tidewaterva
Need help with mower drive belt
tidewaterva
Hello everyone,
I am new to the WheelHorse brand- last year I purchased a 518-H as a backup to a zero turn mower and for mowing at some remote locations.  The 518-H has been repowered with a 20 HP Onan which appears to be a WheelHorse application engine.  The engine fits perfectly and runs perfectly also.  The deck drive belt is failing and appears to not be a correct size belt.  I have a 48" side discharge deck.  My question is- do I need the same belt as a 520-H with this deck would use?  Is the 20 horse engine pulley location any different than the original 18 HP?  The belt that was on previously was a 1/2" x 103" size.  It seemed to be too narrow and was bottoming out on the pulleys.  It was also too long.  I believe that a 5/8" by 100" belt would work, but these belts are pretty pricey and I don't want to guess.  Thanks for any help.
daveoman1966
The engine to deck drive belt s/b # 102742 which is 1/2 x 103".  I may appear to bottom out on the PTO but rides at correct height on the deck and mule drive pulleys.
Look at schematics of the deck model # to see the drive belt...not the tractor or engine model.
roadapples
:WRS:
cleat
So far as I know, the 16, 18, and 20 HP Onan's are physically the same size.
elcamino/wheelhorse
Welcome to Red Square , you are not that far away from me. The guys on Red Square are great and provide information that you can always use.
HokieAg07
Same belt between the different motors 1/2" x 103". Im just up the road from you in Sandston.
tidewaterva
Thanks for the welcome and advice- it could be that the sides of my old belt had worn down, allowing it to bottom out in the pulleys.  I will try a new 1/2" x 103 belt.  I look forward to checking in on this forum in the future.  I also am partial to Case garden tractors and have a 444 that I repowered with a Kohler K341AQS and a 646 loader with an Onan CCKA.
Edited by tidewaterva
Spelling
  • Similar Content
    • Evil Archer 300
      By Evil Archer 300
      Yesterday I filled the Rear wheels with RV Antifreeze, Got the wheel Weights on and mounted the plow. Today Grading the 1500 ft Driveway.
      I'm impressed the new Eaton 1100 pushed like a bear. The Hydro lift is great. For the last 12 years I've been doing all the work here with the 310-8. Huge difference,
      When I bought this Tractor it was in tough shape all rusty and no maintenance. After some sandblasting ,Paint and a new Hydro I love it
    • Evil Archer 300
      By Evil Archer 300
      I recently purchased a 1988 518-H. When I check the Oil level on a cold motor it is very high, If I bump the ignition ( without starting ) it goes to the normal level. Any Ideas
    • Evil Archer 300
      By Evil Archer 300
      31180EO1   1OO862
    • Evil Archer 300
      By Evil Archer 300
      New member here. Springwater NY I have owned my 310-8 for about 10 years, It's tough and very reliable.
      Last weekend I bought the 518-H. When I got it home it didn't seem to have the ability to climb the hill in my back yard. About a 15 degree slope. I found out ( A little Late ) Wheel Horse used 2 different Transaxles in these. Apparently I got the Eaton 700.
      Thru your sight and a very helpful Retired Wheel Horse dealer I changed the oil to a Synthetic. Seems 100% better.
      I am looking to replace Transaxle with a Eaton 1100.No rush.
      I do believe I got a great deal even with the 700 Tranny. Tractor with weights and chains, 48" side discharge ,42 Rear Discharge,48" Plow and a cart. $550
      The Tractor needs some work and a Paint job, But it runs well and mows great.
      Thanks for the help and keep up the good work
    • dwcphoto
      By dwcphoto
      Hi Folks,
        I'm back with another question on my 518-H (with the 520 rear).  I'm loosing some gas. It seems to seep somewhere and I'm suspecting it the seal where the gas line comes out of the bottom of the tank. Is this a fixable thing or do I need to get a new gas tank? It's real slow. I can't find a drip, but I can smell gas and when I go to add gas it seems like it's been leaking. thanks, d
