ztnoo
Recommendations for woodruff key suppliers?
JPWH
I was in a local Toro dealer last week and they had a box of woodruff keys of all sizes. I will be back in there when my pulley bolt gets in would you like me to pick up two for you and send them?
ztnoo
Hank01,
If you would care to check to see what the dealer might have, I'd be happy to compensate you for whatever the parts and shipping costs total.
They would have to duplicate the dimensions listed in the pic below to be the correct woodruff keys for my GT 14 axles......and of course, .25" (1/4") thick.
Steve
56e5c9fe2b973_IMG_0523keydimensions.jpg.
JAinVA
There is an E-bay listing currently for d200 axles that claim they are 1 1/8" and they appear to have 2" long keys.This makes sense.The taller tires on the GT14 and D series
require more torque to move the tractor.To keep the woodruff  you would have to  go to a bigger diameter cutter to increase the effective engagement lenghth of the key to hub.You could do the same thing by using a straight key but the tooling setup would be different than plunge cutting with a woodruff key cutter.If this makes sense then it
would be a simple and inexpensive upgrade for the manufacturer.Its all about pennies when dealing with manufacturing cost.Luck,JAinVA
Edited by JAinVA
ztnoo
I've been thinking about this xxx xxxx woodruff key question at length......if for no other reason than it concerns what I'm doing and attempting to find parts for.
However, I think the information I'm generally poking around trying to find has relevance and can be applied to other applications.
I believe what JAinVA theorized about concerning wheel and tire size has enormous relevance.
Essentially the larger the radius, and by implication, diameter, a force is applied/transmitted through, the greater the loading on the turning axis.....it's the torque factor at work.
Thus, perhaps the need for increased woodruff key sizes as overall wheel/tire diameters are increased, especially as larger, higher hp engines were installed.
Is this a reasonable assumption on my part?
umm.gif.aaddcecffaf5df3864ca4a21ab162c66
OK, I know its VERBOTEN to list links specifically to other sites attempting to sell items.
However, I know of no rule or prohibition against providing specific search parameters, or a seller's name, for that matter.
So, given some inspiration by JAinVA, I went to xxxy, and searched around at length, concerning WH axles of 1 1/8" listed for sale.
After inputting "Wheel Horse rear axle shaft", several options were presented to me.
I recognized one of the sellers because within the last month or so, I have purchase spare GT 14 axles from the same tractor from this seller.
When I inputted the seller's name of "mattverdill" into the search, I was rendered WH axles he currently has listed for sale.
Imagine that!
This seller.......who is not linked, I would point out, has six 1 1/8" axles sets for sale. These axles were removed from the following tractors:
14 hp Automatic
D-200
416H
C145
C125
C120
Visually, because no key sizes are given, ONLY the D-200 woodruff keys (still shown in place in the axles) match the GT 14 woodruff keys.
All of the rest of the woodruff key appear to be smaller......I lay money on the table that they are smaller.
Curious how no one seems to know much about this topic of BIG WOODRUFF KEYS.
Hopefully I'm contributing to the knowledge base here at RS.
Steve
Edited by ztnoo
JAinVA
Steve,
     You went to the same source I looked at.I did some quick scaling on the screen and came to the conclusion that the D200 keys were the same length as the GT 14 keys.
This makes sense as then the dealers would have fewer part types in stock.Based on the need for increased engagement length WH went with the most economical way
to do it.This might not help you get the key you need but at least there  IMHO  is a reason the keys are different.Luck JAinVA
JimAnderson
Gloucester,Va
Martin
From what I remember when rebuilding my 1054, The 953/1054 axles use the 2" long key as well. The 953/1054 and GT14 hubs look the same to me. They are also significantly longer (cover more length of the axle) than any of the standard size 5 bolt hubs.
Edited by Martin
  • Like 7
JAinVA
Martin,
    I am not well versed on WHs pre C series so forgive the dumb question.What's the tire sizes on the 2 models listed.Do they have 15" rims.
JimAnderson
Gloucester,Va
Martin
The 953 and 1054 used 15" wheels. 6.40-15 tires- you can just see the size in the left tire in pic above.
Edited by Martin
ztnoo
My GT 14 four lug hubs have a bore length 4 5/16" + or- into which the axle is inserted.
