Ernie1990
custom exhaust help
Ernie1990
Hi i am new here and not familiar with hoe to navigate the site to find what i am looking for.
I am thinking about doing some exhaust work on my c100 since the factory muffler is starting to rot out. I want to keep the same route of the exhaust but straight pipe it with a chrome tip that has a little turn out to it. I have heard that straight piping these will cause valve issues etc so i was thinking about using a trick from the motorcycle world and using a since strainer in the exhaust tip since it will create back pressure and in the adapter from 1" to w.e. for the tip, drill a hole and use a bolt washer that blocks off 70%ish of the flow as well. I would think this would cause enough back pressure and reduce the noise a lot as opposed to just straight pipe.
Ed Kennell
Same post started 16 hours ago  ????
Ernie1990
Sorry. Phone was acting up.
Ed Kennell
No problem, one of the moderators will probably delete it when they see it.
Ernie1990
I would delete it if i could
  • Similar Content
    • Ernie1990
      By Ernie1990
