Thisguyisnew
Pulling Bushes with a 1977 C-160
Thisguyisnew
Have any of you guys done this or would even recommend it?
Tankman
Slow 'n easy. You'll find front weights are a must. :handgestures-thumbupright:
C-101plowerpower
tried with my c 101 4speed. didn't work in my case because i didn't have low enough gears and the roots were huge.
  • Like 3
DougC
When pulling bushes root ball and all from the earth if the soil is very dry and hard, soak the area around the bushes well with water and wait an hour or so. I learned that the hard way. I had good sized evergreen bush I wanted to pull out on a very hot, dry stretch of weather years ago. I had a 1973 3/4 ton 4x4 Chevy with a 500 gal. water tank full of water in the truck bed and a 25 foot log chain attached to the bush and rear step bumper hitch. An automatic transmission in low gear and gear drive transfer case shifted into low range......... I left some slack in the chain and mashed down on the gas pedal. When I hit the end of the slack, The truck instantly came to a dead stop, Some of the water shot out of the tank, went on and over the roof onto the windshield and hood. The engine cooling fan was now rubbing on the fan shroud making a terrible racket and the trucks motor mounts were broke......
The bush was still in the ground and the neighbors were laughing and pointing.      :confusion-confused:    I walked to the garage to get a shovel and a towel........
Please be very cautious. You dont want the tractor on top of you.....
  • Like 9
prondzy
Good one jason! I must have laughed for 20 min.:ROTF:
midpack
That's freaking hilarious!
Shynon
:text-yeahthat:
Thisguyisnew
Thanks everyone, I believe for the bushes that I got this would work but I don't think I'm experienced enough to try this at all. I don't have a truck so already used to digging and cutting. I'll just stick to that for now. Who's got another good video on something we should not, but do anyway. Hilarious
TDF5G
I've pulled very small shrubs from the ground after cutting them down a year previously.  I used B-100 8 speed with front and rear weights with turf tires & chains.  You have to be gentle and pay attention to what you're doing.  You can tug a little bit but don't over do it.  If a few gentle yanks will not budge it, then I quit.
The bigger bushes I had to pull with the 2500 Silverado 4X4.
MWR
Did you remember to say "Oh Yeah!! Watch This!!!" before you put her into gear?
Or maybe that is a southern thing.
  • Like 4
ClassicTractorProfessor
I thought the southern terminology was "Hold my beer and watch this!" :text-lol:
  • Like 6
WHX??
You beat me to that one Professor!
MWR
But if he had a beer, his insurance might not replace his motor mounts.  :text-lol:
953 nut
Did that once, hooked the chain, rolled forward and let the weight of the truck do the work. That bush popped right out of the ground; then I notices the 4" red clay tile embedded in the root ball. The nasty old boxwood I had pulled was right outside of the bathroom and I had just broken my sewer line in half. Took me a few hours to repair that!     :no:
  • Like 6
BOB ELLISON
That tree beat the crap out of him.
Dumbest guy I ever seen.
mabsoon
Wow! I about woke up the house on that one!!!
wasnt sure I was gonna stop coughing after the laughing!!!
And I mean that in a nice way :)
I actually tried to break my spleen a few weeks ago (not really) pulling down a way rotten tree. The top and side pieces came down but the main trunk stopped my 520 cold!!! And the steering wheel said hello to my gut..barely. I backed up on the seat and gave her another few tries! Yeah, thick head!
mels
Lay your chain over top of a log (just smaller in diameter than the height of where you're hooking to the tractor) just outside the hole you dug, then straight down to wrap around grab low above the root ball.  They pop up easier than they shear out.
coldbear
I put my wife on the 520-H with a chain and put tension on the root. I take the water hose to the roots a few hrs. before the removal As she is putting tension on the root ball, I chainsaw the larger root structure and that's the key. Without cutting those roots, you're asking for trouble. Transmissions can get expensive. I lost a good friend in the 80's when a chain broke.tugging on a Blue Spruce root. The hook hit him in back of his head and did him in. A young wife and 2 kids. Sad. .
  • Similar Content
    • mrodgers
      By mrodgers
      Looking for a Kohler K341 engine for my C-160.
    • RJ Hamner
      By RJ Hamner
      The C-160 just wasn't running right. Started with new points, plug, filters.
      I had put an aftermarket carb on it but had found a good Carter N in the correct size so I rebuilt it.
      Got it started this afternoon and had it running at about half speed to warm it up so I could make the final adjustment to the carb.
      It purred along for about 4 minutes and just quit.
      First thought was "out of gas".  Looked in the tank and sure enough it was really low so I filled it up.
      Tried to start it again .....NOTHING
      Went and rechecked everything ....NOPE
      Got out the can of starting fluid...NOPE
      Pulled the plug and noticed the gap was ZERO.  Re-gapped and tried again.  Same thing again no gap.
      Pulled the head.  Looked normal.
      When I cycled the engine I noticed that the exhaust valve didn't fully retract.
      Was able to remove the exhaust valve with two fingers!!!!!
      Guess I am in the market for a new set of keepers and a few gaskets.
      The guys at McHenry's Small Engine Love Me
    • tractorman99
      By tractorman99
      Hi everyone,
      I bought a wheel-horse c-160 a while back, and did some work with it.
      One day the rear axle housing broke:
      I was thinking about changing the part or soldering the broken pieces.
      Does anyone know where to order this part? Or has any idea of the potential cost of a soldering job?
      Thank you in advance!
    • RJ Hamner
      By RJ Hamner
      Picked up this C-160 a couple of weeks ago from Joe out in SW PA.  It had been on the Classified page for a while so I went out for a look.  Got her home and got a new battery, new plug, new plug wire and some fresh gas.  She purrs like a BIG kitten!  Drove her around the yard a few times and put her on the lift.  Got some of the parts I am going to need at the BS and some more from Jay in GA.  Wife told me I have to finish the all the trim work in her "home theatre" in the basement so......... I do get a few hours in.  After all, "Ya gotta let the finish dry between coats"
    • Mike_W
      By Mike_W
      Been looking for a C-160 Auto with Hydro lift for some time and an acceptable one finally showed itself on CL. Good runner. Needs a replacement seat and a choke lever. Also a battery mount. Anyone point me to how these batteries are held in place? A bigger (younger) brother to my 876
      I had a post on my 876 but I see the images are gone from the post, here is a picture, Love this tractor.