A very considerable length which contributed greatly to the resistance I encountered attempting to remove those monsters 35 years after last being removed...
Martin
yes, I remember all too well the holding power of those long hubs!!
Edited by Martin
  • Like 4
ztnoo
It's good to know I'm not alone in my angst and misery concerning these hubs.....
But I am over the hub torture now, and focused on these mysterious woodruff keys.
gwest_ca
You could order the 937046 key from Toro.
Garry
ztnoo
Garry
That's interesting info, but I don't see any description of the key dimensions when using that part number.
Without the dimensions being given, how does one know this is the correct part?
How do you know this is the right part?
From what I've seen, this pretty well defines the extent to which Toro goes to describe parts. The same seems hold true for RCPW. All one gets returned is "woodruff key" with no specifics.
Am I missing something here? How do you know this is the key I'm looking for?
What's really odd to me is that the woodruff keys aren't even shown in the original illustrated parts diagrams or listed in the numbered parts lists.
You wouldn't even know that part is used in the assembly from simply examining the illustrated diagrams.
That's what lead me to believe it was generic, non-proprietary part from the day the machine(s) were manufactured.
On top of that, the pricing Toro lists for this part is significantly more than any other source I've run across so far.
Regards,
Steve
gwest_ca
I think we only have two original parts list for the GT-14 and they are for the same model number.
The Woodruff key 937046 is illustrated on the page showing the rear wheel/tire and hub.
If you go to a D-Series Automatic parts list it is also shown on the parts list only for the rear wheel/tire. No item number.
1054 also used it and shown on the transmission page.
Some online lists show it used on a Lawn Ranger because Toro messed up and have D-Series Auto parts listed for that particular Lawn Ranger model.
Toro is proud of their parts and charge accordingly.
Garry
ztnoo
Garry,
I will concede you are right.....those woodruff keys are in the diagrams and in the numerical parts list.........I just plain missed them. Duh!
I will agree wholeheartedly TORO is extremely proud of those woodruff keys when they are priced at $7.30 eachhttps://www.torodealer.com/en-us/Pages/Search.aspx?k=937046
RCPW is nearly as proud of their keys also, when priced at $6.31 eachhttps://www.rcpw.com/search/?quest=937046
The good news this morning for me is Fastenal finally shipped a sample key to a local store within my county which I picked up and just verified it is the same key as OEM, and it fits perfectly in the axle key slot.
Price including 7% IN sales tax: $1.31 each.
More detail to follow later.
Steve
Edited by ztnoo
JAinVA
Steve,
   Pays to shop around.Sounds like you are on your way.Luck,JAinVA
JimAnderson
roadapples
For that price you might want to get a few more and squirrel them away..:handgestures-thumbupright:
Martin
Just another example of good shopping around. I used to support my local Toro dealer all the way, but some of the prices just made it an expensive proposition when rebuilding a whole tractor.
I have learnt that its better to seek out the original manufacturers for a lot of these parts, Toro and Wheelhorse before them, didn't make everything. They used oem suppliers just like lots of other companies. I have found some real bargains by finding out which company made the part or had the contract for the part. Sometimes, its just a simple process of looking at the manufacturers name stamped or molded in the part and google searching. You would be amazed at what bargains can be had over Toro pricing.
One such example that comes to mind is the rubber hood catches on the 3,4,500 series and many other 80s and 90s Wheel horse models.   http://www.wheelhorseforum.com/topic/43225-416-adventures/?page=14#comment-438994
  • Like 6
ztnoo
Gentlemen,
Well, I knew these parts had to be "out there", it was just a matter of researching and pounding the keys, and to some extent the pavement to find them. Woodruff keys are a generic hardware type item, maybe not quite as everyday items as flat/lock washers, lag bolts, and 16d common nails, but widely used. Not being able to buy exactly what you need at your hometown corner hardware store, doesn't mean they are "unobtainium", you just have to keep digging until you uncover the Mother Lode.
The Fastenal connection is without doubt the best choice for a supplier of these keys I have yet found, mostly because of their huge geographic reach with "2,700 stores spanning all 50 states and 20-plus nations".
