DownHome
choke
DownHome
Working on my newly acquired 855. When I pull out on choke I get the picture below. When I push it back in it stays in the same position. Do I need to replace choke cable? Thanks.
WNYPCRepair
Check that the metal coil/tube isn't moving when you move the lever.  It may be slipping
DownHome
Upon further investigation this is what I've found. Almost looks like the coil / tubing was burnt
WNYPCRepair
You will need a new cable. I can't think of any way to reliably repair that
DownHome
Where is the best place to purchase a new one? I'm a newbie to WH so I'm looking for reliable parts dealer. Thanks.
WNYPCRepair
Your part number is 5170. It is supposedly replaced by 102118. Google toro 102118, there is one on Amazon, Jack's small engines, and ebay (which is where I found the new part number, but it is almost double the price of the one on Amazon and Jack's. There are more, those are just a few I found.
Maybe someone here can confirm the new part number.
roadapples
I just purchased a universal choke cable at Lowes for $7 if you can switch the handle. Looks simple enough... and   :WRS:
Edited by roadapples
gwest_ca
Check the ground between the engine block and the battery negative cable. If it goes bad the current will use the throttle and choke cables as grounds and they can't handle the current without getting hot.
Perhaps you could move the negative battery cable to one of the engine mounting bolts. The starter is the largest electrical load the system will see. Then add a ground from there to the metal chassis for the lighter loads.
Garry
ol550
Battery acid got it. Have seen it before the coils rot away and the plactic liner gets streached and pulls apart.
  • Similar Content
    • WH1618speed
      By WH1618speed
      1965 Wheel Horse 855 with 42" blade and chains
      Runs good
      Sheet metal is very straight, great candidate for restoration.
      Missing Belt guard
      Will sell tractor by itself for $500 without blade and chains
      Blade is straight and lots of cutting edge left... just a little rusty.
      Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
      I can also deliver to the big show in Arendtsville, PA... IF you prepay.
      Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
    • admin
      By admin-(Admin)
      1 page 196.25KB
      1 page 82.24KB
      Dated February 17, 1965
      232613 Kohler belt nla Use 231605
      232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
      231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
      1964 model 854
      1965 model 855
      1965 model 875
      Starter/generator belt
      Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
      Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
      1964 model 1045
      1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
      1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
      1965 model 1055
      1965 model 1075
    • DownHome
      By DownHome
      Looking for belt specs for my 855. Need to know which belt I need to attach from motor pulley to mower 36" mower deck. Thx
    • DownHome
      By DownHome
      I've noticed that while driving any sort of elevation change, whether it's up a hill or down I start losing throttle. What type of fuel delivery issues could I be having? Occasionally it will even die out almost completely. Sometime if I mess with the throttle I can get it back on track but seems like i shouldn't have to fuss with it that much? Any thoughts? Thanks in advance
    • DownHome
      By DownHome
      I wanted to take a minute and document this new road I've started down. First off this forum is great. Everyone has been so helpful with my recently acquired 855. As I mentioned in previous posts i was originally given my Grandfathers 1054, this is officially my first Wheel Horse. This is the tractor I remember from my childhood. It is in rough shape though. I took this on as a project for my children and I for sentimental reasons I thought it would be great to get it running again. I knew the transmission was a problem along with some fuel delivery issues. As I worked out some of the fuel problems I started to shop around for a replacement transmission. I stumbled upon a 855 for sale somewhat locally on Craigslist. Single owner! It was not running when I purchased it a few weeks ago. Overall the 855 was in much better shape then the 1054 so I switched gears and have been working to get the 855 back up and running. Well that has been accomplished. I did some small things as a part of my troubleshooting. New spark plug, condensor, points, belt, fuel lines, new carb, and added an electric fuel pump. At first I thought I would get it up and running and then repaint it but the patina has grown on me and after reading some other posts i picked up some Penetrol and Johnsons paste wax. So this is the approach I will be taking. Below is a picture from the Craigslist listing. This is my starting point.The other picture is my first spin around the yard. As you can tell I was very happy to get it moving again. I will try to add more pictures as I bring this back to life.
