mjmccarthy85
New to Forum and thinking of buying D160
mjmccarthy85
Hi guys. New to the forum and really want a small garden tractor with loader. I came across this D160 but am hesitant to get into something that will be a headache. It does not have the 3 pt hitch or rear PTO. I know it need a cylinder repacked as the loader drifts down a little he said. He's offering it to me with the plow and some spare parts for $2100. Is this a good deal? Anything i should know before looking at it? May go pick it up tomorrow.
https://nh.craigslist.org/grd/5548998155.html
82Caddy
mjmccarthy85
Or I can get this one for $2500. Could really use some guidance.
1978 Wheel Horse D250 Tractor - Includes bucket, mowing deck, 2 sets of rear wheels and tires (turf tires and snow tires with chains). Excellent condition.
953 nut
:WRS:   We have a few "D Experts" who should be able to let you know what to look out for. The price seems reasonable on both of them if there are no issues. Some folks love the bigger D-250 and some hate them. Take the time to do a search of both on here and educate yourself before making the decision.
mjmccarthy85
Thanks! Okay Ill do my research. I get worried with anything that age and it's a good amount of money! But anything running with a loader seems to hold its value. I'm leaning towards the D-250 as it looks cleaner.
elcamino/wheelhorse
Have you checked the Forum Classifieds ? There have been some D series for sale .
mjmccarthy85
A little. I need something local. Any idea if I can hook up the mower and loader at the the time? If not is it because it wont mount or because they both run off the same thing? Ideally id like the mower on it with the loader and not have to take the loader off all the time to mow with it.
82Caddy
Can't mount both at the same time, at least with an ark loader on a d series.
mjmccarthy85
I ended up going with the D250. It is in amazing shape for its age. It starts right up and purs like a kitten. The deck had been completely gone through although he said the hydraulics to raise and lower are no longer there. So there is a rear pto but no hydraulic 3 point hitch either. Not sure if thats tied together. Ideally i'd like to set it up to have that so the deck raises and lowers. I havent mounted it yet because I need to remove the loader which I dont want to do yet. I was a little apprehensive since its much bigger than the "lawnmower with a loader" I wanted. But Im feeling better about it. For $2500 in its condition I think I'm doing ok. The steering is the only issue which he said is common. Had a lot of play however it doesnt like skip or anything. Of course with the loader and no power steering its not easy to turn. Hppefully thats better with the mower deck and no loader if I play on mowing with it.
Any suggestions on how to fix the steering and how to set up the raising and lowering of the deck?
 Here are some pics, I go the wider wheels with it (which I have put on) and the weight box which we just took of to transport.
Edited by mjmccarthy85
  • Like 7
elcamino/wheelhorse
It looks in real nice shape. Good luck with your new purchase. Now you need another horse to handle the mowing duties so you don't have to remove the loader.
  • Like 5
ericj
i like the mopar rally wheels on the back. nice purchase, someday i wouldn't mind having a D250 someday, good luck
eric j
mjmccarthy85
Thanks! So I've been researching for the past hour or so and having trouble finding info on the steering box. Is there any adjustment I can do? I see one for sale on ebay but its $300! Is there another one I can swa pwith from a different Dseries? Any info or links to anyone who's done power steering?
WNYPCRepair
Saw this recently. Re-powered and added power steering.
Not sure what his plans are for the old steering gear. @82Caddy  Edit: never mind, just re-read and his was shot too.
Edited by WNYPCRepair
82Caddy
The one I pulled out was junk. I can check my other parts tractor and see if it's any good.
Are the d-160/180/200 steering boxes the same as a d-250?
roadapples
I have the same loader on a C160 and love it, but I wouldn`t want to be switching it all the time. I`d get another for mowing. Seems these little horses like to multiply anyway...:) and:WRS:
Edited by roadapples
Ken B
I'm not a D250 specialist so I can't help you there. I think you did pretty good on the price, the loader alone can go for between 1500 to 2 grand. Has the tractor been restored at one time or is it all original?
mjmccarthy85
Im asking the guy on ebay to see if the one hes selling for the 250 will fit others. So I will let you know and thanks!
I dont think its been restored. I was told it was mostly a parade tractor and didnt get much use. Some things have been worked on. I got it off a youngrer guy who used it around his house for the past year or so on his projects. Im not sure who he got it off of but he went through the mower deck and I know he got the charging system to work he said. He was pretty knowledgeable about the tractor. He thinks something has been removed in terms of the 3 point hitch. Which makes sense because why a rear pto with no 3pt?
953 nut
As I understand it the D-250 is a stand alone model with little or no interchangeable parts from other Ds. Be sure the steering box is for the 250. One of the best things to improve your steering will be a lot of weight in your weight box. There is a thread on here about "Hard Steering" that may help you, just do a search.
pacer
Like 953 said, from everything I've read indicates that very little - if anything - is the same as the other D's. Dont jump up and buy anything before confirming.
FWIW, the other D's steering is a bit of a weak spot also. Its steering is by "Ross" which is an American co - which leads to another thought, the 250 wasnt even made here in the states so its box is likely different.
Very nice tractor!!
roadapples
I put 6 ply trailer tires that hold 70 psi on mine. Steers much easier, although will not fix loose steering...
mjmccarthy85
Here it is with the tires and doing my first little bit of work. Still worried about something breaking and finding parts. I'm not sure if I'll keep it too long after my projects are done.
  • Like 6
Reel Mower Freak
Beautiful house. Looking forward to the pics of the completed project.I see some top soil in your future.
Robert of Lake Michigan
I think if you decide to become involved with these machines called tractors that are most often 30 or more years old you can very well expect to make repairs on them no matter their purchase appearance.  The love is in the doing in this hobby.  Expect problems to pop up anytime.