The beauty of this is most of the population here in the US have a Fastenal retail outlet within a reasonable distance of wherever they live. I have one within 1 1/2 miles of my house, and another about 10 miles away. So for me, is like going to Vegas and seeing how the dice roll......if things aren't working in one game room, I pick up my chips and go to "the other casino".
If you communicate with a local store and they don't have the item you are seeking in stock, they'll get it shipped from another Fastenal outlet or warehouse to your local store. From what I can tell, shipping cost me absolutely nothing. I think this is true with a least items of reasonable size and weight......thus I avoided the dreaded shipping charge, which, as many of you know all too well when you buy from Toro, RCPW, eBay, or almost anywhere, which is the real "bummer" part of any deal. If you don't need much in the way of quantity or total cost, often the shipping and handling charges exceeds the cost of the items being purchased. I don't know about the rest of you, but I get absolutely steamed and go into a slow burn when that happens. Sometimes it's just absolutely ridiculous, but often you have no other options if you have to have the item. What's WRONG with this picture?.......you can buy almost anything you want, need, or could ever hope to find here in the continental US, but when shipping charges exceed purchases by sometimes as much as 3 times, there's either gross inefficiency ruling the day to cover glutenous infrastructure, or obscene and unashamed profit taking occurring.
Just my twocents.gif.cfc9fdc90a98d97cc01a525e6e3, and one man's option.
Anyway, I'll dismount my speech-making soapbox, relinquish my bullhorn, and present the facts......"just the facts, Mame".
1/4" x 2-3/4" Key No: RX Woodruff Key
Fastenal Part No. (SKU): 69352
Grade:1035
Key Number:RX
Length:2-3/4"
Material:Steel
Style:Half Moon
Type:Woodruff Key
Width:1/4"
Product Weight:0.064 lbs.
https://www.fastenal.com/products/raw-materials/keyed-shafts-keys/woodruff-keys?term=woodruff+key&r=~|categoryl1:%22600930%20Raw%20Materials%22|~%20~|categoryl2:%22612385%20Keyed%20Shafts%209and%20Keys%22|~%20~|categoryl3:%22601145%20Woodruff%20Keys%22|~%20~|sattr03:^1/4%22$|~%20~|attrlength:1610|~
IMG_0553a.jpg.a4de15a3cc6f71694f24d183a1  IMG_0554a.jpg.881132902b420b48d044bbcefb
Left: OEM installed woodruff key, left axle   Right: Fastenal supplied duplicate woodruff key, # 69352
IMG_0558a.jpg.6fa3920658294d693717ef3a9a
Find your local Fastenal store here:  https://www.fastenal.com/locations
Any questions, Gentlemen?
Regards,
Steve
wavetowel2.gif.ee2e90dedbb02c422884fcfa3
Edited by ztnoo
  • Like 6
Aldon
Nice. While I don't need any currently, for that price I snag a couple the next time I go into Fastenal for something as a just in case item.
ztnoo
Mr. T,
I told you I was a researcher who often focused on minutia.
Hopefully this has been a beneficial exercise for the good of the forum membership.
My advice is to call, and order before showing up at the store unannounced, on the spur of the moment. SVP.
That might avoid some aggravations.
From prior experience,
Steve
2tu.gif.157c3b2d26ede2808b049cbb040d84ed
JAinVA
ztnoo,
          Thanks for sharing the quest with us all.I would never have believed that something as simple as a woodruff key would generate this much interest or discussion.I guess it proves that its the little things in life that matter.I look forward to seeing your future posts here and am truly happy that you got  your Moby Dick after all. Luck,JAinVa
JimAnderson
Gloucester,Va
Edited by JAinVA
ztnoo
I had a very large harpoon, a steadfast captain, and my aim was true......the rest was totally instinct......
Thank you very much for your positive reinforcement and kudos.
I am a very happy camper this evening.
top.jpg.f3cfcc0aec62a1aac99c35757e8d45ea
JAinVA
Kindred spirits thanks for sharing.JAinVA
Edited by JAinVA
ztnoo
Addendum to the woodruff key search:
I'd like to comment on another source for these woodruff keys, but unlike my Fastenal "find", this one proved not nearly as rosy and positive in the end.
