310-8 guy
Need help restoring 310-8
310-8 guy
I have a wheel horse 310-8 and I'm really interested in restoring it. I would love to repaint it and make it look original but I don't have a paint gun. Any ideas?
Brian01
Looks fine to me, just clean it up real good, be surprised what a difference it'll make
310-8 guy
Thanks. I'm waiting for it to Warm up outside because dang it's cold. This thing sat I'm some lady's barn for 9.5 years. I had to spend last winter digging it out. Little embarrassing because it's never this dirty at all. The only problem that I have is if I put up the throttle all the way I think it runs way way to high.... Maybe I adjusted the linkage wrong?
Brian01
Could be out of adjustment...more than likely the high side of carb is turned up though.
Just don't idle it up all the way? :scratchead:
310-8 guy
Oh God no. I'm very touchy about doing that. I never let anyone touch this thing either because they think it's alright to make it go so high. I think it's running rich because the plugs always black (I brought a new one to make sure)  and it was black. So is there anyway to adjust the carb? I see one idle screw and that's all.
mikekot3
A HVLP (High volume low pressure) spray gun for primer and another one for color is a good idea. Also having a small touch up gun with a real small paint cup is handy as well.
Brands I have found to work well is Sata, Iwata, Devilbiss, Binks and others. Also I have seen inexpensive ones at tractor supply and eastwood.com
Basically you need to match the spray orifice size to the material you are spraying. The paint vendor should offer data sheets with proper specs to meet. Also you need a good sized 5hp or bigger air compressor with at least 30 gallon tank and moisture filters in the supply to your spray gun. Also you must wear a proper respirator like a 3M P95 for your lungs or they will get damaged from breathing the nasty chemicals. You will also need a tyvek paint suit to protect your skin and wear nitrile gloves.
Edited by mikekot3
310-8 guy
Basically you need to match the spray orifice size to the material you are spraying. The paint vendor should offer data sheets with proper specs to meet. Also you need a good sized 5hp or bigger air compressor with at least 30 gallon tank and moisture filters in the supply to your spray gun. Also you must wear a proper respirator like a 3M P95 for your lungs with get damaged from breathing the nasty chemicals. You will also need a tyvek paint suit to protect your skin and wear nitrile gloves.
That's a lot to take in but sounds reasonable... This sounds crazy but if you could do it right... Would spray paint work...?
Brian01
Here's my spray painted RJ
mikekot3
Using rustoleum paint cans works okay which I have tried. But It takes forever to dry especially when it is cool outside. When it is 90 degrees it helps with paint drying faster.
I would suggest starting with the 40 dollar tractor supply setup and buy a 35 dollar 3M paint respirator and and a Tyvek suit for starters once you have the air compressor and inline moisture filter.
310-8 guy
True
Brian01
Yes, I agree, if your gonna try n paint it in the near future, be sure you do it in a heated garage.
310-8 guy
Holy crap! You sure that's sp? That looks professional!
I'll have to wait till summer. I have maybe a cupple living room heaters I could use to warm it up fairly.
clip
Check out the Harbor Freight purple HVLP spray guns. They're surprisingly good quality for the price. I was doing some reading on paint forums and they're accepted to be the best budget option. Just remember air quality going in makes a huge difference, as does temperature and surface cleanliness. Make sure the air is dry and oil free and your compressor is big enough to keep up with the demand.
310-8 guy
I have a 3.3 horse air compressor with a 20 gallon tank. I've never painted anything along these lines before. I'm really scared about really screwing things up.
Brian01
The strategy when spray painting with rattle cans, is not to get carried away, several thin coats...if you try to just spray it all on there to cover, you will end up with runs, etc.
Edited by Brian01
310-8 guy
55 minutes ago, clip said:
True
DougC
Wow. I gotta agree with Brian. Blow that tractor and mower deck off really good with compressed air, Wash with soap and water and a soft wash mitt. Dry it off and buff it out or pay  someone in your area that has some expertise with a buffer buff it for you.  Wax it and stand back. That baby would look brand new. If you have never painted before there is a lot more to it to do it right and have the results you want than most people think. That would put a smile on your face for this winter anyway and if the desire to paint it is still there, in the spring. Go for it.    :)
310-8 guy
Oh I love cleaning this thing. Accually just got done driving it around. Just wondering how do you take off the deck? Is it really hard?
Brian01
I've never owned a 310 -8 so I couldn't really tell you how to remove the deck, but I can guarantee you it won't be hard...its a Wheel Horse, for cryin' out loud! lol
310-8 guy
Lol very true! I'm just hoping it isn't like the stupid mtd (made to die)  decks...
DougC
How to remove a mower deck
In instructional threads and videos by nylyon.
310-8 guy
Is that a link? Sorry using a phone for all this
DougC
I was hoping that would take you to it but it is on the home page down a ways in Instructional Threads and Videos . It is a topic in there not a video.
slammer302
The great thing about painting is if it doesn't come out good let it dry and sand it down and try it again!
clip
Odds are you will probably screw up with an HVLP setup the first few times you use it. The good thing is, you can usually catch yourself before it gets too far and you don't have much rework. It seems simple but there are a lot of nuances to get down just right, such as air pressure going in, air pressure at the tip, air flow, paint flow (like the jet in a carb), fan pattern, droplet size,etc. I used a compressor about that size for a few years, and ended up adding a second and third tank for increased volume. It became a 70 gallon setup on a single cylinder compressor, which took forever to fill but the increased capacity made things a little better.
I'd tell you "don't try and learn on a project you love" but that'd be going against what I've always done. It's how I learned to paint and weld, all trial and error. I've messed up spray painting and HVLP before, and the HVLP process gives you much more control over the finished product so you know exactly how much paint you're putting on and what your fan pattern looks like. I say go for it!
  • Similar Content
    • OHLB
      By OHLB
      Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
    • Big Rig
      By Big Rig
      ISO clutch neutral safety switch for 310-8
      or alternative
    • Rob R
      By Rob R
      Soo couple of years back did a pulley change on the tranny from 6 inch to 4.5 and used a 1/2 X 79 belt to make it work and it worked fairly well but wanted to get back to a 5/8 drive belt so went to a 5/8 x 81 inch belt and added a second flat Idler pulley. I simply cannot believe how smooth and sharp it shifts and drives now!  The added flat Idler was 2 3/4" with a 5/8ths bore used and existing hole on the side shroud and just opened it up a bit. I use to slip a bit on steep hill with the 79" slips no more, the belt drives and the clutch is  LOT smoother and in the right pedal area.... Will see how it holds up cut 3/4 of an acre of grass yesterday NO issues.
    • Ifixoldjunk
      By Ifixoldjunk
      So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
      Like would generic adjustable go-kart tie rods do the trick?
    • Ifixoldjunk
      By Ifixoldjunk
      so I spent a few hours today welding up a custom front weight bracket for my 310-8. It has two and a half inches of ground clearance with a generic 12 inch weight bolted on.
      so the question is, how well do y’all think the 300 series front axle will hold the weight? It’s only 50lbs so it’s lighter than the snowblower it has to hold up in winter so I don’t think I’ll have any problems. And I really don’t intend on using it constantly.