953 nut
If you don't decide to keep the 250 there will be no problem selling it for what you paid.
TDF5G
I'd say you got the right machine for the job!  That's gonna be a nice project.
:text-coolphotos:
  • Similar Content
    • Crazy Old Red Horse
      By Crazy Old Red Horse
      Barn find 1975 D180. 608 original hours. Tractor and 48” belly mower look to be still in their original paint. Rear 60” finish mower looks like it has had one coat of new paint added at some point. Open to trades. Please email me with any questions or for additional photos. 35 miles north of Pittsbugh.
    • mkueb
      By mkueb
      I have an issue with my mid 1970's D160 garden tractor.   Plowing snow over the weekend it begain to make an awful grinding sound come from what appears to be behind the motor.  Once this happened,  all the hydraulic stop working and the forward reverse lever seem to be stuck in the middle position.   I shut down the tractor and was able to release the value on the pump and tow the tractor back into the garage.   When towing it back to the garage,   I noticed the rear wheel where moving ok (with the release valve open)  In the garage,  the forward / reverse lever will move back and forth.   I did attempt to restart the tractor again without any luck.  The sound seemed to be the same.
      I am speculating that I have a pump issue on the hydrostatic drive.   It' not the spline coupler with I know can spin out.   I did have this happen about 10years ago and at that time,  I removed the pump and had shop replace the shaft.   This time,  the shaft is definetly spinning the pump making a sound that I can only describe as a high pitch grind combine with what sounds like gravel rolling around inside of the a barrell.
      Does anybody out there have any advise?    Is there any checks that I can do to make sure it is the pump?  I friend has suggest lifting up the rear end and seeing if the wheels spin in opposite directions by hand (with our without valve closed?)   Is it possible that I may have damage something in the rear end?    I did notice after replacing the spline on the pump 10 years ago,  the tractor would still roll backwards with the value closed and the tractor not running.   I was not concerned at the time the tractor seem to move fine forward and reverse.
      I do use the tractor for many task.  I have the rotor tiller,  snowblower,  deck,  category 0 connection with back blade.   It's a nice little tractor and I would like to keep it running.   It has the Onan 16hp engine which I have only had to rebuild the carb back about 10years ago due to some lugging issues.   For the most part,  engine is good burns a little oil (I change it every month in the summertime), and runs best on 90 REC gas.
      If anybody has any recommendation for how to troubleshoot the most recent problem,  veryify it's the pump,  rule out any other possilbe rear-end damage, and possible recommend next steps,  I would be greatly appreciative.    Thanks  Marc   (FYI,  I live in Western Michigan between Grand Rapids and Kalamazoo).
    • Petes Horse
      By Petes Horse
      Getting my mess of a d160 rebuilt and found the source of play in my steering.
      This may also explain the oddball rim.
      Bottom race. Or is it races now?
      -----------------------If you don't like modded OEM parts go no further, there be carnage ahead!----------------------------------------
      So I went on a hunt for a replacement. Wow those are expensive. No standard bearings even close.
      Turns out 3/4 x 1-3/8 x 1/2 wheel bearings fit perfect because of their flange. Well almost. The ID is a little off.
      Adjustment needed. I already ground the lip off. I believe the lips were to hold the bearings for assembly.
      The flange of the bearing sits nicely in the adjustment cup.
      Looking down into the cup with bearing in it. Flange side down.
      Worm alignment with sealed bearing in cup on left. Same as new.
      The cotter pin hole doesn't line up but there is enough room to drill a new one.
      End view with bearing installed.
      To install both top and bottom bearings you have to grind or turn a good portion of the shaft and the lip on the other side.
      It's only .030 so not to bad.
      Both bearings installed. Fit nicely against the shoulder of the race on the worm.
      Worm alignment with both bearings installed. Old outer races removed. tightened snug. Still has full travel and is more centered.
      No way to install cotter pin. but my alignment cup was so tight it will not come loose. I'm lucky I got it out.
      End cap with both bearings installed.
      Hi-tech cap removal tool one ground down wood bit.
      The sealed bearings sit up against the shoulder of the race and the bearing flanges face away from the worm.
      The flange may need adjusting depending on who made it. There is no inner seal so it can be greased like usual.
      I'm not sure how they will hold up to thrust loads but for 6 bucks I'll risk it.
      I didn't grind near the original races at all so it can be put back to original if need be, minus some metal anyway.
      Welp, back to painting parts.......
    • Petes Horse
      By Petes Horse
      I've been looking for a while. The bolt holes just line up and the wire is a little tight between the fender and light. No drilling though.
      They were at Rural King. I think about three bucks each. Optronics MC42RS RED  Marker/Clearance.
    • 1977.d-160
      By 1977.d-160
      Hi again all,
      I was using my D160 to till some hard packed earth (first till) and it was working OK, not great, just OK.  First pass, was about an inch and a half, two inches at max.  The tiller would work, then stall and I'd have to lift the hydro to get it spinning again.  I did this a few times then the engine stalled and the starter would not strike.  The lights still worked and I could hear the elec PTO clutch 'click' when I threw the switch on/off.  I thought maybe I smoked the ignition switch, but I went out the next day and it fired right up.  I tried tilling a little more and same thing happened.
      What am I doing wrong?  Is there a thermal protection ckt or something that's causing this?  How can I till w/o overloading it?
      I've read in my 520H manual that you need to run the engine at full throttle otherwise you risk damaging the trans.  I assume that's true for the D160 as well?  When tilling at full throttle the tiller is really crankin'.  So ideally I could run the engine at about 1/2-2/3 throttle in order to slow down the tiller.
      Looking forward to the group's thoughts, feedback, opinions, advice so that I can till my plot!
      Thanks in advance,
      Jeff