While I was in the midst of gyrations getting a sample woodruff key shipped to one of the two Fastenal stores in my county to be able to physically compare with my one good woodruff key, I ran across another promising looking source with the G.L. Huyett company of Minneapolis, KS.
Aldon had pointed them out in a thread, but I had run across the web site earlier in my search for the monster woodruff keys I needed.
I was astounded by the huge variety of hardware and goods the company listed. It was quite pervasive in its selection of materials.
Have a look for yourself, I think you will be impressed.........  https://www.huyett.com/
So over the weekend, still not knowing anything definitive from Fastenal, I took a leap of faith and ordered two keys because I was 99 44/100% certain what Huyett listed would work for my application.
https://www.huyett.com/Products/Power-Transmission/Machine-Keys/Woodruff-Keys/WKA-0RX?searchText=
Price: $1.3141 each.
Sounds petty good, eh?
I ordered last Saturday, March 12.
Let me preface the rest of my story with a well known Roman phrase, caveat emptor. Of course this is defined as "Let the buyer beware". This is a concept that most people are cognizant of and typically attuned to watch for.
* The phrase caveat emptor arises from the fact that buyers typically have less information about the good or service they are purchasing, while the seller has more information. The quality of this situation is known as 'information asymmetry'. Defects in the good or service may be hidden from the buyer, and only known to the seller. https://en.wikipedia.org/wiki/Caveat_emptor
Never having ordered from the site before I didn't know exactly how the checkout procedure would go, but I went with the flow assuming at the end of the process I'd get a totaled price, shipping included and based on my zip code, then I could decide to hit the "Buy" button or not. Well that didn't happen. As a matter of fact, I didn't even get the typical quick automated email acknowledging my order of two woodruff keys with all the pertinent charges. I thought that was a bit strange at the time, but I saw nothing else I could do at that point. A little unusual. Now I see why.
So, Monday morning I get an email with a pdf attachment described as an "Order Acknowledgement". In that document was my order for the two keys which totaled $2.63, but additionally attached was a "Small Order Handling Fee" of $10.00.
I thought that was a little on the excessive side, but again at that point in the process, I obviously had no control or say over that charge. So, I 'm thinking well they'll stick those keys in small mailing envelope, send them USPS, and I'll probably have them about Wednesday, March 16.
So today, March 16, I get another email from a different Huyett employee, with a pdf  "Invoice" attachment. Within this document are the above charges PLUS a freight charge (UPS) of $10.50! Say What??? You gotta be kiddin' me!
Turns out Huyett has lots of legalese and small print which isn't readily apparent to or made known to a first time buyer in particular. I never recall seeing it anywhere in my ordering procedure.
So, the short story is that Steve got the short end of the stick and the joke is on him. The two absolutely wonderful Huyett keys are now costing me the grand sum of  $23.13, or $11.56 1/2 each!
I find that outrageous and repulsive, to say the least. I feel like I've been raped. It was the process and it's secretive nature I feel is what was abusive and underhanded. If the true cost information had been provided to me up front, I never would have ordered from The Hardware Highness G.L. Huyett. They also made no effort to use the cheapest means of delivery, which I find ridiculous.
I am appalled and made my feelings known to several email addresses at Huyett, including the CEO. I received a cursory reply from a company vice president which did nothing to rinse the rancid taste from my mouth of dealing with this company. It kind of reminded me of all those legal documents Microsoft and all of the big software and hardware developers make you affirm for the right to use their products........the documents that will take a couple of hours to actually read and maybe comprehend, if you are lucky.
Live and learn, sometimes the hard way.
Needless to say, I'm done with G.L. Huyett.
If any of you here choose to give them a try ........all I'm going to say is "caveat emptor".
Once the keys arrive, if they don't fit, I'm really going to be ticked off....as if I'm not already.
Steve
Edited by ztnoo
  • Similar Content
    • ztnoo
      By ztnoo
      Not sure this is in the right category, but here goes anyway.
      I have a hydraulic fluid leak problem which originally WAS NOT particularly noticeable or troublesome.
      Now is would be better described as a HEMORRHAGE.
      Some of you may remember me doing battle a year ago last winter with the rear hubs on my GT 14 to originally correct an issue with one which had slid inward on the left axle.
