Red308
What model snow blade is this?
Red308
Hello! I purchased a WH 308-8 with a snow blade and a mower deck. I have the manuals for the mower deck and the tractor but I have absolutely nothing on the plow. It has a 42" blade and I think the frame is 56" from the end to the pivot point. I have found lots of information on similar blades but I have been unable to figure out exactly what model mine is. I am asking simply because I am curious. Thanks in advance!
P.S. It doesn't work real well on the 308-8 as I currently have it. I think I might be missing a piece.
gwest_ca
May be this one?
Garry
wallfish
:WRS:
That is for a short frame tractor from the mid to late 60s. Your tractor is longer.
Edited by wallfish
Red308
Thank you Gary and John!
The fact that it is for a short frame tractor explains a lot. :)
I thought it looked the most like the BD-426 as well. What interests me is the extra cross brace.
  • Similar Content
    • Mattgray
      By Mattgray
      I am looking for a snow plow in the Western NC area, might be a long shot but iv checked marketplace and craigslist. No luck. if anyone has one or knows where I could get one. I believe I need a long frame one for my tractor. Thank you!! sorry if I posted this in the wrong spot. One year after owning my wheel horse and still running strong!
    • Trouty56
      By Trouty56
      Tractor vs. Implement cross reference chart for models from 1955 - 2000
      110 pages 513.43KB
      This chart lists the original attachment model
      The model that replaced the original model
      The model that was available when the list was made
      Often many models between the last two are not listed.
      You must go from year to year and follow the model numbers to see them all.
      For a complete list of models click on the magnifying glass in the Search box. Enter DNA in the Search box and select Files from the drop down menu. Two pages of 33 results will come up in random order. Find the attachment you are looking for and click on it. The DNA for that model of attachment will come up. Look for the model of your attachment in the DNA list. They are organized from earliest to latest.
      OR
      Search the Files using a model number you know will work. Look through the results for DNA in another file name for the same item. That will have the full list of models.
      STD for a model indicates that attachment was standard equipment that came on that model of tractor.
      Mistakes in the online attachment list @ Toro. The Attachment Interchange is correct but confusing and the source of the mistakes.
      1970 *VS           rear discharge mower deck                             5-7362 is correct replaced by 5-0610 both CCW rotation
      1971                  rear discharge mower deck                             5-0600 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 rear discharge mower deck should be model 5-7362 - CCW spindle rotation
      1972 *CG-7 & 8 rear discharge mower deck should be model 5-0610 - CCW spindle rotation
      1973 *VS           rear discharge mower deck should be model 5-0611 - CCW spindle rotation
      1970 *VS          side discharge mower deck                             5-2365 is correct replaced by 5-0700 both CCW rotation
      1971                  side discharge mower deck                            5-0710 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 side discharge mower deck should be model 5-0700 - CCW spindle rotation
      1972 *CG-7 & 8 side discharge mower deck should be model 5-0701 - CCW spindle rotation
      1973 *VS           side discharge mower deck should be model 5-0702 - CCW spindle rotation
      1974 Replacement rear discharge mower deck for the model 5-0622 (side discharge) is wrong - should be 65-36XR01
      *Models using a vertical engine crankshaft
    • Marc M.
      By Marc M.
      Hi guys I'm new to the wheelhorse world and i recently picked up a for 416-H and I'm looking to buy/install a plow put on it. I have found one on craigslist but I can't tell if it will work on my tractor or not, it is a wheelhorse plow though. Can somebody please send a photo or even a video of how to hook up a plow to a 416 or equivalent tractor?
      Attached is my tractor and the plow I'm looking at. Will it fix and what's it missing ?!
    • MartinSweden
      By MartinSweden
      Hi,
       I bought a C 120 model with a snowblade  from an old lady. However i can't figure out how to to assemble the snowblade in the front of the c120-machine. I guess I am missing some sort of an adapter? It doesn't look like a standard blade according to pictures I've seen where you assemble a steel frame under the machine.  The lady don't know how her husband used to assemble it. Does anyone have a picture/instructions how to assemble it and a picture of the assumed missing adapter (if needed)? I guess i need to go back to her barn and start looking for missing parts.
    • oliver2-44
      By oliver2-44
      I have a large dirt leveling & shaping project coming up down the road.  Seat time!
      I need to be able to loosen up high areas to push them around to level and improve drainage of a 100 ft x 150 ft back yard.  The soil is sandy/clay granite gravel. It has enough clay in it to be very hard when very dry, but will dig fairly easily when damp.
      So I'm starting to think about how to install a tiller and dozer blade on my C-160 at the same time.
      I wish I could even mount the Tiller and a Center Mount Grader Blade at the same time.
       But I suspect the blade would hit the front wheels when angled since it would be mounted forward of its normal position, or it would hit the front tiller pulley?
      One idea I'm thinking of essentially making a double rear axle hitch, one in front of the other. The tiller would mount in the rear mount under the axle in the normal positionn so the pulleys would be in the correct location so the belt length would not change.  The dozer blade wound mount in the forward mount, and its lift link would have to be a custom length. I'm thinking I need to make some type of support bracket from each side of the front mount that would mount to the frame.  The forward mount would also have to be spaced forward enough so the end of the dozer blade arms  would not hit the tiller cross bar in the rear hitch mount.The normal hitch locks probable would not work, so I'm thinking a locking bar would be bolted on to lock both implements in place.
      The other idea would be one hitch directly below the other in the normal axle position. It would also have to have some type of brace to the forward frame so as to not put a twisting force on the axle.  I  haven't figured out if there's enough ground clearance to do this type of arrangement.
      The front dozer blade would be lifted by the existing hydraulic lift and the rear tiller would be lifted by a 2nd rear hydraulic cylinder.  Only one implement would be in use at one time.
      I'm thinking I will make a wood mock up of both ideas to work out some basic details before I start cutting & welding.
      Has anyone tried this?  I would like to learn what worked and what didn't from others. if you haven't tried it, I still like to hear your thoughts on what might work, or potential  problems that I haven't thought of yet.
      Thanks
      So many projects, got to find a way to make them fun!
