a newbie to this wheel horse world so first off, thanks for any advice/assistance you give me.  I have a 312-8 with a 12HP kohler and the starter will spin but won't engage the flywheel.  Do I need a new starter or is there something else I can do?
KC9KAS
@kougar31 :WRS:
The starter drive on the starter may be dirty and not extending into/onto the flywheel when the starter spins.
Or, maybe the teeth are worn off the starter drive and not engaging.
Disconnect the battery, remove the cable from the starter and remove the starter and see what the starter drive looks like and go from there.
953 nut
:text-welcomeconfetti:      to  :rs:      Good advice from KC9KAS, but first make sure the starter mounting bolts are good and tight; if they have backed out a little the Bendix will fail to engage the ring gear.
Hope it is a simple repair and please keep us posted.
Jerry77
Had the same problem with a 314-8 years ago...after several failures at keeping it going, I slicked the shaft with white lube...not a problem after that..KC9KAS hit it on the head.....one more thought - when you take the starter off, be careful not to let it come apart - has brushes and it is a bear to get back together...have some scotch tape handy and put a band of it around at the top...it will only grab a very small slice of the top, but is amazingly strong..it will hold it together...good luck
stevasaurus
You may have the "High Mount Starter" on your horse...not sure...if you do, this thread may help you a bunch.  If you do not, it will still help you a lot.  :)
sluggo
I just beat the crap outa my starter with rubber mallet until it behaves.
Maybe that's why I am never allowed to sit at the cool Wheel Horse table.
kougar31
Thanks for the input gents.  I pulled it apart and wiped it down and put it back together and it didn't work at all after that.  So I asked my brother in law to take a look nad he pulled it apart and cleaned it up and it put it back together and it works like a champ.  Not sure what I did but I know he got it working cause it cranks right up every time now.
953 nut
:handgestures-thumbupright:            Wish my brother in law could fix things for me.      :ychain:
  • Similar Content
    • tallen4392
      By tallen4392
      looking for rear weights  12 inch  close to 01077 zip maybe fits also let me know what you have  Thanks
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • Wvtroutbum81
      By Wvtroutbum81
      Got my dads 1992 312-8 when he passed
      have a snow plow and 42” deck.
      gathering parts to restore back to new as possible. This is my therapy.
    • Chuck14025
      By Chuck14025
      1994 520 H.   Starter just clicks.
      1. Battery 12.6V, load test OK.,    New solenoid. Ground good. Key switch tested ok. Wiring diagram shows a 'kill' relay - I can't find it on the tractor. Checked the 3 relays under the battery box - they work. Neutral switch, PTP and seat switch work mechanically.
      2. Not able to find article on this problem when searching. There must be dozens. How do I find them?
      3. Can I test the starter without taking it out?
      4. Is there a 'kill' relay?
      thank you...
    • Tj_WH_Collector
      By Tj_WH_Collector
      Hello y'all,
      I hope everyone is staying safe and staying healthy. If not, i pray that you or whoever is afflicted be healed soon.
      I hope to learn a lot from the forums and hopefully can use some of you young whipper snappers for your brains (ideas, how to's and such). Lol. Btw i am only 30, much respect for the older generation(s)!
      For me, well... If i would have found this 5-6 years ago, i would have said I am new to Wheel Horse. That is about the time my dad bought the 312-8 (that i now own). That purchase and talking to my dad about implements/attachments that i could purchase is what got me so interested in wheel horse.
      Like i mentioned, i started with a 312-8. When i purchased from my dad, it came with a mower pan and a snowblower (wrong model tho). Wisconsin winters were brutal and a regular snowblower was taking me 2+ hours to clear the driveway. Thats when i bought my B-100, included in that deal was a mower pan and a plow. Boy... that B-100 has plowed a lot of snow. I love it.
      I had also bought 2 lack luster tillers at some auctions. Well, that made me look for a tiller attachment. Found one relatively close and went to go look. $200 later, i had a tiller loaded into my truck and i had asked if he had the tillers mount for the rear axle. He said he wasnt sure, but he has a wheel horse sitting in the back. Told me to go look.
      I look over this 854, and there is no rear mount. Just as im getting up, he asks if i want the tractor. I said i only got the $200 i gave you. He said free of charge. And thats how i gained my 854. (854s hood is in my shop)
      I want to start restoring my wheel horses, pretty paint, new decals, clean them up. I am proud of what i own.
      And now im looking at getting a D200 with FEL and a backhoe. Its a sketch time to buy but i could use the tractor for house and cabin work.
      Pics are attached. Please ignore the messes. They aint the prettiest tractors, but they all run.