      In the course of that adventure, it was mentioned to me that might be an excellent time to replace my 47 year old axle seals.
      They were leaking somewhat, but were not what I would describe as an emergency or huge fluid loss problem.
      I decided since it was the middle of winter and I was messing with the hubs, the suggestion made perfect sense to do some preventative maintenance at a leisurely pace given the time of year.
      So I was able to complete my horrific hub removal/woodruff key battle, but managed do the axle seal installation without major drama.
      I had completely drained the tranny prior to axle seal removal and upon installing the new seals and a new tranny filter, filled with fresh Type A tranny fluid.
      During the middle of the mowing season last summer, I began to note my hydro ground speed response was a bit sluggish and slow.
      After checking the fluid level in the tranny, I noted it was low.
      The system is a 4 quart system and it required over a quart to bring the fluid up to proper level.
      I checked around a different locations of the hydraulic system for some obvious telltale signs of loss.
      The new axle seals looked great, no loss there. The hydraulic cylinder looked OK from what I could tell after hosing the area down and running it again after cleaning. Didn't appear to be any significant or apparently loss there.
      The hoses looked OK with no cracking or splitting, and their fittings seemed to be leak proof.
      However after running the tractor for a while in a stationary position and using the control valve which lifts and lowers the mower deck, I could detect leakage out of the top of the valve. The leakage was only coming from the top of the control valve in the area immediately below the valve lever itself.
      My assumption is since I replaced the axle seals and stopped any fluid leakage in those two locations, potential leakage problems in the hydro system have migrated to the next weakest point.........in this case the control valve (#8363).
      Unfortunately, I did not attend to this problem last winter as I should have (DUH!), being aware of the problem.......which of course continued the remainder of the last mowing season.
      So..........guess what? The problem for some reason has not resolved itself without my engagement over the winter. And now its mowing season.......and in the two mowing sessions I've done since getting my mule drive problem and deck gauge wheel axle support problems resolved after running over a 3/4" steel form stake, the leaking/hemorrhaging control valve seal is only getting worse. I once again added over a quart of Type A fluid before my first mowing this year to bring the fluid to proper operating level.
      I know it needs fixed meaning new internal seals need to be installed. The problem is how to get to the control valve to remove it or manipulate it in some fashion to install the seals on the spool valve and get it reinstalled in the control valve body without tearing the tractor half way apart.
      Lots of older WH tractors have the hydraulic control valve on the outside of the hood stand or some side area of the tractor generally on the left just forward of the the seating position and under the dash area, which would make servicing the spool valve a relatively simple procedure.
      Not so with the GT 14.
      The control valve is located between two tall, heavy gauge "C" shaped steel panels which sit on top of the frame rails.The hood stand mounts to these "C" channel members. There is about 5 1/4" of width between the C channels......not a lot of room for a guy with big hands and fingers to operate.
      My primary question is can the control valve and its primary operating part, the spool valve which has two seals, be serviced without completely removing the valve body from the tractor???
      Is it possible to manipulate the valve after removing the mounting bolts from the right side C channel in such a way to gain access (the spool is removed from the bottom side of the valve body by removing a snap ring), either from the top or the bottom of the tractor to successfully remove the spool valve from the valve body, replace the seals, and reinstall the spool valve in the body of the valve without removing all the hoses and completely removing the valve from the tractor?
      Without the tractor running, will there still be residual hydraulic pressure in the lines and in the system in general which would cause fluid to spurt out once a component is removed.........a hose or the spool valve itself for instance?
      The control valve is WH part # 8363 and I see that Lowell Scholljegerdes (wheelhorseman1000) has a seal kit for resolving this leakage problem with "Control valve seals #7788". The seals are very reasonably priced and readily available and will undoubtedly fix the tremendous leakage at the top of my control valve.
      https://www.wheelhorseman1000.com/product-p/00123.htm
      The problem is what all is involved to get to the valve for the repair and how long something like this might actually take to get the tractor back in service?
      One of my big concerns is the hoses which are now 48 years old. They show no signs of leakage now, but I fear if I start manipulating and moving them around too much messing around with the control valve, I'll create a whole new dilemma.
      The big problem is its right in the critical time of year for mowing season here in Indiana, and with the mass quantities of rain we have had the last week or so, once it turns 75 or 80 or more, I'm going to need to mow twice a week just to keep up. Since my GT 14 is my only tractor and my prime tool for mowing, I just can't afford to have it down for a prolonged period this time of year.
      If there's not a decently quick and reasonably simple removal procedure someone can suggest, I may just have to continue to keep the fluid level up in the tranny and control the mess of the leakage around the top of the valve as best I can until a drier time of year when mowing isn't a pressing twice a week issue. I might even have to just grin and bear it and keep adding fluid until mowing season is over in the fall. That assumes of course the hemorrhaging doesn't get disastrously worse than it already is.
      I'm anticipating once this particular leakage issue gets resolved, the next weakest spot in the hydro system will show up, but first things first.
      Any suggestions or words of wisdom anyone has to offer about this repair, I am completely open to listening.
      Thanks,
      Steve
      p.s.  I've attached a few pics below of the control valve and the affected area which is leaking for your reference.
      leakage area circled
      ***  Updated Addendum: June 1, 2017
      See my last post dated June 1 on page 2 of this thread.
    • ztnoo
      By ztnoo
      I've been looking for a replacement small General Motors pickup from roughly 25 years ago in reasonable shape for 4-5 months.
      After reviewing untold numbers of CL listings during the period, I ran across what looked to be a reasonable mileage example in good aesthetic shape within a reasonable driving distance from my location.
      It was listed on CL in Louisville. Not exactly the next county over (a three hour one way drive), but a good enough prospect, I decided to take a day road trip
      3hr 2min, 187 miles, per Mapquest.
      I was thinking.......OK Steve, you are wanting to drive to Louisville to look at a vehicle, so what if I couldn't find anyone (a local friend/neighbor) available on Saturday to go with me?
      Three strikes and I was out. Bingo. Reality sets in.
      My theory was, if it was something I really decided I wanted, I needed to get it out of Louisville THAT day. But with no drafted co-driver, I had a definite problem.
      In a eureka moment, I remembered Chaplain Manny, who I had never met, but with whom I have conversed extensively, not only here at RS, but on various WH FB sites, and by email as well.
      Manny was raised in Louisville, so I instinctively knew he would be an excellent guide and pathfinder in a metropolis I had no familiarity with, other than passing through on I-65 to go to Florida.
      So, I messaged Manny on Friday with my situation and proposal and asked if he would be available to assist me for a few hours on Saturday. He now lives east of Jeffersonville (across the river from Louisville, in Indiana) in a very small rural town.
      He replied and told me he was available to help me, given his wife and young son were away at a wedding he wasn't attending.
      I explained the situation generally, and to my amazement and luck, Manny agreed to help me go into Louisville on my long bed S-15 quest.
      I arrived a little after 9 am at Manny's residence (following a three hour drive) and Manny proceeded to guide me into the bowels of Louisville.
      Traffic was horrific for some reason on Saturday morning on both southbound bridges over the Ohio River into downtown Louisville. Manny speculated there had to be some big event going on downtown that morning, but we never did learn what it might be. I would have definitely lost my cool sitting and waiting for traffic to start moving and the stress of trying to navigate the unfamiliar interior of a major urban jungle. But Manny took it all in stride and we eventually maneuvered around the bottlenecks and we got to the desired address in an area of town known as Germantown.
      So the short of it is, I bought the truck because it was in excellent shape for a 1990 model with reasonable mileage given its age, and Manny drove the station wagon while I followed in the S15 and we went back north across across the bridge over the Ohio River leading the way back to his place east of Jeffersonville. Generally speaking, the theory "move your feet, lose your seat" applies to CL items, because they can move very quickly and you usually have to have your ducks lined up and be ready to act promptly, or there's a high risk of losing your chance. With Manny's help and assistance, I was able to achieve my goal.
      Manny let me park the truck at his house until I can draft a friend into a day road trip to go retrieve my little S15 jewel later this week. When we got back to his place and he showed me his Wheel Horse collection and ongoing projects and we philosophized about life a bit before I left.
      Manny is a great caring and helpful person with a warm and outgoing soul. He has considerable health issues for a male of 56 years of age, but he does his best not to allow that to distract his quality of life and daily routine. I now consider him to be a friend and buddy and not just a correspondent........having met through our mutual interest in Wheel Horses, GT 14s in particular.
      Steve
      ___________________________
      Manny & me.
      Manny in front of my purchase.
      My "new" S15.
    • ztnoo
      By ztnoo
      I've discovered the main engine pulley driving the hydro pump seems to be a bit loose.
      I need to pull the clutch and associated pulleys off to have a look at what's going on back there.
      May be just a loosened allen screw mounting the pulley, a bad key, a bad pulley bore, or some combination of all three.
      Is the clutch mounting bolt going into the crankshaft a right hand thread, or a left hand thread?
      Anyone have a quick answer?
      Steve
    • ztnoo
      By ztnoo
      I have a Kohler K341 on a GT 14 tractor.
      Its always had the typical .....what are they called?........pepper shaker muffler? on the tractor.
      I've had to replace them several times....they seem to just eventually burn up.
      I can honestly say even from day one whenever I installed a new muffler of this type, I really couldn't tell that it really muffled much noise, maybe a little, but very little.
      As usage time goes on, they all got nothing but louder.
      Of course, part of this is the sheer displacement of the motor......35.9 cu. in. = 588 cc. Think of it in terms of a slightly bored out Norton Manx 500 cc thumper with an open megaphone exhaust. Deafening! You don't want to be standing 8 or 10' behind a Manx when it being warmed up and the throttle is being "blipped" to do that, without ear protection.
      These older flat head engines seem to be much louder than the newer OHV engines which are common in lots of equipment now.
      I've owned and used this tractor for 35 years now, and I guess I'm beginning to become somewhat of a crotchety old senior, but its becoming annoying to me (the operator), and I in fact had one neighbor that ragged me out over the noise.
      It may be because they have a pool and spend a fair amount of time outside, and the pool is about 10-11 feet from a chain link fence that divides the properties.
      I'm really not that worried about the neighbor nearly as much as I am myself, or should I say my hearing.
      I already have hearing loss from years of firing pneumatic nail guns and listening to compressors and heavy machinery running on job sites.
      What are you other K341 owners using and doing to get more muffling accomplished?
      Surely there has to be a more reasonable solution which will allow you to hear yourself think after an hour or hour and a half of operation.
      Is there a viable, positive solution for this problem so my ears and head don't ring for an hour after just mowing my lawn?
      Regards,
      Steve
    • ztnoo
      By ztnoo
      As many of you know, I've been in a prolonged battle with the rear hubs, woodruff keys, and oil seals on my 1969 GT 14, Model # 1-7441.
      I'm to the point of installing the new SKF oil seals today as soon as I can round up one more PVC fitting to properly size it to my seals for tap in installation.
      After that, its spin on the new NAPA 1410 hydraulic filter, and then fill with ATF.
      When I drained the tranny, I measured and computed the volume of ATF taken.
      It was right at 128 oz. + or - maybe two ounces. The volume spec says 4 qts. (4 qts. = 1 gallon = 128 oz.)
      So I know I was within spec, and wasn't losing large amounts of fluid, although I have a couple of random minor seepage locations on the tractor.......mostly around the control value which raises and lowers the mower deck.
      ATF is always what has been in the tranny, so that's what's going back in.
      My reason for caution regarding what to use specifically is probably more a matter of jargon and my understanding of terminology than anything.
      Of course, since my GT 14 was a first model year tractor, Type A transmission fluid was specified in all the literature.
      Type A is no longer available, but it my understanding is that equates with Dextron II.
      But isn't Dextron II now an outdated designation?
      If so, what should I be putting back into this Sundstrand  90-2062 tranny to ensure continued adequate trouble-free lubrication???
      I have more than a little angst over wanting to make sure I used the right product in this transmission.
      The changes in products over the years makes it very confusing for those of us who only occasionally wander in and out of discussions like this and automotive/mechanical related jargon and word usage generally.
      So gentlemen, what are your specific recommendations on tranny fluid to use in my Sundstrand, and is there any particular brand any of you favor over another?
      Or is it pretty much the case that ATF is ATF is ATF, the world around?
      Looking forward to your suggestions and recommendations.
      Regards,
      Steve
